Old 01-02-2013, 01:27 PM   #1
freefall109 OP
freefall109's Avatar
Oddometer: 156
4 month bike storage question.
I will be heading overseas or four months and leaving my triumph tiger in northern Jersey in an unheated garage. My question is, do you think it would be better left sitting after prepped or having my someone start and run it for a period if time every week? If the latter, how long and often should it be done?
Thanks.
---The only time you have too much fuel is when you are on fire!---
freefall109 is offline   Reply With Quote
Old 01-02-2013, 01:57 PM   #2
PoundSand
PoundSand's Avatar
Oddometer: 6,883
4 months is nothing. full tank, some fuel stabilizer and call it good.
Edit - and if I were feeling motivated, I'd disconnect the battery.
PoundSand screwed with this post 01-02-2013 at 03:46 PM
PoundSand is offline   Reply With Quote
Old 01-02-2013, 02:05 PM   #3
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,394
Don't start it unless it's going to be ridden for long enough to get the oil good and hot to burn off acids and condensation. Otherwise, you're doing more harm than good.
Four months is fine for fuel injected bike. Fill the tank completely full, add some stabilizer, ride the bike around enough to get the treated fuel through the system, and park it. You may also want to use a battery tender.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 01-02-2013, 02:06 PM   #4
nwcycle
nwcycle's Avatar
Oddometer: 1,184
Another.....
We use SeaFoam, way better than StaBil, If its fuel injected you should have no worry's, but make sure you fill the tank, no rust will start if its full, I usually air up the tires more to eliminate flat spots, maybe put on wood, dont know if it helps or not but always did that.....................
nwcycle is offline   Reply With Quote
Old 01-02-2013, 02:14 PM   #5
Cataract2
Where to?
Cataract2's Avatar
Oddometer: 1,828
Stabil in gas and battery maintainer and you should be just fine.
People who get made because they're old, haven't lived.
Cataract2 is offline   Reply With Quote
Old 01-02-2013, 03:34 PM   #6
sieg
sieg's Avatar
Oddometer: 2,883
True
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is online now   Reply With Quote
Old 01-02-2013, 04:36 PM   #7
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
I'll ride your bike for you, just drop it by.
Old 01-02-2013, 07:03 PM   #8
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
No worries, Sta-Bil, run it in 10 miles, top up the battery every few weeks.
Old 01-03-2013, 06:28 AM   #9
Grinnin
Forever N00b
Oddometer: 2,893
I was amazed at how much water condenses in a muffler.
I was building baffles and testing various configurations. One time I started the bike and it was immediately apparent that it was far too loud so I shut it off after just 10 or 20 seconds and removed the baffles. The baffles were covered with water droplets although not quite dripping.
It takes a while for the entire exhaust system to heat up enough to clear the condensation out. If you add condensation every week or so you'll be looking for new mufflers far sooner.
"The belief that there is only one truth, and that oneself is in possession of it, is the root of all evil in the world."-- Max Born, Nobel Physicist
Grinnin is offline   Reply With Quote
Old 01-03-2013, 08:49 AM   #10
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,030
Just a bit of trivia, that is one of the reasons old Honda 4 into 4 exhausts rusted out so quickly. With only one cylinder going into each ( pretty large) muffler, it took quite a few miles to warm them up enough to get rid of the condensation. As a consequence, they just didn't last.
As everyone else mentioned, add stabil or sea foam, fill it completely, hook up a battery tender if you have one, and let it sit.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 01-03-2013, 03:16 PM   #11
freefall109 OP
Oddometer: 156
Thanks, stabil added, trickle charger on and muffler sprayed with wd40 and stuffed closed. Appreciate the help!
Old 01-04-2013, 05:53 PM   #12
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
And you RODE it a few MILES to get the fuel stabilizer in the fuel system?
Old 01-04-2013, 06:02 PM   #13
freefall109 OP
Oddometer: 156
I started it and let it run for about five minutes which was the best I could do with snow and ice on the roads.
Old 01-04-2013, 07:43 PM   #14
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,617
So you generated a bunch of moisture in the crankcase and exhaust system, and are going to leave it that way for 4 months.
You would have been better off avoiding the fuel stabilizer and leaving the whole thing alone.
Flashmo is offline   Reply With Quote
Old 01-05-2013, 06:05 PM   #15
freefall109 OP
Oddometer: 156
Yes, Flashmo. Thank you for the feedback.
Times are GMT -7.   It's 06:46 AM.
