Old 01-06-2013, 08:53 AM   #51211
Dooga
Dooga's Avatar
Oddometer: 192
Send a message via Skype™ to Dooga
Originally Posted by Brown Falcon View Post
Fork brace on the way! Thanks Marko!
Which fork brace did you go with?
My 2002 Honda XR650L is a lemon bought off Craigslist
(She's my lemon and I love her and her name is Gerris)
Dooga is online now   Reply With Quote
Old 01-06-2013, 08:54 AM   #51212
bwalsh
Oddometer: 7,730
Originally Posted by RZRob View Post
I'd sold my 4 extra Diamond Club seats to a very famous fashion designer who is also a car and motorcycle buff and wealthy beyond our wildest dreams. The guy has 2 Enzos, a Mercedes SLR McClaren and an SLS and get this, 4 Desmosedicis.
No XRL?
Pfff. Amateur...
2004 XR650L
1992 Specialized Stump Jumper FS
NWVA TAG
NWVA TAG MAP
RTE THREAD & IN LIST
bwalsh is offline   Reply With Quote
Old 01-06-2013, 08:56 AM   #51213
bwalsh
Oddometer: 7,730
RSW Fork Brace installed yesterday evening. First impressions... awesome!
I've got one on my bike. It came on my 04 so I never had anything to compare with...until I got the 08, with no brace.
I just installed it on the 08 a week ago. They do make a difference.
Hey Dooga, do you ever post in the regional's section? Lots of ADVer's in NOVA and Virginia in general. I'll be posting a RTE soon so check the RTE thread in my sig line.
2004 XR650L
NWVA TAG
NWVA TAG MAP
bwalsh screwed with this post 01-06-2013 at 09:01 AM
Old 01-06-2013, 08:58 AM   #51214
Spud Rider
Spud Rider's Avatar
Oddometer: 2,955
Originally Posted by Gone14s View Post
I bought my 95 XR650L with only 7900 miles on her. The bike is bone stock. Needless to say I have been doing quite a few mods that have read here on this thread.
I ride most of the time just under 4000 feet and venture to 9000 feet every so often. Most of the rides consist of hard or soft dirt tree line riding. I do live at sea level.
I have done research here in the threads about the carb mod and jetting for the exhaust. I have a FMF Q4 coming and a set of 55-155 jets coming for the bike.
I plan on drilling the slider holes out to 5/32 holes.
Question:
Do I need to shim the needle with the larger jets or try it with out.??
Thanks Kurt
I live at 4,600 feet above sea level, and ride to 10,400 feet above sea level. I enlarged the holes in the carburetor slider and shimmed the jet needle; my bike runs great.
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil
Spud Rider is online now   Reply With Quote
Old 01-06-2013, 09:04 AM   #51215
Gone14s
Gone14s's Avatar
Oddometer: 86
Spud
Thanks Spud, most what I have read on the mod's comes from you. I did get the shim kit at the same place I bought the jets. I have done the carb. mods the the KLR650 also and the carb. mod for this bike seems about the same.
Kurt
Def. of man:
We spend 9 months trying to get out, and the rest of our lives trying to get back in.
http://s1085.photobucket.com/albums/...900%20elefant/
Gone14s is offline   Reply With Quote
Old 01-06-2013, 09:35 AM   #51216
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 726
Originally Posted by pngaudioguy View Post
Good info to know from both of you - thanks. I guess my concern with rivets is that this is the older style Supertrapp with exposed discs, not the newer internal discs and turndown endcap. The bolts are about 3" long, and hold the discs and flat endcap onto the muffler, so I don't think I'll be able to use normal rivets for it. I'll get the bolts cut off, clean it out and see what looks like it'll be most sturdy. Going to be ordering from McMaster anyway, since I haven't found anywhere that sells stuff like that in Belgium, so any connector is fair game.
See this video...
Your muffler doesn't have the bolts that hold the core in, the muffler inlet clamp holds it together.
