09-16-2012, 01:39 AM
#46 |
Oddometer: 35
Hi Pete, very cool and well made little chair that
10-14-2012, 03:36 AM
#47 |
Oddometer: 143
That's Frickin' awesome. it's exactly what I want nothing to big nice and light. I'm pumped to start my build this winter.
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course ![]() http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
10-20-2012, 06:06 PM
#48 |
Oddometer: 1,403
That is a great looking set up.
Thank you for posting . Cheers Ian |
01-01-2013, 05:12 PM
#49 |
Oddometer: 191
I love your build! my only question is how is it to ride? I rode my hack as a leaner (just around the house) before I got my struts built and it scared me to death. And I didn't go over 15 MPH. It just felt grabby and wanted to pull and lean when I wasn't ready, and I also felt like I was going to snap off my right ankle when I stopped. Your side car was designed to lean so im sure it is much better, I was just curious. Thanks!
01-01-2013, 06:35 PM
#50 | |
Oddometer: 508
when your unit is standing the car would pull the bike over towards the car as your mounts are to the side of the bike... where if you look at where my car is mounted.. in a direct line though the centre of the bike the weight from the car is dirrectly down.. the bike will stand up right by itself when parked "till someone knocks it" the other thing that happens when turning the car steers in the direction you are going.. As the front mount point is higher by 80mm than the rear so as the bike leans it pulls/pushes the front of the car across more than the rear..turning the whole car into the corner..front mount being higher than the rear it has a longer arc radius than the rear for any lean angle of the bike...but if the car goes over a bump or drops into a hole it goes up or down straight with no turning/steering efect... The steering only happens when the bike leans moveing the front mount point ferther away from the bikes centre line than the rear mount.. So you can't mount a leaner off the side of the bike as it will try and make the bike lean towards it the heavyer the car the worse that efect is... you will be always fighting it to keep the bike up right.. Imagine putting all your weight on one foot peg.. the bike will fall towards that side.. I can sit on 100kph "60mph" with no probs... tight corners can be a issue as you can run out of lean on the limiting strut... just slow down and alls good... On gravel roads start to turn in ..then a little dap on the rear brake kicks the rear out pointing the unit in the direction of the corner..fun fun fun... Pete
Here.... my XR250 leaner side car build http://www.advrider.com/forums/showthread.php?t=716993 Pete-NZ screwed with this post 01-01-2013 at 06:59 PM |
01-01-2013, 07:41 PM
#51 |
Oddometer: 191
Cool, That explains a lot! Thanks for the info. Maybe someday I'll make a leaner :)
01-03-2013, 06:45 AM
#52 |
Is still learning
Oddometer: 254
Hi Pete!
A little question for you... I'm making a rear rack for my Tornado.. Can I post some photos of it here? I do also have plans of making a bashplate with a washing machine drum (Inox steel)
2010 Honda XR 250 Tornado |
01-03-2013, 11:22 AM
#53 |
Oddometer: 508
yes .. go for it
Here.... my XR250 leaner side car build http://www.advrider.com/forums/showthread.php?t=716993 |
01-03-2013, 03:38 PM
#54 |
Is still learning
Oddometer: 254
Well, thanks Pete!
So, I'll hijack the thread with this.. I've made the rack with lots of help of my sister's husband (Actually, he did most of the job and I helped) although it's not finished yet, here are some pics of it.. ![]() ![]() ![]() He lent me his angle grinder, so I took it for grinding the welds.. And also, I used it for cutting the files of the cross (I know they are pretty bad cutted, but hey, I learned to use the grinder a week ago, I do what I can, hehe!) The missing spaces between the files will be filled when we do the final weld.. The idea of it was taken of the NX 250 rack, if anyone is interested, I can measure everything and post the sizes here.. We have to weld a little more yet and also do some holes for ropes, cargo nets, etc.. I'll post pictures as we progress with it.. Thanks for the space for posting this! Greetings from Argentina!
01-11-2013, 09:43 AM
#55 |
Is still learning
Oddometer: 254
Here are some photos of the project finished.. (I'll cut the pieces of hose that are not between the rack and the frame of the bike..)
03-05-2013, 12:15 AM
#56 |
Oddometer: 759
Hows the 40 degree lean working out Pete? is that enough to still give it a good lean over on the road as well?
02 & 05 DR650's 67 Ducati 250 Mark 3 Narrow Case 94 Beta Techno 250 Facebook Adventure Riding NZ Group Facebook Adventure Riding NZ News |
03-05-2013, 12:25 AM
#57 | |
Oddometer: 508
40* is plenty... yer wouldn't want to push a nobbley much more.... you tend to back of a bit in the corners with a car on... 40* is a static measurement in fact its prob more when cornering as the car will rise & lower as the car suspention lifts/compresses..
03-05-2013, 05:28 AM
#58 |
Oddometer: 1,403
Hi Pete-NZ. One question please .
what did you use for your limiting strut,The one that is on the bike now in the photos I have no idea of what to get for ours . I like the idea of adjusting it to how fast or slow it works . That should make it better for when the wife rides it in the dirt . I too have to remember the sidecar is on there when it is set up as a leaner .On the way out to take the dog to the beach for swim today I hit a white post on the side of a dirt road with the front of the sidecar . They are only plastic posts so no damage . Cheers Ian |
03-07-2013, 06:38 AM
#59 |
I've been cloned
Oddometer: 385
specs?
Pete awesome build! I see a weight estimate 60-70lbs. Did you have a chance to weigh it in it's final configuration?
What's the size of the storage space? Ive seen a lid that opens over the hack wheel to make a table, maybe you'd consider. Thanks for posting! You've got me wondering how this could work on my WR250R....
seeking entelecheia thru ipsedixitism
03-08-2013, 12:55 AM
#60 |
Oddometer: 16
Nice chair Pete.
....no need for the left hand guard.....
