Old 06-17-2012, 07:11 AM   #31
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 345
Originally Posted by ADV8 View Post
Very nice Eldorado
Its amazing how many are posted in the various threads.
Does anyone know what sizes the double ended ring spanner that comes in the tool kit is by any chance ?
24mm and 22mm I believe. 24 fits the axles; 22mm fits the dipstick and trans and rear drive fillers.
Life's too short.
F_Sahms is offline   Reply With Quote
Old 06-17-2012, 04:37 PM   #32
ADV8
Taumarunui..Darwin..
ADV8's Avatar
Oddometer: 2,313
The person who got you the billet DR650 third gear set, you're welcome.
49 Sunbeam S7 Deluxe-57 TR6 Trophy-68 Huskys x 2-71 Commando Fastback-73 Ducati 750GT-73 Eldorado-74 TR5T x 2-74 Commando Roadster-73 and 74 H2A/B-77 and 81 900SD's-86 400WR-98 TL1000S x 2-08 DR780-07 Ducati HM 1100S
ADV8 is offline   Reply With Quote
Old 06-17-2012, 04:51 PM   #33
sjc56 OP
Oddometer: 1,336
Yes they are Road King shocks. I had them on my 850 Lemans but that was so wrong. A better fit on the Eldo.
Steve
sjc56 is online now   Reply With Quote
Old 01-05-2013, 11:13 AM   #34
sjc56 OP
Oddometer: 1,336
Well it took awhile, I finally got my gearbox back from my friend who went through it for me and got my friend Tom a long time loop owner to help me install it, a bit differnt from a Tonti (I can do that solo) got a few dings on the frame.
So motor has new seals, timing chain and tensioner, new rings. Amal carbs rebuilt, new wiring by Greg Bender he does great work, u joint rebuilt, new u joint bearing, tires etc. My friend Tom was looking through my parts and notised the new set of head pipes that came with it aren't for a Guzzi, I never looked at them to closely they look like they are for w Triumph or BSA, rats a couple of hundred bucks I was going to spend on some new crash bars.[IMG]
P1030498 by steven_j_cote, on Flickr[/IMG]
Steve
Old 01-05-2013, 06:44 PM   #35
danedg
Horizontally Opposed
Oddometer: 6,611
I'm pretty sure it's 27 - 22mm.
I've been using it a lot to spin the crank nut as motor comes apart.
Your progress is inspiring!
danedg is offline   Reply With Quote
Old 02-08-2013, 01:43 PM   #36
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,900
Hey SJC did you say you had the lifters refinished? If so I was wondering about the process, and how did the cam look? I thought the cam and lifters had a special silicon carbide coating or something that makes them wear a long time...please enlighten me!
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Old 02-08-2013, 03:01 PM   #37
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 345
You are correct. Loops had the 27mm version and the Tontis had a 24mm version:
http://www.thisoldtractor.com/gtbend...ok_v7sport.pdf
Life's too short.
Old 02-08-2013, 05:12 PM   #38
baloneyskin daddy
bikaholic
Oddometer: 2,103
I've never seen handlebars set so far backfrom the forktubes! Seems it would steer like a wheelbarrow.
baloneyskin daddy is offline   Reply With Quote
Old 02-08-2013, 08:05 PM   #39
MZRider
Neo-Luddite
Oddometer: 705
Loopframe Guzzis don't "steer like a wheelbarrow" at all. Try one sometime.
Charlie
http://www.AntietamClassicCycle.com
'69 Guzzi Ambassador,'77 Yamaha XT500,
'88 Ducati Paso, '91 ATK 604
'94 MZ Silver Star, '96 CCM 350
MZRider is online now   Reply With Quote
Old 02-08-2013, 08:20 PM   #40
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 345
With the civilian bars, mine steers pretty well. Not any slower than a tonti.
Life's too short.
Old 02-08-2013, 08:25 PM   #41
F_Sahms
mostly paved
F_Sahms's Avatar
Oddometer: 345
That is a great looking front brake.
Life's too short.
Old 03-23-2013, 01:35 PM   #42
sjc56 OP
Oddometer: 1,336
Eldo running kind of.
Kind of.
http://youtu.be/pDpWbU1-DvA
It's spitting back through the right carb
Runs best with mixture screws all the way in
Rattling from timing cover. It goes away if I touch if I just touch it with a screw driver, maybe pulley is rubbing.
The strange thing is, watch the video and you will see what looks like gold sparks around the header, but they are to slow for sparks.
Steve
Steve
Old 03-23-2013, 02:12 PM   #43
danedg
Oddometer: 6,611
Love your new gas tank.
What are those doohickeys on your headers? The golden sparks are really strange., might just be your digital camera. Plugs and wires all tight?
Just a reminder, ride every chance you get. You just don't know how soon it can be taken from you. T.Low
danedg screwed with this post 03-23-2013 at 02:22 PM
Old 03-24-2013, 09:29 AM   #44
sjc56 OP
Oddometer: 1,336
Progress! The sparks where from the fact my manifold nuts where lose the sparks where coming from the exhaust by the head.
Steve
Old 03-24-2013, 10:27 AM   #45
danedg
Oddometer: 6,611
Those aren't sparks...they're Flames!!!
Nicholas Cage would be proud!
Times are GMT -7.   It's 07:45 PM.
