Thread Tools Search this Thread Rating: Thread Rating: 157 votes, 4.99 average. Display Modes
Old 01-03-2013, 12:49 PM   #3301
DaFoole
Lewddite at large...
DaFoole's Avatar
Oddometer: 4,222
Had my Spot 2 for about 2 yrs IIRC. Lately it's been shutting off without warning. I'm guessing it's dying...
Been mounted to the bike for it's entire life with no crashes.
I've read about similar episodes on Amazon.
Anyone else experiencing this?
Guess I gotta buy a new one.
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over
"Don't come in here with your thoughtfulness, empathy, and reason... this is shit, up with which, I shall not put." -Boondoggle
DaFoole is offline   Reply With Quote
Old 01-03-2013, 06:57 PM   #3302
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
Tried new Lithiums lately? Maybe the batteries are losing contact? Try stuffing an earplug in the battery case to see if it stops the batteries moving around.
Old 01-05-2013, 01:48 PM   #3303
H-Jay
Mo 2 C
H-Jay's Avatar
Oddometer: 401
Originally Posted by BrzGSAdv View Post
I must confess I have not heard about Delrone's InReach before and after reading about it I am now officialy over the fence on which to choose. Okay, it is more expensive but the Iridium network should be superior, right? This is safety so the extra buck$ are not the biggest driver...
Which is best??? Any additional views?
I plan to buy over the next couple of days and have it delivered to my hotel during an upcoming business trip so I need to make up my mind quickly here...
Best Rafa
Regarding Spots working in South America, I used tracks all through Chile and Argentina with no problems. It even worked fin in Ushuaia. You may have already made your decision.
H-Jay
2007 BMW R1200GSA
1968 Norton Fastback
1969 Triumph Bonnie
South America Blog
Patagonia Bound Ride Report
http://www.advrider.com/forums/showthread.php?t=420453
Alaska Ride Report http://www.advrider.com/forums/showthread.php?t=250239
H-Jay is offline   Reply With Quote
Old 01-05-2013, 02:40 PM   #3304
HogWild
Scott Whitney
HogWild's Avatar
Oddometer: 2,766
The southern most part of SA is in the "marginal" zone of coverage. That means it may work sometime, and not work other times. It depends on where the satellite is at the moment the SPOT transmitts.
New desert racing frontiers
It will be Devilish !
HogWild is offline   Reply With Quote
Old 01-07-2013, 10:05 AM   #3305
HOFNAR
Oddometer: 72
Yet another SPOT/Spotwalla question...
OK, I'm at my wit's end here. I thought I did everything correctly, but apparently not, since I can't get my "test trip" using my SPOT to show up on the shared page I created on Spotwalla. Ugh! I know the device is working because the "test trip" is showing up on my account on the SPOT website.
I followed the directions on the Spotwalla website. I've opened an account, created a device, etc, etc,...However, when I check the "Trips" tab on Spotwalla it indicates that "No New Messages" are available and the map is blank. Again, I know I've done everything correctly using the SPOT device because I get the notifications via email/text message showing that I "Checked In" and also that I sent a "Tracking Point".
If anyone has any suggestions, I'd be grateful. Thank you.
Jesse
HOFNAR is offline   Reply With Quote
Old 01-07-2013, 10:10 AM   #3306
Montague
UDF Adventurer
Montague's Avatar
Location: an alternate universe, much better than yours
Oddometer: 666
Have you sent a message to Jason at Spotwalla?
He is very helpful and quick to reply.
Honda ST1300 with Hannigan Super Sport sidecar (Hondagan), Ural Gear Up, Rokon Ranger and now an Argo, WTF is wrong with me?
A Brit named Billy once said something silly; he so wrongly concluded that Ural deluded.
Montague is offline   Reply With Quote
Old 01-07-2013, 10:15 AM   #3307
HOFNAR
Oddometer: 72
How do I get a message over to Jason? I didn't see a contact link for him on the Spotwalla website.
