Old 01-06-2013, 12:20 PM   #1
Dano650 OP
Oddometer: 4
KLR 650 new counter sprocket installed, and a question
Hey new here, newish to the DS world
I have a 2006 KLR 650 with ~19k miles. I installed a new chain and sprocket set this weekend because the old ones were beat, probably stock. Before I put the new ones on, I could hear the front sprocket when riding and figured it was just because it was old. With the new one, I hear the same. Is it normal? I attempted to post a video on youtube with the sound:
http://www.youtube.com/watch?v=Ssh0uy0jL04
Just me spinning the rear wheal with my hand. Obviously under power, it gets faster as the motor gets faster
Dan
Dano650 is offline   Reply With Quote
Old 01-06-2013, 01:14 PM   #2
Dan in Grand Rapids
Dan in Grand Rapids's Avatar
Oddometer: 58
How much play is there in the chain? I had a similar noise and it was from the chain being too tight.
Dan in Grand Rapids is offline   Reply With Quote
Old 01-06-2013, 01:37 PM   #3
Dano650 OP
Oddometer: 4
Its adjusted according to Kawasaki specs, theres play but its supposed to be that way without a rider
Old 01-06-2013, 04:39 PM   #4
rowie
Oddometer: 239
Can't help you with the noise, but your joining link clip is on the wrong way. The round end faces the direction of travel. Think of a fish swimming up stream.
Rowie's DR650RS Rebuild
rowie is offline   Reply With Quote
Old 01-06-2013, 04:43 PM   #5
Dano650 OP
Oddometer: 4
I told myself that today after messing around with the noise issue. Its fixed since this video was taken
Old 01-06-2013, 05:10 PM   #6
Billy Beer
Billy Beer's Avatar
Oddometer: 22
normal??
Dano
Mine has made the same noise since new. Through two chains and sprocket changes the clicking noise has persisted. Nothing to worry about i think. Just be sure the wheel is aligned so the chain is running straight.
B
Billy Beer is offline   Reply With Quote
Old 01-06-2013, 05:20 PM   #7
Dano650 OP
Oddometer: 4
Originally Posted by Billy Beer View Post
Dano
B
Good to hear. Pretty sure I got the wheel aligned pretty good this time. At least I hope ;)
Old 01-07-2013, 08:44 AM   #8
ADW
'tard bike restos
ADW's Avatar
Oddometer: 575
Agreed, noise sounds normal to me. Regarding chain adjustment, a little too loose is WAY better than a little too tight! I've done the "remove the shock and move the swingarm until the countershaft aligns with the rear axle, set chain tension" thing. Turns out that with the bike on the sidestand, adjusting it so the chain just BARELY can touch the black rubber swingarm chain protector as you push up from the bottom is about right. Any tighter than that and you risk stressing the countershaft bearing and/or seal. Again, too LOOSE is not gonna hurt anything, but too tight sure will!
08 KLR, 06 KLR w/Sputnik sidecar, 09 WR250R, 72 CB350F
ADW is offline   Reply With Quote
Times are GMT -7.   It's 04:36 PM.
