Old 01-03-2013, 06:06 PM   #61
go2cnavy
go2cnavy's Avatar
Oddometer: 561
Originally Posted by aquaheshe View Post
Why? Because I'm not as smart as you? We did post a pic. Don't pee on my parade dude!
No, because I was feeling a little froggy. Many posers on this board post long laundry lists of intended farkles complete with claims of extravagant stables filled with bikes because of their unlimited resources and months off to enjoy riding. The post just smelled funny to me.
If this post is legit then CONGRATS to you! Seems like a fine build and a great score on an unmolested SE.
P.s. I installed a Rekluse EXP about 1500 miles ago and it has been the best addition to my ADV bar none.
go2cnavy is offline   Reply With Quote
Old 01-04-2013, 04:18 AM   #62
Harold Waikiki OP
oldfatdumbbrokeoutof
Harold Waikiki's Avatar
Oddometer: 405
I'm real. Semi retired with a bike addiction. Thanks for the post. I have rekluse clutches on my 350, 530, and 990. All tweaked by Al himself (the owner of rekluse) in Boise. Head2wind has seen my 350, 530, and 990. All highly modified/farkled. We are going to post further pics as we go along. I think I have a pretty good list. any helpful ideas?
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
'09 KTM 950 SE Erzberg
'15 KTM 1290 SA ordered.
Harold Waikiki is offline   Reply With Quote
Old 01-04-2013, 06:52 AM   #63
go2cnavy
go2cnavy's Avatar
Oddometer: 561
You list looks like it includes everything except a spare set of wheels. one set up for the street and one for the dirt.
Old 01-04-2013, 08:43 AM   #64
Harold Waikiki OP
Oddometer: 405
basically making a big dirt bike. very little street. only to get to more dirt in the middle of no where. gonna use up stock tires, then mount tkc front and rear mefo super explorer or heidenau k60. have this set up on my 990 and love it. recommended by Geek and I really believe he knows everything! my dirt riding abilities on this bike will not require any knobbier tires. if it's technical then i will ride a different bike. that being said i would love a set of woody's wheels!
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
Old 01-04-2013, 09:45 AM   #65
charlie264
charlie264's Avatar
Oddometer: 8,372
No he doesnt, Mitas E10 front is better. Better side walls.
Old 01-04-2013, 10:41 AM   #66
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,078
My comments on your list.
ballistic battery
facet fuel pump
voltage regulator relocate-custom
carbon tank covers, ignition cover, clutch cover
I would strongly recommend you stay away from ballistic batteries. I had two in sequence die, on the first use. I believe the best lithium at the moment is antigravity 12 cell, but haven't tested because of cost. Shorai seems to have some believers in here.
My facet died at 15k kms. I think DrBean solution is far more reliable and closer to the initial design and function. I use one at the moment.
On the voltage regulator I would recommend installing a Shindengen Mosfet R/R. Avoids baking your CDI in case it dies and doesn't generate too much heat when alive.
I believe clutch covers to be obstacles in radiating heat so I would avoid it.
The rest are great updates I would follow if I had unrestricted budget.
I would be interested on your jetting with dome air filters.
Cheers
gefr screwed with this post 01-14-2013 at 09:16 AM
Old 01-05-2013, 02:06 PM   #67
Harold Waikiki OP
Oddometer: 405
My facet died at 15k kms. I think DrBean solution is far more reliable and closer to the initial intended operation. I use one at the moment.
Cheers
great info. thank-you. we will post progress notes and pics. i have ballistic batteries in my 530 and 990 and have never had any problems. head2wind is the brains here. i will make sure he reads your post.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
Old 01-05-2013, 02:35 PM   #68
amanlikemike
Recoverin speedfreak
amanlikemike's Avatar
Oddometer: 1,050
This is gonna be fun!
Doing similar with a 990 myself at the moment.
Let me know if you need any advice on 'low-to-no' weight, short-haul, off-road luggage options.
Happy Farkling!
Cheers,
Michael
'Ave it.
BritKit LLC
US Distributor of Kriega Motorcycle Luggage
www.kriega.us / Facebook / vendors thread
amanlikemike is offline   Reply With Quote
Old 01-14-2013, 05:09 AM   #69
michaelmy
Oddometer: 30
Thanks for all this, I have just acquired an 08 SE on similar miles in the uk
I ( but mostly the previous and only owner) have done all of the mods being talked about
Only things I am looking at are rotopax on the wolfman racks
also the centre stand but an Anderson stand will do pro tem
Michaelmy in Fulham
06 HP2, 67 Honda Monkey (since new!)
michaelmy is offline   Reply With Quote
Old 01-14-2013, 06:25 AM   #70
charlie264
charlie264's Avatar
Oddometer: 8,372
Nice find.....Have a butchers at the UK KTM forum.
Old 01-14-2013, 09:25 AM   #71
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,078
I would also recommend
Small simple things:
little drain holes at the lower side of your wishbones
bolts that run through the wishbone, securing the chain slider in place
Cheers
Old 01-14-2013, 02:10 PM   #72
Harold Waikiki OP
Oddometer: 405
Cheers
great ideas. also considering the center stand. i am having a custom rear rack made that will accomodate rotopax and winch at the same time. or it will also accomodate a touratech aluminum top case. presently ordering stuff. still waiting on bike. being shipped from Iowa by way of Milwaukee. slow.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
Old 01-14-2013, 02:12 PM   #73
Harold Waikiki OP
Oddometer: 405
Happy Farkling!
Cheers,
Michael
what are you thinking?
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
Old 01-15-2013, 08:08 AM   #74
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 5,010
A top case? I thought you said this was going to be for dirt riding...
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 01-15-2013, 12:42 PM   #75
Harold Waikiki OP
Oddometer: 405
sometimes i will take my special lady friend 2 up, she will lean against it a bit. we do the same thing on the 990 and the ducati. same top case moves between 3 bikes. custom made back rest so she is comfortable. also take a wine and cheese spread into the boonies. with a blanket.
'14 KTM 1190R
'12 KTM 350 EXC
'82 Honda CT 110
Times are GMT -7.   It's 03:46 AM.
