Old 01-07-2013, 08:45 PM   #6691
crobox
crobox's Avatar
Oddometer: 324
Originally Posted by Schrauberklaus View Post
my Tank is selfmade with the original bottom part of the XL Tank
Klaus- I read this post a few weeks ago and it stuck in my head. I had to search to find it again....
I'm interested in this tank that you made with the bottom of a stock XL tank. (That's a really good idea!)
Do you have pictures of it? I would love to see.
Thanks,
Christian
Current Bikes: 2006 KTM 950 ADV S, 2002 XR650L, 1988 Hondasuki KLNX250R
Previous Bikes: 1986 Honda XL600R,Honda XL250R (2 of them), Honda XL600R, Kawasaki KLR600, Honda Nighthawk, BMW K1100LT, BMW R100GS, BMW R60/6, BMW K75, Husqvarna 430XC
Click HERE for my Cummins 4BT International Scout build thread www.christianristow.com
crobox is offline   Reply With Quote
Old 01-07-2013, 09:09 PM   #6692
12120
Indenturedx5
12120's Avatar
Oddometer: 487
Got parts
RIcky stator is here, coil is her, new gasket for stator cover, now I just need some time. I would be nice if it wasn't raining sideways to. Anybody know if CR pegs will fit on the XL? I believe they are wider.
Chris
Sorry about your luck Pete. I think you outta just pull the carbs off and totally take apart and clean. Same goes for the fuel line/tank screen and tank. I you had that much crap in the carbs the need complete tear down. I would think. I hate the little mystery problems.
If you find yourself in a fair fight, your tactics are wrong.
'83 XL 600r
12120 screwed with this post 01-07-2013 at 09:42 PM
12120 is offline   Reply With Quote
Old 01-08-2013, 02:03 PM   #6693
Stretchah
Oddometer: 123
After my post regarding the fork upgrades, I just want to clarify a few things i've noticed that seem a little strange, Firstly am I right in thinking that standard xl600 forks are 39mm to 1985 and 41mm after?.
I was in the garage earlier and thought I'd have a closer look at mine and I noticed the tops are about 1 inch above the top yoke - is this normal for them to be set that way or are they normally flush with the top of the yoke?
I then noticed that they look like they've been machined from half way between the 2 yokes to the tops
So, I measured them and they are 43mm all the way up to where it looks machined and then 41mm. And from what Carter said the other day I am guessing a european top yoke has been used as its 41mm and has the ignition holder and screen/light holder brackets in the normal place.
Found a part no. KA4-831 on a little blue sticker on the right slider and have done a quick search and they seem to be coming up as from a CR250R or CR500R from 85-87 intrigued as to whether the machining is original or an alteration - most forks I've seen are normally the same diameter all the way up...
Heres a pic of the whole forks in case it helps... At the moment I'm thinking someone has done me a massive favour and may have already upgraded my forks
Let me know what you think? it may just be that I've misinterpreted what you guys have said and I've read and this is all normal
____________________
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Stretchah screwed with this post 01-08-2013 at 02:27 PM
Stretchah is offline   Reply With Quote
Old 01-08-2013, 02:50 PM   #6694
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 729
Originally Posted by Moparmanpete View Post
Manual states they are to be flush with the top of the yoke.
My XL is an 87 and has 39mm forks
His bike is a Euro model so it's probably way cooler....
Win a Free Helmet. xladv.com/topic/258-msr-x-pedition-helmet-give-away-round-1/
MentalGuru is offline   Reply With Quote
Old 01-08-2013, 03:49 PM   #6695
mcma111
mcma111's Avatar
Oddometer: 12,923
[QUOTE=Stretchah;20429659]
[QUOTE]
You see that line on the right fork tube about 1/4" from the top of the tube? THAT is what you line up to the top of the triple clamp.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-08-2013, 04:34 PM   #6696
MentalGuru
Crazy Diamond
MentalGuru's Avatar
Oddometer: 729
I suspect a fork swap has been done. Maybe CR forks and lower with them machined to fit the stock upper. Measure the tubes at both clamps (some cartidge forks neck down between the triple clamps). Measure the axle size to see if it is 15 or 17mm in size.
