01-04-2013, 09:14 AM
#46 |
Dog Rancher
Oddometer: 4,188
Did you ever change the spark plug.
I remember on my 2 stroke bikes when the plug went bad it would start and idle but die when the throttle was opened. Put a new plug in and it would run like a champ. I always thought that was weird to start and idle fine but die with added throttle. Stepping back and looking at the overall situation. You said it wasn't sudden, started acting up. Being in Mexico I would think bad fuel or dirty fuel clogging the carb or tank. Did you ever try to start it with the fuel cap off or opened. A clogged gas cap vent can cause fuel starvation. http://www.thumpertalk.com/topic/613782-dr650-faq/ http://dr650.wikia.com/wiki/Intake http://www.procycle.us/bikepages/dr650.html#fuelsystems http://www.factorypro.com/tech/carbtun.html http://www.advrider.com/forums/showthread.php?t=347184 http://www.thumpertalk.com/topic/500.../#entry4680645 http://my2wheels.com/forum/showthread.php?t=6456 http://www.advrider.com/forums/showthread.php?t=715659 http://dr650.wikia.com/wiki/Potentia...to_be_aware_of http://drriders.com/topic6707.html
01-04-2013, 10:28 AM
#47 |
on the road o'dreams
Oddometer: 5,510
Of all things mentioned ... the pick-up coil goes to the top of my list. If you read the 11 million post BIG DR650 thread ... you'll see that over time there have been several failed pick-up coils (also called "ignitor or Pulse coil). Not many, but a few. One was on Big Al's bike which failed somewhere in Cent. America. The local mechanics borrowed a PU coil from a car and fit it in .... IT WORKED!
![]() You're correct .. The PU Coil is part of the Stator. It's rare but there have been a few over the years. I don't believe the carb is the issue. (unless it's been buggered up by someone trying to "fix" it! ) We've never seen a Main coil go bad on a DR650. There have been a few Stators gone bad but most times it's misdiagnosed and turns out to only be the Pick-up coil. One or two bad CDI boxes too ... but once again ... very rare. On the road I carry a spare Stator. Best of luck !
01-04-2013, 03:01 PM
#48 | |
Oddometer: 2,612
http://advrider.com/forums/showpost....ostcount=69046 ADV8 posted this pic earlier, from a Suzuki TL1000, NOT a DR.
2004 DR650: 47,033 miles of The last 314 miles were done with my super, hot rod, whiz-bang, blue KLIM Dakar gloves. Good thing I lost one of my 10 year old Joe Rocket gloves; I didn't know I could ride so fast. |
01-07-2013, 11:18 PM
#49 | |
Restless
Oddometer: 211
01-07-2013, 11:51 PM
#50 |
Oddometer: 2,001
01-08-2013, 06:37 PM
#51 |
AKA Invisible Dave
Oddometer: 2,476
Ok, you made it back to Mex. We're all anxiously waiting to hear the final diagnosis
Why are we stopping? We don't have time for that! http://share.findmespot.com/shared/f...8pP8skl622N3ri |
01-09-2013, 05:44 AM
#52 |
Restless
Oddometer: 211
I'm back in zacatecas
Dave, My three flights down were without a glitch...couldn't have been better. I'm unpacked and have my kit ready to meet the tech at 9am. It's the moment of truth...I'll report back later in the day! Jim
01-09-2013, 10:45 AM
#53 |
Long way to go
Oddometer: 1,112
Everybody's on the run |
01-09-2013, 01:19 PM
#54 |
Oddometer: 284
You only need 4 things for an engine to run; compression, fuel, ignition and timing. So, if you've got compression and your plug jumps a nice spark gap and your timing marks all line up and valves seem to open/shut in step with a 4 cycle ... then ?
01-09-2013, 01:21 PM
#55 |
Funemployed
Oddometer: 26
01-09-2013, 03:14 PM
#56 |
Restless
Oddometer: 211
Problem identified
Although my bike still isn't running, the problem is identified. To save me the work of explaining things in two places, please check out my pics and explanation on my RR...http://advrider.com/forums/showthrea...8#post20439568
Again, my thanks go out to all of you for your help and support! |
01-09-2013, 06:02 PM
#57 | |
Oddometer: 5,510
But I also blame the Mexican techs for not finding this in the first hour of work. Hate to say it ... but I feel they strung you along ... WAKE UP! This sort of fault is a novice mechanic diagnostics 101 exercise. I know your guys know more than they are letting on. Oh well, live and learn! BtW, aftermarket Stators are famous for failure. Many many KLR guys have gone with aftermarket stators to gain more output. Many end in failures. It's all over the KLR boards, has been for years. If you feel you need more elec. output you should have come over to the BIG DR650 thread. Lots of guys there with plenty of helpful tips on how to set up your bike to get by with the DR's measly 200 Watt output. Many good mods and upgrades to get by and still have power for elec. jackets, grips and running GPS and such. No problemo. Hope you can still enjoy the rest of your trip! I'll check out your report ... and please ... from now on ask on the BIG DR thread if you have questions. A wealth of knowledge and even some direct support from Pros over there. |
01-09-2013, 08:00 PM
#58 |
One wheel wonder...
Oddometer: 6,435
On our SV portal site there have been numerous occasions where the magnets in the rotor have came loose and pretty much given the same issues you had. Glad you figured it out. Life goes on.
Keep on ridin'...
"Tough times don't last, but tough people do." Robert A. Schuler
01-10-2013, 08:12 AM
#59 | |
Restless
Oddometer: 211
Jim |
01-10-2013, 09:57 AM
#60 |
One wheel wonder...
Oddometer: 6,435
Your rotor is designed differently from the SV's. Ours does NOT have the metal ring on the inside. Some people have used JB weld to epoxy them back into place.
