Old 01-03-2013, 05:27 PM   #226
vtwin OP
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 6,112
Progress!
I got tired of trying to save this piston as I'm sure the cylinder will need machining, so forget the wood block.
The right side was a lot more cooperative though.
Looks like the crank is going to need some cleaning up too. What did I get myself into?
I used to be indecisive. Now I'm not so sure.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 01-04-2013, 05:28 PM   #227
vtwin OP
vtwin's Avatar
Oddometer: 6,112
unknown
Old 01-04-2013, 06:54 PM   #228
brucifer
brucifer's Avatar
Oddometer: 1,625
Excellent!
2006 KLR650-2002 Husaberg FC550E w/2008 FE550E engine-2000 Buell M2 Cyclone-Plated 1995 XR600R-1984 Honda CR500R-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1981 Honda XR500R-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 01-06-2013, 12:21 PM   #229
vtwin OP
vtwin's Avatar
Oddometer: 6,112
More work today.
Battery box and air cleaner need a little work.
unknown
Old 01-06-2013, 12:30 PM   #230
vtwin OP
vtwin's Avatar
Oddometer: 6,112
Guess this protects the frame from the chain.
Rear brakes are pretty worn, guess someone really did ride this bike.
This side cover did not want to come off, I'm certain all the bolts were removed, maybe one under the points?
Nope, just stuck on the dowel pins and power of the magnet from the stator.
It's out!
I think I've been here before...
Next, strip the frame down and then the engine. Club member recommended a small engine shop I'll bring the crank and cylinders to.
unknown
Old 01-06-2013, 04:47 PM   #231
brucifer
brucifer's Avatar
Oddometer: 1,625
vtwin, maybe you should start a dedicated build thread for this bike up in the 2 stroke forum. You may get more interaction there. Just a thought.
Old 01-06-2013, 05:36 PM   #232
vtwin OP
vtwin's Avatar
Oddometer: 6,112
Yea, I thought of that, but thought I'm already using too much bandwidth.
unknown
Old 01-06-2013, 06:03 PM   #233
radianrider
Adventurer wanna'be
radianrider's Avatar
Oddometer: 297
Just not sure whether to admire your chutzpah or offer you my condolences. Man, that bike is a PROJECT!
radianrider is offline   Reply With Quote
Old 01-06-2013, 06:05 PM   #234
vtwin OP
vtwin's Avatar
Oddometer: 6,112
I know, but in my mind it's already restored to perfection.
unknown
Old 01-07-2013, 05:36 PM   #235
radianrider
Adventurer wanna'be
Oddometer: 297
I suspect that is what it will take to stick with it long enough to achieve it.
Hang in with the wee beastie.
Old 01-07-2013, 07:49 PM   #236
vtwin OP
vtwin's Avatar
Oddometer: 6,112
Thanks RR, will be stripping the rest of the frame this weekend and look for a painter. Maybe powder coat instead?
unknown
Old 01-08-2013, 07:22 PM   #237
radianrider
Adventurer wanna'be
Oddometer: 297
I've been wondering, does power coating help prevent rust better than paint? If it does, I'd go with it instead of paint. That poor bike has earned as much protection as possible after the hard life it has lived to this point.
Did you ever get the GR back on the road this fall?
Old 01-08-2013, 08:03 PM   #238
vtwin OP
vtwin's Avatar
Oddometer: 6,112
I think I will get off my ass and take those carbs off again. Spoke to a carb guru and he mentioned I may have an issue with the slow jet. I may just send them to him, along with the frozen Stinger carbs.
unknown
Old 01-09-2013, 03:50 AM   #239
radianrider
Adventurer wanna'be
Oddometer: 297
Sounds like a good plan. Looks like you've got your hands full with the project you are working on anyway.
Finally got my brakes fixed. Another forum member, bwringer, figured out what was wrong and got them set up correctly. A lot more fun to ride when you know you can stop.
Have the tank off right now trying to figure out how to take some dents out. Plan to strip and paint the body work early in the spring (waiting for it to get warm enough) and then ride the thing. Need to figure out some saddlebags or better tailbag so I can commute to work more comfortably. Not a fan of backpacks.
Hang in with the Stinger--it will keep me entertained while it is too cold to work on mine. :)
Old 01-09-2013, 07:19 PM   #240
vtwin OP
vtwin's Avatar
Oddometer: 6,112
Thanks will do. Update, inside of the right side looks good, very clean. Guess they took care of the fluid and clutch does not appear to have been burnt.
Started to disassemble the front end.
Brakes are better on the front than the rear.
Rears.
Fronts
Drum could use some cleaning up.
That's all for today.
unknown
Times are GMT -7.   It's 11:45 PM.
