Thread Tools Search this Thread Rating: Thread Rating: 369 votes, 4.93 average. Display Modes
Old 01-10-2013, 05:26 PM   #6556
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,633
Originally Posted by Emmbeedee View Post
Nope, not available for the Montana.
Bummer.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 01-10-2013, 08:20 PM   #6557
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
It would be interesting if the Montana could display in a larger way the zoom scale you're changing to for a couple of seconds, when you zoom in or out.
Great suggestion! Thank You :)
atlas cached is offline   Reply With Quote
Old 01-11-2013, 10:26 AM   #6558
Rocky TFS
Rocky TFS's Avatar
Oddometer: 565
Originally Posted by Rocky TFS View Post
I've been playing with custom POI files after reading Post # 1935-1938 way back in January '12 from DVWalker.
Several of them went well, then I started seeing this behavior: (posted on the Garmin POILoader forum)
Never mind, I solved my own question. I was using a source directory that had a few other files in it that I did not believe POILoader would see, not being *csv or *gpx. Apparently, however, it WAS parsing these files, and one of them had my home waypoint somewhere in it. (I can't find out which one, but when I moved the source *.csv file into a completely empty folder before running POILoader, the spurious waypoint "Poi" disappeared.)
(Just like the directions say: USE AN EMPTY FOLDER AS YOUR SOURCE, WITH ONLY THE *GPX OR *CSV FILES IN IT THAT YOU WANT TO CONVERT TO *GPI.!! ) D'oh!
Rocky TFS is offline   Reply With Quote
Old 01-11-2013, 01:08 PM   #6559
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,652
Glad you figured that out, and reported back. I get the feeling not that many people use custom pois.
Emmbeedee is online now   Reply With Quote
Old 01-11-2013, 01:12 PM   #6560
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,652
New Use for a Garmin Tempe:
A meat thermometer!
I was out in the car today and found a good source of frozen meats, but hesitated about buying it in case we'd have to head home sooner than we wanted to, to stop it thawing. I stuck the meat into a plastic bin in the trunk, with a polar fleece cover, and my Tempe sitting on the meat. The whole rest of the day, I knew exactly what the temperature was in there, displayed on the gps on the dash, and recorded in the track.
Old 01-11-2013, 01:22 PM   #6561
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,039
A meat thermometer!
Old 01-11-2013, 01:38 PM   #6562
mass-klr
mass-klr's Avatar
Oddometer: 159
A meat thermometer!
Nice.
_____________________________
Leon
'11 KLR650 ... '04 DRZ400S
Paved Roads are just another example of wasted Taxpayer Dollars
mass-klr is offline   Reply With Quote
Old 01-11-2013, 02:58 PM   #6563
Rocky TFS
Rocky TFS's Avatar
Oddometer: 565
A meat thermometer!
Hey, maybe there is a use for the Tempe for me after all! Since the Beemer has it's own thermometer, I never thought about buying one, but we are often concerned whether the frozen food will stay frozen on the way back from Costco, a two hour drive.
Anybody know the upper limit of transmit distance?
Old 01-11-2013, 03:11 PM   #6564
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,652
I don't know what the official distance is but it transmits at least 20 feet in my house, through wood and drywall walls.
And about 10 feet from the trunk to my dash.
These figures are my own observations - I can't find a published spec for that, and I haven't tried to see how far I could get from the Tempe to the gps.
Emmbeedee screwed with this post 01-11-2013 at 05:42 PM
Old 01-11-2013, 05:10 PM   #6565
snooker
AttitudeIsEverything
snooker's Avatar
Oddometer: 1,580
I can't tell from the pictures, is the accessory pocket on the inside and is it big enough for the USB cable?
A normal USB cable would fit, not sure what came with the Montana, the pocket is open on the top and some of cable might stick out, but the side with the backbone i put the Montana front/glass facing to protect it, so the side with pocket, well if the cable end rattled around they would only hit the back of the Montana.
XCountry Web Site ~~~ My Spot Location ~~~ Spot Baja Trip ~~~ Neduro Did Dakar!
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400
snooker is offline   Reply With Quote
Old 01-14-2013, 12:10 PM   #6566
snooker
snooker's Avatar
Oddometer: 1,580
what's going on? 3 whole days and no newbie questions?? it's like the whole world is shellshocked Broncos fans or something, I thought that was just us in Colorado..
Ok I'll ask another one... I know it's been answered but a few minutes of googling and I can't find it, must not be searching for the correct term, sorry...
So in map view when you accidentally touch the screen too lightly and it is trying to mark a waypoint and the red pin shows up.... so annoying! Is there a way to turn this off or what is a suggestion?
thanks.
Old 01-14-2013, 12:15 PM   #6567
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,652
thanks.
Close the pushpin by clicking the X on the right side of the details screen.
Old 01-14-2013, 12:41 PM   #6568
snooker
snooker's Avatar
Oddometer: 1,580
ok well there's that yes.
But is there anyway to PREVENT the pushpin from popping up in the first place? Or a workaround of some sort to minimize the effect?
I am willing to push 18 menu items IF I even want to set a waypoint! It is just something I RARELY want to do, and I touch the screen a LOT and it is annoying as hell!
Old 01-14-2013, 12:49 PM   #6569
guavadude
de-composer
guavadude's Avatar
Oddometer: 826
If you touch the screen and pause before swiping, the screen will move and a pin will not drop.
If you touch short and quick, a pin drops.
That's about the best I've found and agree, I wish I could bypass it somehow.
guavadude is offline   Reply With Quote
Old 01-14-2013, 01:05 PM   #6570
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,039
Wow. Very useful to know.
Times are GMT -7.   It's 07:12 PM.
