Old 01-05-2013, 05:13 PM   #1
jrsride2002 OP
jrsride2002's Avatar
Oddometer: 82
OK, need to talk Trailer stuff
OK, so I JUST bought a single axle trailer off CraigsList. Like it, for the most part....
So I need a hear to heart talk about this. This is my first trailer, that will be hauling MAYBE 1500lbs plus the ~1250lbs trailer. I've already set my van up to handle this and much much more.
Want to talk about add on's, and modifying this sucker, just a little bit. Normally with me, their is no little bit of mod'ing but with this, it seems pretty set up for my needs... When I got it, wasn't to happy that the manufacture didn't install an e-brake system. I dont know what would be more daunting of a task. Larger brakes on the Astro, to handle something like that OR e-brake the trailer... Just dont know.
Also I was checking the lights off the sellers truck, and the lights could BEARELY been seen during in the day light hours, so I am gonna head up to Harbor Frieght for some LED replacements, and may through on some side signals also while I am at it.
By doing these mods, extra lights, and e-brakes. Wouldn't that pretty much require a 7 prong plug as apposed to the manufactures 4 prong plug??? I not positive, but I thought I read that some where on here a while back, could totally be wrong though...
Lastly, I do a LOT of dirt bike riding in my local deserts and have started going in to the woods. I have have every belief in God, that my buddies are gonna want to do a ride, or join me for a trip. I could end up hauling a load of bikes, so I want to do what I spotted on someone elses trailer....
(this is not my trailer, it belongs to durangoman and might still be for sale, but this is one I am looking to copy)
As for my trail specifically, I bought a 2011 PJ Single Axle - U8 trailer. U8, refers to the size, for the most part. It is a 7' x 14' trailer. Here is a link to a PDF of many trailers, including mine, from the manufactures website: http://www.pjtrailers.com/brochures/web_utilities.pdf
No joke, I spent close to 4 hours, in a parking lot, just trying to understand how to park this thing.
Wants/Need to do's:
E-brakes
7 prong plug
LED tail lights
E-track and hook ups
I do not have much more I can think of at this time.
Really looking for some insight, opinions, comments, concerns, evaluations, etc...
Thanks guys for reading,
~Junior
'02 XR650L: Accerbis tank, motor mods, suspension mods, electronics mods
'02 DR650: Yamaha Raptor 660 petcock, everything else stock
jrsride2002 is offline   Reply With Quote
Old 01-05-2013, 06:31 PM   #2
acejones
acejones's Avatar
Oddometer: 5,282
Most single axle trailers don't have e-brakes. You don't normally see those until you get to double axles.
I got tired of being here, so now I'm there
acejones is offline   Reply With Quote
Old 01-05-2013, 06:42 PM   #3
jrsride2002 OP
Oddometer: 82
Should I consider doing that?
I just dont know about the brakes on my van is my main thing.
Old 01-05-2013, 06:54 PM   #4
acejones
acejones's Avatar
Oddometer: 5,282
Maybe consider a newer van or talk to a good mechanic to get his opinion of the vans braking ability.
Old 01-05-2013, 07:20 PM   #5
oldmanb777
Just say NO to socialism!
oldmanb777's Avatar
Oddometer: 4,042
The most important thing is: make sure you have adequit tongue weight. If you don't IT WILL BECOME UNCONTROLABLE!!!!!!! and thus WILL kill someone. The DOT has some good info on thier website about this. After that make sure you have more than enough brake energy. Then take it easy when towing. You can't stop as easy and maneuver as easy. Kinda like riding with an unpredictable pillion.
oldmanb777 is offline   Reply With Quote
Old 01-05-2013, 07:38 PM   #6
showkey
Oddometer: 1,974
The main reason single axle trailers do not have brakes is cost................the trailer industry is so price competitive they leave brakes off to meet a price point. Trailer brakes are on the top of the list of nice to have. Once you have a trailer with brakes you will not buy one without brakes.............been there.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is offline   Reply With Quote
Old 01-05-2013, 07:44 PM   #7
CanadianX
Oh!? That is deep.
CanadianX's Avatar
Oddometer: 1,694
Might want to check the inspection rules for trailers with vs without brakes. Brakes on the trailer could be a nice thing but could be far more costly then just upgrading the brakes on your van. I tow an enclosed trailer, single axle and no brakes and the brakes on my SUV (Xterra) do just fine. I drive a little slower and give myself more space for the added measure of comfort.
I added the E channels to mine, a must do as it makes it so easy to strap things down.
CanadianX is offline   Reply With Quote
Old 01-05-2013, 09:23 PM   #8
Helipilot
Helipilot's Avatar
Oddometer: 192
PJ trailers are usually very well made and will last you for a long time if you take care of them. The dim lights were probably a result of a bad connection or improper ground connection. Check your wiring for a short. The trailer will have a three wire set; Green is the right side of the trailer's brakes and turn signal; Yellow is the left side for brakes and turn signal lights; the Brown is the running lights. The left and right is determined by standing behind the trailer and looking forward to the tongue.
