Old 11-13-2012, 03:27 PM   #1681
Pyndon OP
Pyndon's Avatar
Oddometer: 2,590
Originally Posted by Tbone View Post
I still remember when you bought this from Steverino. Man I thought you were nuts!
He was nuts selling it to somebody as meticulous as me. I could have sued!
Lyndon Poskitt Racing
Currently racing my way around the world at: www.facebook.com/LyndonPoskittRacing
Blogging at: www.racestoplaces.com
My Dakar Rally Experience
and blog www.LyndonPoskittRacing.com
My KTM 950 Story
Pyndon is offline   Reply With Quote
Old 11-13-2012, 08:25 PM   #1682
Mr Head
PowerPoint ADV
Mr Head's Avatar
Oddometer: 7,828
Lyndon is responsible for me test riding a 990 adventure, then actually visiting a real KTM shop, then spending money there. Then going back and spending more time there, figuring out I need three KTM's!
I think I'll be forced to compromise with one. And now I'm in a muddle over which is the one.
...Dick
"You don't go to Mongolia for the food." - Sebastian & Kim
2010 KTM 990 Adventure R
My Life With The 990R
Smugmug
Mr Head is online now   Reply With Quote
Old 01-11-2013, 11:17 AM   #1683
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,342
Engine rebuild....
Pyndon,
When you get a minute, I have a question:
My bike appears to have the oil-leak-from-the-base-gasket issue like yours. Mine has 40,xxx miles. Should I re-fresh the top end while I have it out and apart, or just fix the oil leak?
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Old 01-11-2013, 11:25 AM   #1684
5 speed
Oddometer: 950
Originally Posted by Cpt. Ron View Post
Pyndon,
PS you might have delayed reply as Lyndon is currently in Chile participating the Dakar!!
info here: http://advrider.com/forums/showthrea...777301&page=65
5 speed is offline   Reply With Quote
Old 01-11-2013, 12:57 PM   #1685
hilslamer
2XRedheadedstepchild
hilslamer's Avatar
Oddometer: 1,786
Pyndon,
He's prolly gonna be a little delayed to reply - he's "busy" right now:
http://advrider.com/forums/showthread.php?t=777301
:cheers
hilslamer is offline   Reply With Quote
Old 01-11-2013, 01:40 PM   #1686
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,342
I've been F5-ing since the start, gentlemen. My sarcasm is apparently a bit dull this week.
Cpt. Ron
Old 01-11-2013, 03:59 PM   #1687
neduro
Addict
neduro's Avatar
Oddometer: 12,052
Just a reminder that his support packages are still available, I know first hand how much it both helps, and means, to sell a few while on the race and realize upon re-entry that your financial picture is slightly less bad than anticipated!
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 01-11-2013, 04:51 PM   #1688
pebble35
pebble35's Avatar
Oddometer: 1,581
+ 1 on that Ned.
Many Ktm riders will have saved a lot of time and hard cash from the advice and information Pyn has kindly taken the time and effort to share with all of us.
a little bit of payback by way of a thank you won't hurt !
Sent from my iPad using Tapatalk HD
Proud to be supporting Pyndon
www.lyndonposkittracing.com
www.bikersjersey.com for all your KTM parts
A 2,400 KM ride around Egypt by Scooter - ride report here
pebble35 is offline   Reply With Quote
Old 01-11-2013, 05:56 PM   #1689
Bgunn
Mucha distancia
Bgunn's Avatar
Oddometer: 1,441
Originally Posted by pebble35 View Post
+ 1 on that Ned.
+2....
Bgunn screwed with this post 01-11-2013 at 07:56 PM
Bgunn is offline   Reply With Quote
Old 01-30-2013, 02:23 PM   #1690
Pyndon OP
Pyndon's Avatar
Oddometer: 2,590
The time might have come! Revised list........
2003 KTM 950 Adventure S - Lovingly cared for by a careful owner, never raced or rallied (much). Full detailed service history (this thread and more!).
89,000 miles
Oil and filters changed more times than I can remember
Engine fully rebuilt at ~65,000 miles with brand new cases and full set of bearings and shells.
Every single engine upgrade / revised part is fitted to this engine
- Crank and flywheel
- Outer clutch basket
- Oil distribution systems and oil rails
- New piston rings
- Cylinder heads fully stripped, inspected and serviced.
- Revised cylinders installed
- New output shaft fitted
- New gear shift fork rollers fitted
- Revised shift drum installed
- Starter clutch system upgraded
- Latest balancer shaft assembly with cylindrical roller bearing
- Valve clearances stable - never move.
Water pump replaced every 20,000 regardless and was done at 80,000.
