01-08-2013, 06:41 AM
#26851 | |
I just wander.....
Oddometer: 1,287
My answer is the first one. To tell if a specific tubeset is 531, cut it apart and destructively test the tubes..... You can figure out if it is columbus by show it to an old school builder. As stated above. The pictures were to help if it was a production frame, we could figure it out.
2007 Factory Husaberg 380FE 2007 Montesa 4rt 1984 Husqvarna 500AE mud screwed with this post 01-08-2013 at 07:39 AM |
01-08-2013, 06:48 AM
#26852 | |
Bend it Bend it
Oddometer: 5,435
Has anyone here actually seen bare 531DB main tubes?? overlandr screwed with this post 01-08-2013 at 06:54 AM |
01-08-2013, 07:48 AM
#26853 | |
I just wander.....
Oddometer: 1,287
I will clarify. If it is a true production touring frame (cantilevers, rack mounts, loooong chainstays) from the eighties, there are not that many manufactures, they are quite distinctive. With a few (if they are the right ones) pictures you can figure out who built it by looking at the dropouts, BB, serial number, etc. If you have a blank frame with no stickers, generic dropouts, hand stamped serial numbers, there is nothing (or very little). And with that. I am done.
2007 Factory Husaberg 380FE 2007 Montesa 4rt 1984 Husqvarna 500AE |
01-08-2013, 12:38 PM
#26854 |
Wandering Moran
Oddometer: 2,030
Thanks Gwen!
"Hey I've never seen the sun come up in the west!?!" - Fozzie Bear |
01-08-2013, 12:41 PM
#26855 |
That's MR. Toothless
Oddometer: 25,658
If I had a running DS bike, I'd be PMing Shogs for the other set of bags. Looks like with minor work, they'd make great softbags for DS bikes.
Alas, the Husky doesn't look to be in running order any time soon, so whomever can use those bags should grab em M
There. I've moved back to VA. Can you PLEASE change the weather?! |
01-09-2013, 12:47 AM
#26856 | |
Bend it Bend it
Oddometer: 5,435
To others, reconfirm my interest is restricted to the brand and type of tubing used in the frame and nothing else. I want to keep it so destruction is not an option. I'm aware of the internal 'rifling' on Columbus SLX tubing and am hoping that there is some other perhaps similar method of determining whether I have 531 or not. To my untrained eye, it looks to be made of lower grade tubing.
overlandr screwed with this post 01-09-2013 at 01:02 AM |
01-09-2013, 06:41 AM
#26857 |
Kilted Terror
Location: I've narrowed it down to 'earth'. Or 'Baltimore'.
Oddometer: 1,757
Low 60's today? HEWW YEH, I'll take it! Time trial training starts today! Thank god I get off work at 3pm everyday.
ESCAAAAPE..FROMMMM...BALTIMOOOOORE Dynamick & I are raising money for the Children's Foundation. Please give if you feel so inclined! 2001 Kawasaki Concours |
01-09-2013, 09:25 AM
#26858 | |
part-time wanderer
Oddometer: 1,490
just a guy... '02 GS Adv |
01-09-2013, 02:40 PM
#26859 | |
I just wander.....
Oddometer: 1,287
If that is a picture of the bikes actual BB, it doesn't say a whole lot. I have seen that BB on Miyata's, Specialized's, Univega's and a couple of others. It is a pretty standard piece. It DOES NOT mean it is a low quality frame, nor does it point to a good one either. My Miyata 1000 has that BB and it is a top notch frame, as does the Specialized Expedition, also a top notch frame. On the other side the Univega specialissima use it as well, and it is more of a standard frame, still pretty good though. None of these frames used 531. Sorry if that is vague. I will look at it some more and see if anything catches my eye.
01-09-2013, 03:27 PM
#26860 |
I just wander.....
Oddometer: 1,287
Jack Taylor also used a similar BB, they thinned (filed the edges) them out though. They used 531.
01-09-2013, 06:10 PM
#26861 | |
Bend it Bend it
Oddometer: 5,435
http://i.ebayimg.com/00/s/MTIwMFgxNj...GYt!~~60_3.JPG http://i.ebayimg.com/00/s/MTIwMFgxNj...eYl!~~60_3.JPG http://i.ebayimg.com/00/s/MTIwMFgxNj...Eq)Q~~60_3.JPG http://i.ebayimg.com/00/s/MTIwMFgxNj...EsW!~~60_3.JPG Perhaps another option is to carefully strip the paint off and hope that the old stickers/transfers are still there? I gather the seatpost diameter would also help clarify. I have a vernier caliper somewhere. overlandr screwed with this post 01-10-2013 at 02:37 AM |
01-09-2013, 07:09 PM
#26862 | |
I just wander.....
Oddometer: 1,287
Pressed (stamped) lugs are not necessarily a sign of a "bad" frame, it is the lack of finishing that is the big pointer. The lug thickness is constant, if a frame is a quality frame the lugs would have a filed taper as the get closer to the tube. The edges would also be softer yet more sharp as well... There are other things that are covered by the paint that would tell. The "shoreline" for one, it is the junction between the tube and the lug. If it is sharp, it is of good quality. not so sharp, lesser quality.... It is still a lugged steel frame. Hope this helps, sorry it is not more exciting.
01-09-2013, 07:25 PM
#26863 |
Oddometer: 25,658
My new Edge 500 came in today. So far, I like the computer, but Garmin Connect is being a PITA.
Ride tonite took longer than normal 'cause there were 3 flats. None of em mine. We only went the short route. I wanted to go round the whole loop, but... So we set out at what felt like arctic temps but were really normal for this time of year. Dressed for normal for this time of year. Soon as we got up the first hill, it got warmer. Got colder again down the hill, then REALLY warm at the top of the 2nd hill. Completely back-asswards from the way it normally goes. Reminded me of riding in Sandy Eggo with the thermocline and all. Only 3 of us tonite. WE had fun. IDK about all the rest that are *supposed* to show.M
#26864 |
Reformed Kneedragger
Oddometer: 4,383
Good gosh, this has turned into a turd polishing thread.
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides "A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad |
01-09-2013, 07:36 PM
#26865 |
I just wander.....
Oddometer: 1,287
Not so much....
It is a legitimate inquiry.
| Thread Tools | |
