Old 01-05-2013, 03:18 PM   #1
KTMSAM OP
KTMSAM's Avatar
Oddometer: 108
Question 990 ADV aux power supply
I noticed in the fuse box that the Adventures have the acc 1 & 2 circuits just as my '08 Super Duke did. My question is, where are the wires for it? I know the Super Dukes had them located behind the headlight, but I wanted to ask before I take the bike apart and find that they aren't there. I have a 2012 Adventure if that makes a difference.
"KTM? Who makes that?"
KTMSAM is offline   Reply With Quote
Old 01-05-2013, 05:38 PM   #2
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 918
Send a message via Skype™ to ciedema
Same - behind the headlight.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
No Four Wheel Drives, No Fixers and No Fricken Whingers
ciedema is offline   Reply With Quote
Old 01-05-2013, 05:44 PM   #3
motokeith
Oddometer: 11
I just went through this exercise with my 2012 yesterday while installing heated grips. I found the two acc connections behind the headlight on the left side. The acc1 connection is actually powering the factory dash-mounted cigarette plug. The acc2 connection was folded up and stuffed back into the space behind the headlight. I found it by following the acc1 wire backwards from the cigarette plug.
motokeith is offline   Reply With Quote
Old 01-05-2013, 05:46 PM   #4
KTMSAM OP
KTMSAM's Avatar
Oddometer: 108
perfect, thanks ciedema!
Old 01-05-2013, 05:52 PM   #5
KTMSAM OP
KTMSAM's Avatar
Oddometer: 108
Excellent, thanks for the help. I would assume that the acc1 is constant then (since the factory cig lighter is always powered) and 2 will be remote with the ignition... I will test it before I wire up my accessories.
Old 01-06-2013, 09:38 AM   #6
groovyspuds
groovyspuds's Avatar
Oddometer: 22
That is correct.
groovyspuds is offline   Reply With Quote
Times are GMT -7.   It's 08:26 PM.