Just curious...
Old 01-08-2013, 11:29 PM   #6697
Stretchah
Oddometer: 123
Cheers Guys and mental guru hopefully one day it'll be cooler, but, not in it's current state
I was thinking the tops should be pretty much flush. I'm guessing they may be a little longer and a previous owner did it like that to even the ride height as seems to be a standard rear shock. That seems to be good news though as wanted to raise the ride height, just got to get an XR rear shock now
It does drop from 43mm to 41mm on the yokes...if they are like that as standard it may be another upgrade option for us :) I'll measure the axle too especially as just bought a spare front wheel Hopefully I can get it to fit without issues...
Moparmanpete, Glad to hear that you've sorted your carb problem, enjoy
Andy
84 Harris Magnum 2
84 XL600R
85 Vespa PK135
Stretchah screwed with this post 01-08-2013 at 11:39 PM
Old 01-09-2013, 05:05 PM   #6698
12120
Indenturedx5
12120's Avatar
Oddometer: 487
Ditto its alive
Yay Mine is also alive. Glad you got your's sorted Pete! I did not get to go for a ride. My tags are expired, and the plate is from OR. I have the bike in my name, just did not get a WA plate on it cause the tags where still good on the old one. I know bend the rules. It was also raining cats and dogs and about 40 degrees. New coil new ricky see what brakes next.
Chris
'83 XL 600r
Old 01-09-2013, 08:52 PM   #6699
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,094
I got a problem, I bought a new Volar o-ring chain. I guess you gotta use a special tool to the press the rivets on the masterlink and I can't afford the tool
What should I do? the damn tool is more than the chain!!
Can i use a master link from a regular o-ring chain??
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 01-09-2013, 09:02 PM   #6700
Homerb
Oddometer: 471
Im assuming the link is a rivet type master link? Id just peen the riverts over with a hammer. Or you could use a normal master link. I did on my last bike which was dynoed at 73rwhp and the link held fine.
Homerb is offline   Reply With Quote
Old 01-10-2013, 12:49 PM   #6701
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 3,094
The bike shop cut me some slack, they installed the chain for free even though I didn't purchase it from them. The mechanic told me my chain is a cheap POS and should replace it soon. And then he told me that the XL isn't worth owning and I should sell it for a 650L. "once this thing blows, that's it! it'll be the same as having no bike" Sorry bro, this thing eats XRLs . But according to him, the engines of the XL and the XRL have NOTHING in common.
I understand my bike looks like a junker, but it's not worthless, kinda pissed me off a little, but I kept my mouth shut since he was installing it for free.
Old 01-10-2013, 01:26 PM   #6702
brucifer
brucifer's Avatar
Oddometer: 2,557
That mechanic sounds like a real winner...
2014.5 Kawasaki KLR650 NE-2002 Kawasaki KLX300R-2002 Husky TE570-2001 Husaberg FE650E-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 01-10-2013, 01:38 PM   #6703
Mike the Yank
Oddometer: 450
Talking
I think that is WHINER
It's a lot easier to apologise than to ask permission
Mike the Yank is online now   Reply With Quote
Old 01-10-2013, 02:59 PM   #6704
mcma111
mcma111's Avatar
Oddometer: 12,923
Opinions are like, well you know.
To each their own.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-10-2013, 07:06 PM   #6705
davek181
davek181's Avatar
Oddometer: 965
A good running XL is much better than the XRL. You have to mod the L to even compare favorably. If you mod the XL suspension you have a much better bike overall.
I have ridden both and I definitely prefer my XL over the L that I got to ride extensively this summer. A friend bought one and I was tasked with uncorking it and rejetting it and desmogging it as per numerous posts on many sites. The intent and purported results of the mods was to "wake up" the XRL. After doing all the popular mods and dialing in the jetting I kept wondering when the wakeup was going to happen. When I finished up and gave it back to the owner, he was impressed by the results, but I was still a little underwhelmed myself.
davek181 is offline   Reply With Quote
Times are GMT -7.   It's 01:44 PM.