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru is offline   Reply With Quote
Old 01-06-2013, 09:35 AM   #51217
mcma111
mcma111's Avatar
Oddometer: 8,011
Originally Posted by tractor4play View Post
the clutch casing from the xr and xl 600 will not fit on my rfvc 650
(im doing the kickstart upgrade)
as its a 1997ish model with the large oil pump.
has anybody solved this problem rather than swapping in the smaller pump?
i would like to keep the high output pump as the motor will be big bored and fat cam etc.
its a 1997 slr 650 bottom end with twin carb head.
What year XR cover do you have? IIRC the 95 and later XR600 has the bigger oil pump so the cover from one of those should work.
If you can't find a cover just have your XRL cover machined for the kicker shaft. Buy the XR shaft seal.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
mcma111 screwed with this post 01-06-2013 at 10:04 AM
Old 01-06-2013, 09:44 AM   #51218
smokeeater495
smokeeater495's Avatar
Oddometer: 503
Originally Posted by mendoteach View Post
Shim it. The richer mid range it provides contributes a lot to the improved ridability of the bike. Use (I think, Spud may correct me) a #4 washer.
When I shimmed mine I just went to the hardware store and got one that was the correct size diameter. I wasn't completely satisfied with initial set-up due to 10% ethanol here in Indiana. Rejetted up one size and also checked thickness of washer with micrometer. Dave's Mods calls for 0.020-0.030" thickness. The washer was 0.018. So I went back to hardware with my mic. The washers were all over the board. Finally found one 0.028". The bike starts, idles, and runs better.
Harley, been there done that. Don't want to be a pirate.
smokeeater495 is offline   Reply With Quote
Old 01-06-2013, 10:28 AM   #51219
tractor4play
Oddometer: 83
im not sure what year the xr clutch cover is and getting machine work done around here is difficult.
although i like what your saying about the 1995 and on xr 600.
that solution sounds too easy surely theres a catch.
thanks for the quick reply.
tractor4play is offline   Reply With Quote
Old 01-06-2013, 10:56 AM   #51220
Gone14s
Gone14s's Avatar
Oddometer: 86
Thanks, I'll bee sure to mic the ones I got in the kit to get the right thickness..........
Kurt
Def. of man:
Old 01-06-2013, 11:16 AM   #51221
AZ TOM
Oddometer: 2,360
Originally Posted by beechum1 View Post
yeah they did. Marko had one....
Rekluse never made one. Marko's was a Revloc he got from me.
AZ TOM is offline   Reply With Quote
Old 01-06-2013, 12:37 PM   #51222
Barron
M0DAH0LIC
Barron's Avatar
Oddometer: 1,946
and Revloc doesn't make them any more. They have moved on to bigger and better things as their website says...
-Barron
1996 XR650L with a couple mods
If everyone brewed beer there would be no war.
Barron is offline   Reply With Quote
Old 01-06-2013, 01:27 PM   #51223
Brown Falcon
Mossy-Back
Brown Falcon's Avatar
Oddometer: 714
It's a RSW brace. It seems to be pretty beefy, and the machine work looks nice. Install was easy as well. I made sure to have the front end off the ground, loosen the axle hold down clamp, and used blue loc-tite on the brace bolts.
Evan
Ooh-Rah! Once a Marine, always a Marine!
'93 XR650L (Xena)
Brown Falcon is offline   Reply With Quote
Old 01-06-2013, 01:43 PM   #51224
Spud Rider
Spud Rider's Avatar
Oddometer: 2,955
...Dave's Mods calls for 0.020-0.030" thickness. The washer was 0.018. So I went back to hardware with my mic. The washers were all over the board. Finally found one 0.028". The bike starts, idles, and runs better.
Kurt
You can get the correct shims for the carburetor at Lowes. Buy a 12-pack of Arendelas #4S washers, part #491431. These washers are the correct diameter as well as the correct thickness. The 12-pack only costs $1.
Spud
Old 01-06-2013, 02:06 PM   #51225
AZ TOM
Oddometer: 2,360
-Barron
Revloc Austrailia, say's they have them. Hope Revloc in Denver moved on to better things at least!
Times are GMT -7.   It's 02:56 AM.
