Old 01-10-2013, 07:57 AM   #241
claude
Sidecar Jockey
Oddometer: 3,693
Originally Posted by MotoJ View Post
I really like the carrier/stay piece for the brake caliper in this setup. Any more pics?
This IS kinda cool. However for off road it is probably better to have th ecaliper up on top. Just food for thought.Many of the trike folks use the plate as shown on the downtube in lieu of bending the fork tubes. We use double wall tubing for the fork tubes which are bent to whatever angle we feel is best for the application. Lots of ways to make aleading link happen no doubt. Floating calipers are the way to go though.
Claude
http://freedomsidecars.com/
Old 01-10-2013, 10:11 AM   #242
boxertricks
Oddometer: 189
No I'm afraid not these were the only pictures I took.
boxertricks is offline   Reply With Quote
Old 01-15-2013, 06:40 PM   #243
MILLENNIUM FALCON
Oddometer: 245
.......what do you guys use for the joint at end of the fork legs (where the lower swing arm attaches? I have seen some bikes use ball (heim) joints, but was wondering what most are using. Bearings,bushings, or maybe just steel on steel. Any help...pictures would be awesome! Thanks!
MILLENNIUM FALCON is offline   Reply With Quote
Old 01-18-2013, 02:09 PM   #244
halflive
halflive's Avatar
Oddometer: 350
Most common used are rubber bushes. The same kind as used in the A-arms of cars.
halflive is offline   Reply With Quote
Old 01-18-2013, 03:17 PM   #245
zipper421
Oddometer: 204
bushing
are they two piece
how do you weld them in with out them melting
I love it when they say, "Where did you buy that ?"
zipper421 is offline   Reply With Quote
Old 01-18-2013, 07:21 PM   #246
oppozit
Oddometer: 341
Originally Posted by zipper421 View Post
are they two piece
You don't! You use an interference fit to press them in, just like IMZ has done for decades.
oppozit is offline   Reply With Quote
Old 01-19-2013, 04:56 AM   #247
kshansen
kshansen
Oddometer: 188
On the front end I built back in 1992/93 I used the Heim joints, 3/4 inch with grease fittings. That front end has over 100,000 miles on it and I did replace them once.
I do like the rubber car bushings idea, have to keep that in mind if I decide to build another front end for the XS400 project
kshansen is offline   Reply With Quote
Old 01-19-2013, 06:04 AM   #248
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,287
You can buy high performance Polymer bushings instead of the standard rubber ones.They will have less play/flex in them.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 01-19-2013, 11:06 AM   #249
halflive
halflive's Avatar
Oddometer: 350
Do the polymer bushes also have enough flex in them? The rubber bushes are also the hinge. They must be able to rotate about 15 degrees.
Old 01-19-2013, 03:11 PM   #250
claude
Sidecar Jockey
Oddometer: 3,693
We have used both and I prefer the heim ends. The ones we use are aircraft quality 3/4" x 3/4". No grease fittings. Weldnuts are wleded into the end of the fork tubes To receive these. You can play with camber on the front wheel a little using these by screwing them in and out.
Claude
Old 01-25-2013, 06:47 AM   #251
Slade 330
Slade 330's Avatar
Oddometer: 92
My Front end , this works great
My front end , this works great and won't break
http://www.youtube.com/watch?v=OlEiQdlJKVM
Slade 330 is offline   Reply With Quote
Old 01-26-2013, 04:52 PM   #252
Flodder
Flodder
Flodder's Avatar
Oddometer: 466
Thanks for the vidio and the isralite run. gotta get my act togather and put my chair on the 1400 i got from santa last xmas
Cheers Flodder
Flodder is offline   Reply With Quote
Old 01-27-2013, 12:02 AM   #253
MILLENNIUM FALCON
Oddometer: 245
Thank you for the info guys!
Old 05-14-2013, 11:56 AM   #254
NitroMax
NitroMax's Avatar
Oddometer: 674
Mine's ready, EHE design ( Netherlands ) built it. I liked the design of the leading link fork on his Hacked Wing so much I asked him to build me one.
It's for my BMW R90/6
Pics:
Buildthread with all the pics here:
http://advrider.com/forums/showthrea...=623971&page=4
1300cc 217Nm/207Hp NOS-injected VMax (1985), 500 cc 1950 BSA chopper (1983) in pieces, 750 cc CB750 chopper (1990), 300 cc MZ transporthack (1989) winterhack, 900 cc BMW R 90/6 hack (1976) summerhack, 1100 cc BMW R1100GS (1997) daily driver.
Age is an issue of mind over matter. If you don't mind, it doesn't matter ( Mark Twain )
NitroMax is offline   Reply With Quote
Old 05-29-2013, 04:42 PM   #255
SINCAZ
OUTBACK BUSH BASHER
SINCAZ's Avatar
Oddometer: 11
Talking Sidecar front end design
Just going back to the basics.
We want to reduce the trail or caster effect of the front wheel don't we ?
First of all what trail are we aiming for ?
1. Well what about remake the triple trees with a different fork angle to bring the wheel further forward ?
2. On the leading link design do we want to get the main bent down tube vertical at the lower section and have the swing arm in the horizontal position ?
3. Brakes. Floating or attached to the swing arm ?
4. Main tube thickness 5 or 6 mm ?
If I can't find the right tube diameter how about sleeving it to suit the triple tree ? ie 46 mm triple tree and using tube of 40 mm by 5 mm wall thickness and turning a sleeve of 6 mm and plug welding.
Does this sound logical and safe ?
Thanks for your input
SINCAZ is offline   Reply With Quote
Times are GMT -7.   It's 09:00 AM.
