Old 01-09-2013, 05:44 AM   #106
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 41,488
Originally Posted by JimVonBaden View Post
It was Christmas!
Took it to the garage and played with some of it.
A bunch of farkles for the bike, and new brakes for the wife's car. I'll be busy this weekend!
Jim
I added a couple more farkles.
Helmet lock off E-bay. Not particularly cheap, but necessary.
I also added a couple yellow conspicuity lights.
Cheap CREE 15 watt yellow lights.
I added a switch for temporary. I plan a better one when I do the Fuzeblock.
I know, but they are ridiculously light, and I am trying it out. I have some spare turn signal stalks.
They really put out. I doubt all that much down the road, but I bet people will see me, even if they don't see my turn signals!
Alternate mounting locations are in the future when I add the driving lights.
I also mounted and wired up, temporarily, my USB plug. Very nice Pieces, and should work great!
Jim
Old 01-09-2013, 10:24 AM   #107
RoyQ
RoyQ's Avatar
Oddometer: 1,812
I have been building this track monster since Nov '12
Started out as a nice street bike
Few weeks later stripped of street creed
Suspension upgrades, 30 mil Thermosman tweaked Ohlins cartridges in front forks and a massive JRi rear shock added.
Vortex rearsets and Spiegler brake lines added
Vortex engine guards added
Race bodywork added, but I still need to add decals, stickers and numbers once paint cures.
It's a mean mutha, ecu tuned and it's not short on power. I still have to add the quick shifter with map up to ecu and CRG black shorty levers. 8 weeks is the inaugural run at Talladega GP in Al. Then Barber in April. Day in the life of a GSXR1000.
2012 YAMAHA Super Ténéré
'11 GSXR750
'11 GSXR1000 racebike
RoyQ screwed with this post 01-09-2013 at 10:41 AM
RoyQ is offline   Reply With Quote
Old 01-10-2013, 05:10 AM   #108
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 5,299
Way cool project.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 03 Harley Road King Police, 00 Husky Te 610 e, 1999 Husky TC610 SM,
fritzcoinc is offline   Reply With Quote
Old 01-10-2013, 05:38 AM   #109
Sir. Waffles
Sir. Waffles's Avatar
Oddometer: 47
Jim
Where did you get the USB socket from??
Sir. Waffles is offline   Reply With Quote
Old 01-10-2013, 06:41 AM   #110
JimVonBaden OP
"Cool" Aid!
Oddometer: 41,488
Ebay, these guys: http://www.ebay.com/itm/251122104452...84.m1439.l2649
Just keep in mind that it needs to be put on a circuit that has no power with the bike off. It is lit, and draws a small amount that could kill the battery over many days.
Covered.
Jim
PS I tested it yeaterday and it works great, even in the rain!
Old 01-10-2013, 06:44 AM   #111
JimVonBaden OP
"Cool" Aid!
Oddometer: 41,488
Made this last night:
Jim
Old 01-10-2013, 08:30 AM   #112
kubiak
Oddometer: 4,139
nice headlight protector!
Old 01-10-2013, 04:52 PM   #113
Sir. Waffles
Oddometer: 47
Covered.
Jim
Thanks, I've seen them around but been trying to find a cheap place to get one. Still over priced for USB in my mind but better than 40 plus shipping at other places.
Old 01-10-2013, 06:11 PM   #114
kubiak
Oddometer: 4,139
on my bmw tw650 i put some bar risers, shortened the kickstand an inch since i put a lowering link on a few days ago and a helmet lock.
Old 01-10-2013, 06:24 PM   #115
JimVonBaden OP
"Cool" Aid!
Oddometer: 41,488
Yeah, I looked everywhere for this kind of flush mount USB with two plugs. This was the best I could find. High quality to be sure.
Jim
Old 01-11-2013, 05:24 AM   #116
RoyQ
RoyQ's Avatar
Oddometer: 1,812
Sticker fairy arrived yesterday
The GSXR is just about complete!
'11 GSXR750
Old 01-11-2013, 08:02 PM   #117
JimVonBaden OP
"Cool" Aid!
Oddometer: 41,488
I wanted both conspicuity lights (see above), and driving lights. I also wanted to move the conspicuity lights lower so they didn't wash out my turn signals.
This was my cheap solution:
Using 1" by 1/8" flat bar I formed this:
Checking for clearance I zip tied it in place.
The center section is 11" long, with a 1.5" drop and 4" mounting surface for lights. It is quite stiff as is.
Being cheap, I made my own "J" bolts from long bolts I had in the bin.
I wanted to bed liner paint it, but had run out, so I used Plastidip. It was really too thick, but should be OK for now. I have plans for a slightly improved unit in the future.
Mounted to the beak frame with J-bolts. As far forward as possible. This gives the forks about an inch of clearance at full lock.
The conspicuity lights are mounted low, and the driving lights high. (Yes, I would have prefered black light housings for both, but they were cheap.) I used the same bolt, loctited, for both lights.
Front view. Looks like this should work great!
I will wire up the lights when I receive the fuse box next weekend.
Jim
Old 01-12-2013, 06:18 AM   #118
walkingbear
walkingbear's Avatar
Oddometer: 2,858
Friday
finished re organizing the tool box and purchased a rivet gun to
redo some of my seats,
Question to the audience : Can I use led driving or spot lights with a home 12v landscaping system.
BMWMOA 82741 75 R90S ,83 R100RT (Baron) , 88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS w/hack,05 K1200S (Gandalf)
walkingbear is offline   Reply With Quote
Old 01-12-2013, 09:15 AM   #119
JimVonBaden OP
"Cool" Aid!
Oddometer: 41,488
Most of the LED lights are able to handle a variety of voltages. Mine are good from 9-80 volts. You can get them dirt cheap on E-bay too!
Jim
Old 01-12-2013, 02:20 PM   #120
JimVonBaden OP
"Cool" Aid!
Oddometer: 41,488
Brakes, pads and rotors, on the wife's Rogue.
The rotors were not much out of new spec, about .02", but there was a high speed vibration when braking from about 50+ lightly. Not bad wear for 38K miles, and a lot of in town driving by a heavy braking foot.
Polished out several door scratches, and cleaned the garage for the next project.
Jim
Times are GMT -7.   It's 03:27 AM.