A new axle is the best way to get electric brakes since the brake wire is inside the axle tube to get power from one side to the other. A 3,500 lb brake axle should be no more than 150.00 without springs (Note: Buy the Easy-Lube axle to insure you get grease to the back bearings when you do your ANNUAL axle service). You can use your springs that came with the original axle. The brake axle is directional and you must mount it with the right and left brakes on the corresponding side of the trailer or they will not work. Additionally, you will need to install a Break-a-Way system which consists of a 12 v small battery and a snap switch to activate the circuit and stop the trailer if it breaks away from your vehicle. This will be about 60.00. You will need to install an additional wire pair to operate the brakes, one hot and one ground wire. This should make you 50 state legal if you are less than 8'wide and16' in length.
This will call for the 7-prong plug to run the three basic wires, the two wire brake system, a ground wire and a hot wire to keep the Break-a-Way battery charged. It is not difficult to do if you want to invest in the trailer. I used to own a trailer manufacturing and axle distribution company (31 employees) as part of my flying operation. Personally, if you are going to haul other riders bikes I would suggest a two axle trailer since if you have a flat on a single axle trailer it becomes pretty uncontrollable if you are heavy and are at speed and you also have the ability to carry up to 7,000 lbs which includes the weight of the trailer. Good luck in your endeavor.
2004 XR650L Heavily Farkled.
Helipilot is offline   Reply With Quote
Old 01-06-2013, 10:52 AM   #9
mookybird
Gramps
mookybird's Avatar
Oddometer: 213
I certainly don't want to be the guy who teels someone not to uggrade their brakes.
I own a number of small trailers, some get used every year and others everyday, I love little trailers they just sit there waiting until you need them and the battery is never dead, they don't need antifreeze etc.
I've run tens of thousands of miles with trailers without brakes on them and of course many of those were with heavy loads and pulled with a 2wd toyota.
Brakes are always good and more brakes are always gooder but not having them on a light trailer isn't horrible.
I believe big in good wiring with soldered joints and good quality heatshrink over them, LED lights are a really smart idea and lastly I buy expensive tires for any trailer that I'm going more than a few miles with. Enjoy your trailer it looks like a nice one and unlike just about everything else a person buys they are worth as much years from now as they are today.
mookybird is offline   Reply With Quote
Old 01-06-2013, 12:48 PM   #10
jkm
Oddometer: 204
I learned that a little of the e-trac goes a looong way. I actually put too many sections of it on my trailer and never use some of it. I'm going to take the extra back off because it's difficult to set gas cans, etc on top of it.
I use the ATK bike shoes. I mounted each one to a seperate piece of plywood. Then I put thread inserts in the bed of the trailer. I attach the plywood / shoes to the bed of the trailer using a thumb bolt down thru the plywood and into the thread insert. This system permits me to easily remove the shoes and have a nice flat trailer floor for hauling other things when I need to.
Good luck. Sometimes it's hard to stop farkling a trailer......jkm
jkm is offline   Reply With Quote
Old 01-06-2013, 02:10 PM   #11
slobinski
Inept adventurer
Oddometer: 438
Years ago I bought a ten foot utility trailer with a 3500 pound Hayes single axle, to use at work and elsewhere. Could not find one this size with electric brakes, so I eventually researched and discovered that Dexter brakes and hubs would fit it perfectly, and best of all were in stock locally. Did this mod one winter and it's worked fine ever since, and I'm still on the original brakes. I don't know if this would be cost-effective today, but it may be an option. I remember it being a fun project; possibly more so because the dealer assured me it would never work.
slobinski is offline   Reply With Quote
Old 01-06-2013, 07:59 PM   #12
Stumpalump
Oddometer: 128
Unless your hauling 3 Harley's then you don't need breaks. They will lock up too easy. If you do it, a good controller should be considered.
KTM 950A
Rokon 2X2
Montesa 315R trials
KTM 200 EXC.
XR400
Stumpalump is offline   Reply With Quote
Old 01-06-2013, 08:09 PM   #13
troidus
Oddometer: 15,737
I went with a surge coupler and disc brakes on my 5x10. That way the brakes always work no matter what's being used to pull it and they work in reverse. Should the trailer come loose when going up a steep hill, the safety wire will trip the brakes and they won't unlock themselves when the trailer tries to roll back downhill. The disadvantage to surge brakes is not being able to tap the trailer brakes alone to line things back up if things get a bit squirrelly. A huge advantage is that the trailer brakes will never lock up under normal use no matter how it's loaded.
troidus is online now   Reply With Quote
Old 01-06-2013, 08:12 PM   #14
troidus
Oddometer: 15,737
Originally Posted by jrsride2002 View Post
... and may through on some side signals also while I am at it.
Do you mean side markers, or turn signals? U.S. vehicles aren't equipped with separate brake and turn signal circuits for trailers. For my tow vehicle, I got a European 13-pin harness. (Some day I'll actually install it.)
Old 01-06-2013, 08:15 PM   #15
kiwi_outdoors
kiwi_outdoors's Avatar
Oddometer: 114
7x14 is a big trailer
maybe not with bikes - but if you ever start hauling other stuff, such as wet garden refuse, it gets heavy quickly, and you can find yourself towing too much mass.
and stay in the allotted lanes for towing, it will stop your speed from getting too excessive
kiwi_outdoors is online now   Reply With Quote
Times are GMT -7.   It's 10:18 PM.
