01-10-2013, 04:54 PM
#6571 | |
Procrastinators
Oddometer: 5,792
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
01-10-2013, 05:03 PM
#6572 | |
Oddometer: 198
01-10-2013, 05:26 PM
#6573 |
Accredited Jackass
Oddometer: 42,795
Life is not measured by the number of breaths we take, but by those moments that take our breath away. George Carlin |
01-10-2013, 08:20 PM
#6574 | |
OX Ambassador
Oddometer: 419
01-11-2013, 10:26 AM
#6575 | |
Oddometer: 198
Never mind, I solved my own question. I was using a source directory that had a few other files in it that I did not believe POILoader would see, not being *csv or *gpx. Apparently, however, it WAS parsing these files, and one of them had my home waypoint somewhere in it. (I can't find out which one, but when I moved the source *.csv file into a completely empty folder before running POILoader, the spurious waypoint "Poi" disappeared.) (Just like the directions say: USE AN EMPTY FOLDER AS YOUR SOURCE, WITH ONLY THE *GPX OR *CSV FILES IN IT THAT YOU WANT TO CONVERT TO *GPI.!! ) D'oh!
01-11-2013, 01:08 PM
#6576 |
Procrastinators
Oddometer: 5,792
Glad you figured that out, and reported back. I get the feeling not that many people use custom pois.
01-11-2013, 01:12 PM
#6577 |
Procrastinators
Oddometer: 5,792
New Use for a Garmin Tempe:
A meat thermometer! I was out in the car today and found a good source of frozen meats, but hesitated about buying it in case we'd have to head home sooner than we wanted to, to stop it thawing. I stuck the meat into a plastic bin in the trunk, with a polar fleece cover, and my Tempe sitting on the meat. The whole rest of the day, I knew exactly what the temperature was in there, displayed on the gps on the dash, and recorded in the track.
01-11-2013, 01:22 PM
#6578 | |
Sure, why not?
Oddometer: 16,136
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ |
01-11-2013, 01:38 PM
#6579 | |
Oddometer: 66
_____________________________ Leon '11 Orange KLR650 |
01-11-2013, 02:58 PM
#6580 |
Oddometer: 198
Hey, maybe there is a use for the Tempe for me after all! Since the Beemer has it's own thermometer, I never thought about buying one, but we are often concerned whether the frozen food will stay frozen on the way back from Costco, a two hour drive.
![]() Anybody know the upper limit of transmit distance? |
01-11-2013, 03:11 PM
#6581 |
Procrastinators
Oddometer: 5,792
I don't know what the official distance is but it transmits at least 20 feet in my house, through wood and drywall walls.
And about 10 feet from the trunk to my dash. These figures are my own observations - I can't find a published spec for that, and I haven't tried to see how far I could get from the Tempe to the gps.
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. Emmbeedee screwed with this post 01-11-2013 at 05:42 PM |
01-11-2013, 05:10 PM
#6582 |
AttitudeIsEverything
Oddometer: 1,255
A normal USB cable would fit, not sure what came with the Montana, the pocket is open on the top and some of cable might stick out, but the side with the backbone i put the Montana front/glass facing to protect it, so the side with pocket, well if the cable end rattled around they would only hit the back of the Montana.
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~ Kids: OSET electric | Honda CRF50FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar! |
01-14-2013, 12:10 PM
#6583 |
Oddometer: 1,255
what's going on? 3 whole days and no newbie questions?? it's like the whole world is shellshocked Broncos fans or something, I thought that was just us in Colorado..
![]() Ok I'll ask another one... So in map view when you accidentally touch the screen too lightly and it is trying to mark a waypoint and the red pin shows up.... so annoying! Is there a way to turn this off or what is a suggestion? thanks.
01-14-2013, 12:15 PM
#6584 | |
Procrastinators
Oddometer: 5,792
01-14-2013, 12:41 PM
#6585 | |
Oddometer: 1,255
![]() But is there anyway to PREVENT the pushpin from popping up in the first place? Or a workaround of some sort to minimize the effect? I am willing to push 18 menu items IF I even want to set a waypoint! It is just something I RARELY want to do, and I touch the screen a LOT and it is annoying as hell!