Old 01-07-2013, 10:21 AM   #3308
Montague
UDF Adventurer
Montague's Avatar
Oddometer: 666
https://groups.google.com/forum/?fro...t-trip-manager
Old 01-07-2013, 11:37 AM   #3309
DaFoole
DaFoole's Avatar
Oddometer: 4,222
Brand new batteries....changed out several times...
Will try the earplug trick.
Old 01-07-2013, 01:29 PM   #3310
HOFNAR
Oddometer: 72
Got it all figured out. Thanks for the help.
Jesse
Old 01-10-2013, 06:35 PM   #3311
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,181
I'm still learning to use my Spot 2.
I'm trying to use it to track my route in the woods, but I didn't pay for tracking. How often can I press the "Ok" button to mark my progress? It seems to flash for quite a while after I press it, and I can't wait 5-10 minutes each time I want to mark a location. I think I pressed it again, while it was flashing, and it made and second marker. Can it do that?
GlennR is offline   Reply With Quote
Old 01-10-2013, 06:47 PM   #3312
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
I think it takes at least 15 or 20 minutes before you're clear to send another OK message. If you turn the unit off to stop an OK in progress, you might abort that signal. If you pressed again before it finished sending the first message, it will ignore you.
If tracking's that important to you, maybe you should buy it?
Edit: just checked the manual. The message cycle is 20 minutes.
"Leave the SPOT outdoors. The GPS indicator light blinks green as SPOT acquires a GPS fix. Once SPOT aquires your GPS location, the Message Sending light and GPS light will blink green in unison for ~15 seconds to notify you that your message is being transmitted with GPS location. The Message Sending light will continue to blink green over the remainder of the 20 minute message cycle and for one (1) hour after the end of the message cycle (this is to provide you with additional time to check if your most recent message was transmitted). The Check-In/OK function light will turn off once the message cycle is complete."
Emmbeedee screwed with this post 01-10-2013 at 06:53 PM
Old 01-10-2013, 07:35 PM   #3313
250senuf
250senuf's Avatar
Oddometer: 2,409
Sounds as though you need a GPS that can mark lots of waypoints. Or if it's tracks you're after get a base model GPS to gather tracks, should cost about the same as a year's worth of SPOT tracking service.
Not all who wonder are confused
250senuf is offline   Reply With Quote
Old 01-10-2013, 07:35 PM   #3314
GlennR
Playin' in the Fire
GlennR's Avatar
Oddometer: 2,181
Thanks for the info. I don't know how I managed to get 2 markers so close to each other.
I'd rather buy a GPS that tracks than pay for the Spot tracking. I'm just playing around with the Spot since I haven't bought a GPS yet. I think Spot tracking would be great if I was travelling and family/friends could track my progress, but I'm not travelling or going anywhere that would be interesting to anybody else. I'm just trying to figure out a maze of new & old logging trails that are in the 7500 acres of mountain forest where I ride & explore.
I've been researching GPS models and have decided on an Oregon 450 that's $200 refurbished from Garmin, but haven't been able to justify it quite yet. I'm still not quite convinced that I'll use it a lot, and I'm also having fun exploring "the hard way". It's sort of like a puzzle, and after it's solved the exploring part of the woods is over...So, in that sense I'm not really in a hurry. If I was surrounded by vast open spaces to explore in all directions, I know I would find the GPS a very useful & valuable tool.
I bought the Spot because I like to ride & explore alone, and even though it's only 15 minutes from home, there is plenty of potential for an emergency. Snakes, bears, & broken legs & such.
Old 01-10-2013, 08:04 PM   #3315
Twohondas
Twohondas's Avatar
Oddometer: 1,204
If you are riding in the woods alone...sounds like the SPOT is perfect ..but for your safety ie NO cell phone in many wooded areas. I like the tracking to update folks on your progress. Also good to have if you are unable to push SOS etc as at least they will have last tracking spot.
SPOTs are frankly not good for an accurate track picture as you only get a location every ten minutes. This is especially true if you are exploring and making short legs. Most any GPS will give you track locations frequently along your route to better show where you actually went for the whole trip.
Twohondas is offline   Reply With Quote
Times are GMT -7.   It's 03:09 AM.
