01-06-2013, 07:25 AM
#14101 | |
Oddometer: 325
Are you saying "sumps like crazy" means "it pulls the oil out of the sump and into the frame like crazy"? TDC
I wear a helmet in public! Yeah! GS850GLX DR350SE |
01-06-2013, 08:21 AM
#14102 |
mc caregiver
Oddometer: 2,588
01-06-2013, 08:32 AM
#14103 |
Love those blue pipes
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,090
Yes, it will - but I think the person who brought that up is being overly pedantic. You will NEVER be able to tell the difference in where the slide lifts from shimming the spring .020". However, the difference in fueling from having the needle .020" higher will be marked.
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100 January 2010 New Zealand South Island ride Summer 2009 UK to Alps ride Summer 2008 UK End-to-End ride |
01-06-2013, 08:55 AM
#14104 |
Oddometer: 226
If anyone needs any bits and pieces, I have an entire 91 DR350S that I'm parting out.
Buncha dirt bikes with license plates. |
01-06-2013, 10:33 AM
#14105 | |||||
Oddometer: 1,110
Warm the engine up. Set the CO to between 3 and 5%. Check and or reset the idle speed. Recheck the CO%. If you do not have access to a gas analyzer, lower the idle speed a little bit (this increases the sensitivity, so you can more easily notice the effects of your adjustment). Adjust the fuel screw in until you notice it is running worse, then adjust out to the point where the idle is the strongest, and then no more than 1/8-1/4 turn further. Adjust the idle speed back to normal. Quote:
Regards, Derek |
01-06-2013, 04:10 PM
#14106 | |
Single Track Noob
Oddometer: 1,458
Ride for 15 minutes then check it and it will read normally if not a bit high. Typos and nonsensical words courtesy of fat fingers on a make believe keyboard.
Brian Mine: 07 DL650 ABS, 99 DR350SEx, 05 Montesa 4RT Her's: 02 KL250 Super Sherpa ![]() www.PhotoSupportNW.com |
01-06-2013, 04:16 PM
#14107 |
Oddometer: 92
markk900: yes we have determined the carb is stock. I also believe we have come to the conclusion that trimming the spring and fiddling with the stock needle is not necessary. The bike is running well. What I am trying to accomplish (and seem to be close) is to get feedback from others who have tried mods to this carb to see what works. Or feedback from people who are way more knowledgeable than I but do not necessarily have this carb. A good running bike is subjective to the user (to a certain point where there is an obvious problem) and what works for someone may not for another. Lastly, my wording was incorrect i meant to say "spring for the TM33 carb" as is in take the plunge and shell out the money for that carb. But it does sound like making spring changes to the TM33 carb as if that was the one in question.
With regards to the other comments: I believe that making no changes to the BST33 that I have will be the best solution at this point. Thank you for motolab for the pilot screw adjustment procedure. Once I fiddle with that I hope to have this carb running a bit better than before. I have access to a gas meter, but its not intended to read exhaust gas (it does read CO among 4 other gases) If i can get away with your "by touch" method I will stick with that. I will also check the holes more closely to see what is going on in there. Adjustable needle is a viable option and I will seriously consider it after testing the stock settings with the pilot screw properly adjusted. Thanks again to all who weighed in If there are more comments I will love to hear them. I will report back when I receive the parts and get the intake/fuel system back together and the bike running.
2008 Suzuki DL650 V-Strom (flat black) 1982 Moto Guzzi v50 Monza 1999 Suzuki DR350X |
01-06-2013, 10:29 PM
#14108 | |
Oddometer: 1,110
Regards, Derek |
01-07-2013, 03:15 PM
#14109 |
www.nouturns.tv
Oddometer: 68
Im looking for some lowering links if anyone has some for sale!
Just bought another 350 and need it lower for the misses |
01-07-2013, 03:36 PM
#14110 |
Oddometer: 92
motolab, thank you very much for the detailed description. I hope that method will get me close enough to enjoy riding the bike again after this little winter refresh. I will be extra careful when testing the throttle at different positions, and of course I would not hold anyone responsible for something I am choosing to try myself.
![]() Thanks again to all the DR350 folks for all your help! This forum is my absolute favorite, too bad I would never have enough time to read through all there is on here, but Google search is my friend.
01-07-2013, 07:28 PM
#14111 |
wandering the desert
Oddometer: 680
Just got this in from fleabay:
http://www.ebay.com/itm/AMR-RACING-C...7f6deb&vxp=mtr Maybe tomorrow I'll have time to swap it out with the stock one to see if that helps with the backfiring. I got the bike fired up two days ago (it was 19*F) and it seemed to idle alright, but still backfired like a SOB when you gave it throttle. I did determine that the backfiring is coming from the tail pipe, and having the choke on seemed to help. Who knows if this new coil will help, if it doesn't at least I have a spare coil now.
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood. Border Road 100 Border Road Rally Raid '13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
01-07-2013, 09:05 PM
#14112 |
Oddometer: 1,012
Backfiring, and choke helps? Sounds like she's running lean
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution. |
01-08-2013, 03:41 AM
#14113 |
Squiddly slow
Oddometer: 878
01-08-2013, 04:20 AM
#14114 | |
Oddometer: 581
The old Guzzis I work on use a Dell'Orto carburetor (VHB 29) that has a choke. Only, it isn't a choke at all. A choke richens the mixture by reducing the air intake. The Dell'Orto system acts as an enricher, adding fuel instead of reducing air. The end result is the same, but it is very helpful to know what is happening in case something starts to act funny. Regards, Gregory Bender |
01-08-2013, 04:21 AM
#14115 | |
Oddometer: 581
