Old 12-27-2012, 09:36 AM   #2971
WindSailor
WindSailor's Avatar
Oddometer: 329
Originally Posted by NoVa Rider View Post
Doing very well, I just need to wire it into the fuze block. . ..
That should make the "100 THREADS all GS/GSA owners should read." thread...
Top ten anyway...
WindSailor is offline   Reply With Quote
Old 12-27-2012, 01:05 PM   #2972
G19Tony
G19Tony's Avatar
Oddometer: 366
Just ordered two Model 44's. I'm getting all the electrics done at once on my Versys.
ADVmonster lights
OEM heated grips
Fuzeblock
Stebel Horn
Hardwire the Garmin GPS.
Honda CT70, Hodaka Dirt Squirt, Kawasaki Versys, Suzuki TU250,
Honda CRF250L, Honda CRF80F, Honda CRF230F, Honda CL70.
Nothing's too cruel if it's funny enough.
G19Tony is offline   Reply With Quote
Old 12-31-2012, 09:51 AM   #2973
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,661
ADVmonster lights
OEM heated grips
Fuzeblock
Stebel Horn
Thanks for your business!
Sounds like you will have quite the adventure setup. The Kawi Parallel twins rock
Old 01-04-2013, 06:42 AM   #2974
RoundOz
Plenty of seasoning
Oddometer: 707
Anyone put one of these units inside a headlight shell? Would enclosing it shorten its life? What about with the extra heat of a headlight bulb or projector light all in the same small space?
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 01-05-2013, 09:49 AM   #2975
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,661
There has been a couple of installs in headlight shells. The lights do need some air flow for thermal management.
We do offer a bulkhead mount that let's you mount through a flat surface.
Old 01-05-2013, 12:07 PM   #2976
WindSailor
WindSailor's Avatar
Oddometer: 329
Pinging for an update - how are you coming on your new set of lights etc.?
Old 01-06-2013, 05:22 AM   #2977
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 700
+1
I have a new to me R1150R that needs some lights. This will make 3 1/2 sets of your LED's for me!
Bob Weis
04 K12RS - Hannigan Hack
You rarely see a motorcycle parked outside a psychiatrist's office.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 01-06-2013, 07:15 AM   #2978
RoundOz
Plenty of seasoning
Oddometer: 707
Sanjoh
Any problem with just unscrewing the back off one of my 44's and replacing the mounting bracket with a thin aluminum plate (with heat sink compound) which will be both an extra large heat sink outside the headlight shell, as well as a custom-shaped mounting bracket bent roughly to the shape of the headlight shell (very little room behind the headlight) ?
2009 KTM Adventure
Old 01-06-2013, 07:28 PM   #2979
lvscrvs
lvscrvs's Avatar
Oddometer: 446
I'd like to mount 2 LEDs on the engine guards on my Tiger ( so they would be somewhat protected in case of a fall). As you can see from the pic below they would be about 26-27" off the deck (bike is on the sidestand in the pic) if mounted on the horizontal flat piece. I would like to have the lights on whenever the bike is running for daytime conspicuity, and at night, so I have better viewing down the road when I have my low beams on ( the low beam on the Tiger is pretty weak, so this is really important). What lights would you recommend?
Thanks,
Brian
Tiger 955i / DRZ400S < FJR1300 < DL1000 < BMW R1100RS < Ducati ST4 < DL650 *** 30+ years *** 125 Honda Elsinore < Suzuki TM250 < Yamaha 90 Enduro < Taco
lvscrvs is offline   Reply With Quote
Old 01-06-2013, 07:38 PM   #2980
jeepinbanditrider
Dunkin Donuts Crasher
jeepinbanditrider's Avatar
Oddometer: 782
Mounted on my F800ST
This is WAY better than the stock headlight could ever do.
2004 Suzuki DL650 Weestrom/2007 BMW F800ST
1998 Suzuki DR350SE
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Old 01-07-2013, 05:38 AM   #2981
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,661
Looking good for ~1/21/13
More info and beam pics coming
Originally Posted by Bobmws View Post
+1
Thanks for being a great customer
Sanjoh
Sounds like it should work ok.
Old 01-07-2013, 05:52 AM   #2982
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,661
Thanks,
Brian
A pair of Model 30s would work great. Look at the F800 pictures on this page, looks like you have a similar height for mounting.
One of our LED controllers with the high beam bypass will give you the DRL and full power options you are looking for. Set it and forget it, the lights come on with the bike in DRL mode, full power at a flick of your high beam switch.
Having put a few thousands mile on the same vintage tiger, most of the stock headlights are way out of adjustment. The adjustment procedure is a bit intimidating but made a huge improvement in my stock headlight. Check out the folks at tiger triple for more info.
A few years ago. Lands End Rd on the Grand Mesa, western CO.
Old 01-07-2013, 11:31 AM   #2983
lvscrvs
lvscrvs's Avatar
Oddometer: 446
Thanks for the tip on the Tiger headlight adjustment, I will check that.
I think the Model 30s would work well for me. I believe I had those on my FJR and they worked great. When I did the FJR install, 2 years ago, I believe I used your Waterproof Switch - no others available at that time - and I was able to cycle the lights through 3 different settings plus off. I just left them at the middle setting and they worked well. Can I still use that switch in that way?
I guess I don't quite understand how I would use the DRL rotary switch... DRL, CCW and PWM are greek to me, but if it means I can run the leds on a dimmer when on low beam, and I will get full led power when on high beam, that seems like a good option.
Thanks again.
Old 01-07-2013, 05:05 PM   #2984
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 3,661
Nope, the dimming is now external to the light. You get almost unlimited adjustablity of the light output.
Thanks again.
That's it, works just like you described.
Old 01-08-2013, 07:20 PM   #2985
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,497
Just ordered a set of 30's. Looking forward to it!
Jim
Times are GMT -7.   It's 02:21 AM.
