Old 01-04-2013, 06:23 PM   #106
pvangel OP
Team AARP
Oddometer: 1,466
I think this will fit towards the center of the door and the handle protrudes past the lock bar...I think...
(QUOTE=tommu56;20397719]
5 inch back set would move the knob back another inch or so too away from the bar.
they even make longer ones if needed.
16-132-US3[/QUOTE]
pvangel is offline   Reply With Quote
Old 01-05-2013, 06:05 AM   #107
keyzard
Falls over a lot....
keyzard's Avatar
Oddometer: 95
Send a message via AIM to keyzard Send a message via MSN to keyzard
16-132-US3
FWIW....I used a screendoor handle/lock on mine, the lock bar clears it and it was a breeze to install. When I need real security I use the lock bar.
http://www.homedepot.com/h_d1/N-5yc1...1#.UOgygeSaVVo
My enthusiasm for dirt is eclipsed only by my lack of ability......
2008 Suzuki C109 (Faster than something this big should be)
2002 Yamaha YZ250F (Falls over a lot)
2011 Suzuki DRZ400S (My new favorite)
2006 Suzuki DL650 (My wife's, but I "borrow" it a lot!!)
keyzard is offline   Reply With Quote
Old 01-05-2013, 08:25 AM   #108
pvangel OP
Team AARP
Oddometer: 1,466
Great idea, I'm going to try it! The other setup would require quite alot of fab work and your idea looks much easier.
Just the kind of input I have been looking for>
Old 01-05-2013, 02:07 PM   #109
pvangel OP
Team AARP
Oddometer: 1,466
My E-track pieces today,
Should fit flush to the tile,
So I had to figure out how the bikes would fit, 5 work on paper but I think 4 is it.
I think the angle setup was the best but have to check one more time,the insulation is my base cabinet mock up.
I have to see still what works best...
Old 01-05-2013, 02:20 PM   #110
pvangel OP
Team AARP
Oddometer: 1,466
I cut out plywood backer pieces for the roof vents.
I then glued them up to the ceiling for a guide to cut the hole and then will leave in place to secure the vent to the roof.
Hopefully will cut them in tomorrow.
Old 01-06-2013, 02:02 PM   #111
pvangel OP
Team AARP
Oddometer: 1,466
It was a beautiful day in NY for January, clear skies and 45deg. I'll take it because I got a ton done today.
It's always scary to cut a hole in a perfectly good roof, but I measured twice (more like 5 times) and cut once.
Lots of GE Silicone,should be water tight.
DONE! Black one is a regular vent and the white one is a fantastic fan.
I'm glad I'm past that.
Old 01-06-2013, 02:23 PM   #112
pvangel OP
Team AARP
Oddometer: 1,466
Moved on to windows, have to make hay when the suns shining.
I cut out temporary plywood templates out of the 14"x14" roof vent cutouts so I could mark the holes and then use as spacer blocks,
Had to use duct tape to protect the skin because I was out of blue tape...of course all the glue stuck to the metal when I pulled it off so I had to clean before setting the window.
In!
They are set to go between the base and upper cabinets.
Looks good!
Still waiting on the big window and ripped out most of the wiring I did because I am making the base cabinet smaller so i have to re do it plus I wasn't happy with what I had done.
Old 01-07-2013, 02:48 PM   #113
pvangel OP
Team AARP
Oddometer: 1,466
It's a joy to get home and see a package at the front door!
The picture/escape window showed up today,(not sure who the old guy is in the reflection though?)
Of course the flange got bent, I assume in shipping.
Some pliers and an old sock so I didn't scratch it and good as new.(wait it was new?)
The garage is overflowing, have to start doing more but between work and winter...it ain't easy!
Old 01-08-2013, 01:55 AM   #114
Xmoto
Keep On Keeping On!
Xmoto's Avatar
Oddometer: 1,856
Looks great! Nice job.
“Do not be afraid; only believe.”
Xmoto is offline   Reply With Quote
Old 01-08-2013, 04:12 PM   #115
pvangel OP
Team AARP
Oddometer: 1,466
Thanks X ! It's a labor of love, more updates coming soon....
Old 01-10-2013, 08:33 AM   #116
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 1,825
Send a message via Skype™ to dirtydeeds
I'm probably going to start a little build myself.
Was there a supplier that specializes in cabinets/tables for mobile applications?
Where did you find the folding table?
I figure I can probably get stuff from service vans, hopefully used. And a few other things from wrecked RVs.
I'll start a list of fine ideas to incorporate into a build, too.
I'll slowly be updating the Hino thread.
http://www.advrider.com/forums/showthread.php?t=843673
dirtydeeds is offline   Reply With Quote
Old 01-10-2013, 11:51 AM   #117
SnowMule
SnowMule's Avatar
Oddometer: 16,052
Big thread on my snowmobile trailer -> snowmobile camper conversion here:
http://backcountryrebels.com/showthread.php?t=16674
Big things were insulation, rewiring (12v and adding 120v), and the furnace install.
Cleaned/undercoated the steel:
Pulled out all the old wiring, installed new wiring, and insulated the walls:
Box on the front for the regulator/hookup
Insulated the ceiling
25k BTU forced-air furnace
Battery... removable so I can keep it on a tender in the garage instead of leaving it in the trailer and freezing. LPG/CO detector too.
Hitch-cam
Trailer-cam
It does well.
Spewer of the poignant non sequitur
SnowMule is offline   Reply With Quote
Old 01-10-2013, 05:02 PM   #118
pvangel OP
Team AARP
Oddometer: 1,466
^^ cool rig^^
Old 01-10-2013, 05:08 PM   #119
pvangel OP
Team AARP
Oddometer: 1,466
Table was on EBAY, Bosspowersports was the seller, they have the best prices on cabinets that I have seen anywhere as well. I was going to use them but they didn't fit my plan, then had someone in Ct. build them but he said 6 weeks so I think I am going to go with HomeDepot cabinets that i will custamize to fit my needs.
Old 01-12-2013, 04:15 PM   #120
pvangel OP
Team AARP
Oddometer: 1,466
So even though I thought I would be home all day to work on the trailer I had to actually "work" at my job till 1...I'm not complaining just stating the facts.
Did the window first, 36x22 egress window, layed it out inside and out,
I measured twice and cut once,
Shoulda measured 3 times because the opening was a little big, It is in and ok but not real happy with my install.....
Window is alright but would have preferred a little more meat behind the flange and the screws I got were fine thread and kept stripping as I installed them.
Thread Tools
Times are GMT -7.   It's 09:15 PM.