Engine still on original clutch plates (that's how mechanically sympathetic I am) and still perfectly in spec.
SAS fully removed and billet blanking plates installed.
Later oil tank and revised oil return and breather hoses fitted. New non-return valve and seal fitted.
2nd Fan installed.
Suspension: Full 320mm travel conversion front and rear shock, cost a fortune to develop.
- Increased oil chamber capacity on rear shock
- Orange rear shock spring
- .64 front fork springs, made to fit 320mm travel.
- Valving set-up for 50/50, on / off-road - compromise.
Happy to sell with standard 265mm standard 'S' suspension with 0.59 fork springs.
Fully adjustable side-stand modified to suit any suspension installed.
Large foot on side-stand.
ADV Tank rear fuel tank.
Facet 40171 fuel pump with micro filters.
Emig 20mm offset tripple clamps in black with Emig one-way damper (fully serviced by Emig 5 months ago)
Renthal RC high bars with Cycra Pro-Bend hand guards (even the alloy part of the guards are anodised black).
Black Evolutione clutch slave cylinder
Standard exhaust header pipes with 2-1 link pipe and single Akrapovic Silencer.
G-It black bash plate with tool roll holder.
G-It rear rack
Standard grab handles fitted and bike comes with Touratech (standard KTM) luggage rack and all fittings.
Choice of boxes, beat to shit but still work Touratech Zega's with liners or Gobi KTM plastic boxes.
Crash guards for tanks - choice of three, all scratched and rusted!
Woody's Wheels
- Rad / DID billet hubs in black
- Super heavy duty stainless spokes and nipples
- X3 Superlaced lacing
- 21" x 1.6" Excel A60 front rim in Black
- 18" x 2.5" Excel Rear rim in Black
- Both wheels straight
Brakes
- Braking Wave Rotors front and rear
- Standard front master cylinder with twin discs currently fitted
- My own 1 into 2 brake line rail system with Goodridge braided hoses. No interference with cockpit as the upper part of the brake line does not move, only the lower portions. Works perfect.
- Comes with SE master cylinder and single brake line for single disk running option and more feel off-road
- KTM Sintered pads front and rear - recent.
Scotts shark fin rear disk protection
Recent KTM DID chain and Dirt Tricks Sprockets - currently on 17/42 for road use.
Spare sprocket carrier with 45T Dirt Tricks fitted.
Tyres - black and round, usually pretty worn!
Carbon Tank guards, one side gravel rashed through to tank but did it's job.
Subframe strengthened and powder coated black
Swing arm replaced with latest SE swing arm, powder coated black and fitted with chain guide.
Engine hangers, rear footrests and other stuff powder coated black.
KTM 450 Factory Rally footpegs (longer and meatier!)
Low front fender and high front fender (currently fitted with low fender) with all fittings.
Modified carbs for response and jetted for sea level.
New airbox with my own K&N pre-filter kit installed with spare charger covers.
Fitted with Scottoiler (automatic chain oiler).
Euro light with HID in both high and low beam.
Large rally grips, lock-wires and grip heaters fitted
Garmin Montana and powered / lockable mount
12V heated clothing outlet.
Renazco Racing tall / wide winter road seat (water proof) or +2" Suede seat - both black.
Mousses, tubes, whatever, I have it all.
Probably missed a load of stuff, this is just off the top of my head.
Wants for nothing, if it needs it, it gets it......................
My KTM 950 Story
Old 01-30-2013, 02:47 PM   #1691
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,111
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 01-30-2013, 02:48 PM   #1692
BRUNO BOTELHO
BRUNO BOTELHO's Avatar
Oddometer: 451
Wow
Bruno Botelho
Yamaha MT-09 Tracer - "Dark Side Of Japan"
BRUNO BOTELHO is offline   Reply With Quote
Old 01-30-2013, 02:53 PM   #1693
Grinderman
Grinderman's Avatar
Oddometer: 150
Cry
Say it ain't so....
Grinderman is offline   Reply With Quote
Old 01-30-2013, 04:24 PM   #1694
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,662
Nooooooooooooooooooooooooooooooo!!!!!!!
Why isn't this bike in California??
Scott - Semper Fi
'04 BMW R1150GSA, '05.5 KTM 950 Adventure
Y E T I is offline   Reply With Quote
Old 01-30-2013, 04:53 PM   #1695
5 speed
Oddometer: 950
The end of an era??? We hope not. I have to say I have sold a lot of motorized vehicles in my time and there are a few that I really, really miss and kick myself for selling. Just sayin.....
Course having a rally bike in the garage that finished the Dakar would probably ease the pain a bit.
Times are GMT -7.   It's 06:48 AM.
