01-06-2013, 03:14 PM
#8371 |
Oddometer: 48
[QUOTE=GlennF33;20403540As I said, do one thing at a time.[/QUOTE]
I was hoping to avoid taking the carb apart more than once to clean it and change jets but your advice is wise given the curious lack of consensus on what works best regarding jetting for altitude. There is either a lot of variation between standard carb specs or variation between owners on what they feel is a good running motor. Didn't get to it this weekend anyway, hands numb from cold working on my truck in the driveway. Thanks again |
01-06-2013, 03:20 PM
#8372 |
Oddometer: 4,663
Took the XT out for about a 70 mile loop on back roads in Litchfield Cty CT. About 30deg F., but thanks to Mr.gerbings, very manageable. Just had to remember to pull the plug about 5 miles before I stopped to recharge the battery.
Great to be out, and the XT was running wonderfully. I think it loves the cold weather.
'01 Kawasaki W650 '05 Yamaha XT225 |
01-06-2013, 04:18 PM
#8373 | |
deserteagle56
Oddometer: 30
01-06-2013, 04:54 PM
#8374 | |
Oddometer: 48
Thanks! Is the rest of your bike stock or did you change/open up the intake and/or exhaust? I don't want a louder bike so I don't plan on changes to the snorkel/intake or exhaust. |
01-06-2013, 07:23 PM
#8375 |
deserteagle56
Oddometer: 30
Intake and exhaust completely stock. The older I get the more I can't stand noise. Quiet as the XT225 is, in the last couple years I pretty much always use foam earplugs when riding (and that's even with a Bell helmet that clamps tightly around my ears).
01-07-2013, 06:17 AM
#8376 |
Oddometer: 853
What is the charging output of an 01 225. I have gerbing gear that I use on my other bike that I didn't think it would work on the little bike. I see someone else here used it on the 225 and was curious what I could get away with.
01-07-2013, 09:42 AM
#8377 | |
Oddometer: 4,663
My current battery is new this season, and I figured I'd experiment. As I was approaching home yesterday I decided not to unplug. When I reached home, I turned it off, and then hit the start button. It turned over and started, but just barely. At that point I plugged it into a charger.
01-07-2013, 10:11 AM
#8378 |
All who wander r not lost
Oddometer: 1,982
Anyone looking for a XT250? Found this for sale locally...
For those of us not interested,... It has a very interesting mount for carrying extra fuel that some might be interested in copying for their bikes. http://sandiego.craigslist.org/nsd/mcy/3520717598.html
I've learned to give "impossible" the finger as I pass it by. The only way to get through life is to laugh your way through it! Day by day, nothing seems to change. But pretty soon, everything is different. |
01-07-2013, 01:45 PM
#8379 |
Oddometer: 853
first of all, thanks to speedo66 for the gerbings info. now for the age-old question of jetting... i bought a 130, 135, and 140 main jet that i plan on experimenting with. i don't mind modifying the snorkel but i do not want to modify the exhaust. so if someone has a suggestion as to what would work best with just snorkel removed.....let me know.. i saw comments on shimming the needle jet. i am familiar with shimming the needle but never heard of shimming the jet..so am i misinterpretting the way it was written or are we talking about shimming the needle? point me the right direction............thanks...
01-07-2013, 02:12 PM
#8380 | |
Oddometer: 1,982
01-07-2013, 04:22 PM
#8381 | |||
Dubious Adventurer
Oddometer: 560
![]() Quote:
![]() ![]() Have re-registered over xt225.com. Hopefully can start tearing her down this weekendQuote:
Lisa 2007 xt225; 2008 yamaha wr250, 2003 Suzuki SV650; tent space LisaS and shoein's Maine Adventures |
01-07-2013, 06:29 PM
#8382 |
Wackjob
Oddometer: 807
Anyone got a TTR230 or an XT with the rear brake conversion?
I'm not an XT dude, I'm a TW guy but we're saddled with the same crappy 110mm rear brake. I'm doing a 130mm rear brake conversion on a TW200. Don't stone me, but since there doesn't seem to be a TTR thread and a few of you may own both or have converted your XT to a TTR rear drum, I need a pic of a TTR rear brake backing plate.
More specifically I need an edge pic of the swingarm tab slot in the backing plate. Here's the TW: ![]() And here's one from an XT350, which is one of the few that shares the same brake shoe diameter and axle hole size. The bottom of the slot is too far out from the drum. The TTR is a candidate and I'm hoping its slot depth is at least somewhere between the two. If anyone can help me out with this I'd sure appreciate it:
Lizrdbrth screwed with this post 01-07-2013 at 06:46 PM |
01-07-2013, 07:05 PM
#8383 |
Oddometer: 243
Check post #8065, you may have done this already. I can confirm that with a few mods the ttr225 wheel will fit an xt225. If the hubs share the same parts numbers on the ttr230 and ttr225, and the xt225 and tw200 share the same exact rear hub, then indeed, you are in business. Just check the parts fiche on one of the mailorder places (Cheap Cycle Parts, etc.) for parts #'s. #8065 has a link to an earlier post that describes the process in more detail if they do indeed match.
Keep us in the loop. |
01-07-2013, 08:01 PM
#8384 | |
Wackjob
Oddometer: 807
The fiche are pretty funky line drawings. Not much detail, prolly because there isn't much need for it. Unfortunately your post doesn't include didn't a pic within the swingarm. I can't tell how far outboard the slot is in the brake plate. The TW rear brake drum is removable without unlacing the wheel and the larger 130mm TW front drum can be bolted to the rear hub with a couple of mods if the right 130mm backing plate can be sourced. Unfortunately the only TW's to ever wear 130mm rear brakes were Euro TW125's which were never sold here. Go figger. Yamaha puts the big brakes on the slow bike. Just like the way they treated you guys. They put the least effective rear brake on the street version. Anyway at least the brake shoes are common to both swaps. Don't wanna accumulate a bucketful of doorstops in the search for a backing plate if anyone has pics. Just need a quick visual. Lizrdbrth screwed with this post 01-07-2013 at 11:54 PM |
01-08-2013, 09:54 AM
#8385 |
Oddometer: 18
I am also interested in any information you find but I'm a little confused by your post.Are you changing the rear brake size without changing the hub?I bought a TTR225 hub because it has a bigger brake and is ten times thicker in most places-it's still a weak cast aluminum however.I know in advance that I need shorter spokes because the hub itself is larger and I'm getting new rims as well.You said something about the front fitting the rear which really confused me.Here is a link of someone who put a huge disc on the front of a a TW200 if that interests you. http://tw200forum.com/index.php?/top...mm-brake-disc/
