01-07-2013, 05:39 AM
#51256 | |
Must / takeit / easy
Location: Harrisonboiig; Shenandoah Valley riding wonderland
Oddometer: 4,393
![]() You know how thrilled I'd be to join you on a ride in Mexico. ![]()
Let's ride!!! ![]() - No offense, but there've been a lot of people over time who were just as sure, but got it wrong. - Una necedad, aunque la repitan millones de bocas, no deja de ser una necedad. |
01-07-2013, 05:44 AM
#51257 | |
Oddometer: 4,393
![]() At any rate, I'm sure it's as pretty as Bryce's, and look at what his is doing for him.
01-07-2013, 05:56 AM
#51258 | |
Oddometer: 4,393
I have a viable running '85 VF700S Sabre in my garage Probably the same stator, wow.
01-07-2013, 05:58 AM
#51259 | |||||
Crazy Diamond
Oddometer: 726
The following information is combined Tech form different threads and my own head...
This information can be used to build a wide ratio or close ratio gear box for all of your needs. The primary and final gear ratios only effect the effective overall ratio. They don't change the transmission ratios You'll need to split the cases for that. Stock gear ratios XL600R Primary Reduction 2.188 (70/32) 1st Gear '83-84 is 13/32 (2.46) 1st gear '85-87 is 13/31 (2.38) '85-'87 XR600R & XL600R 31/13 2.38 28/17 1.65 25/20 1.25 23/23 1.00 21/25 0.84 XR600R gear ratios Primary reduction 2.188 (70/32) Final reduction 3.429 (48/14) 1st: 2.385 (31/13) 2nd 1.647 (28/17) 3rd 1.250 (25/20) 4th 1.000 (23/23) 5th 0.840 (21/25) XR650L Gear ratios Primary Reduction: 2.029 (69/34) Final Reduction: 3.0 (45/15) 1st: 2.66 (32/12) 2nd: 1.647 (28/17) 3rd: 1.250 (25/20) 4th: 1.00 (23/23) 5th: 0.84 (21/25) NX650 US model Primary Reduction: 2.029 (69/34) Final Reduction: Varies 1st 2.66 (32/12) 2nd 1.75 (28/16) 3rd 1.25 (25/20) 4th 1.00 (23/23) 5th 0.84 (20/25) NX650 Euro & FMX650 gear ratios Primary Reduction: 2.029 (69/34) Final Reduction: Varies 1st 2.66 (32/12) 2nd 1.75 (28/16) 3rd 1.25 (25/20) 4th 1.00 (23/23) 5th 0.80 (20/25) GB500 31/13 2.38 28/18 1.55 24/20 1.20 23/23 1.00 21/24 0.875 XR650L Primary Reduction 2.029 (69/34) XR600R Primary Reduction 2.188 (70/32) XR600R HRC KIT Primary Reduction 2.029(69/34) XR 5th gear 21/25 NX 5th gear 20/25 Try some combo's on http://www.gearingcommander.com/ for a while. You can change the listed NX650 5th gear tooth count to the Euro spec. Quote:
This chart will show how the ratios compare with other bikes. Quote:
Post up any tech or real world reports you have.
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru screwed with this post 01-07-2013 at 06:07 AM |
01-07-2013, 06:36 AM
#51260 | |
Oddometer: 280
I like this bike though and i am deff on function, i have a clear tank!
i know my clear tank is ugly! |
01-07-2013, 07:27 AM
#51261 |
Oddometer: 86
Hand guards
I have seen a post that most hand guards will not let the clutch and brake levers fit in side of them. This due to the levers being to long. Most folks are cutting the levers down.
I found these guards on ebay and they work really well and the levers fit inside the guards: http://www.ebay.com/itm/360554981847...847%26_rdc%3D1 They are a pretty good item at a very good price. I put a set on my bike. Just thought I would pass it along for the help you folks have given me. Kurt
Def. of man: We spend 9 months trying to get out, and the rest of our lives trying to get back in. http://s1085.photobucket.com/albums/...900%20elefant/ |
01-07-2013, 07:28 AM
#51262 |
Oddometer: 4,393
Excellent info, Sir!
I would have liked to get my hands on the taller fifth gear when I had my tranny apart. I'm fine with the stock first-second-third spacing. Ideally for me, a dual sport bike will have a wide range with a good low first, a good high top, and increasingly large gaps as the gears get higher. Of course we all agree that the XRL would greatly benefit from a sixth gear. Let's try 18/26 (0.69)
01-07-2013, 07:32 AM
#51263 | |
Oddometer: 4,393
01-07-2013, 07:35 AM
#51264 |
Lost in Bama
Oddometer: 62
I have Moose hand guards on mine, no problem with the stock levers.
01-07-2013, 07:40 AM
#51265 |
I did not, when?
01-07-2013, 07:43 AM
#51266 | |
Crazy Diamond
Oddometer: 726
NX 5th gears are hard to get. If I could afford one I would buy it. You have to get it from overseas. I think Barron might be able to hook you up if i recall correctly. Maybe PM him. I think he is over in Japan now.I think he has a post or two about it in this thread. Probably in the 400 posts or so... ![]()
01-07-2013, 07:52 AM
#51267 | |
Crazy Diamond
Oddometer: 726
It would be perfect with the NX 2nd and 5th gears. Combine that with a built CW engine and some stock 15/45 gears for a 120mph beast. ![]()
01-07-2013, 09:39 AM
#51268 | |
Oddometer: 3,443
2009 XR650L Steve |
01-07-2013, 09:45 AM
#51269 |
Oddometer: 3,443
The guy I rode with could haul some major mail as long as it held together. He had 2 or three spare bikes just for parts.
2009 XR650L Steve |
01-07-2013, 10:16 AM
#51270 | |
One day closer...
Oddometer: 1,187
2007 Honda XR650L, 2004 Honda XR250R Dirt Roads within a 100 mile radius of Austin, TX *** The views or comments I express on this site and/or on any other site/forum/social media are strictly my own and do not reflect any past, current or future employer and/or any organization. They are solely my own personal opinions.*** |
