Old 01-11-2013, 04:14 AM   #1
nbsdave OP
Oddometer: 335
moving the bike in the garage
space is real tight in my garage
I vaguely remember seeing a pick of some kind of wheeled thing under a centerstand.
Anyone everhear of that?
Would like to move the bike without taking it down off the stand.
nbsdave is offline   Reply With Quote
Old 01-11-2013, 04:28 AM   #2
duck
duck's Avatar
Oddometer: 10,403
http://www.harborfreight.com/low-pro...lly-95896.html
duck is offline   Reply With Quote
Old 01-11-2013, 04:53 AM   #3
AtlantaViking
AtlantaViking's Avatar
Oddometer: 984
Park n Move
I received one of these a couple of years ago as a Christmas gift. Nice liitle cart - works as advertised. I can pivot the bike on the stand and spin it 360 and just move it anywhere.
EDIT: Looks like my pic got nuked - it was a stock pic from the web, must have been a no-no.
Here's the link to the mfg: http://www.legalspeeding.com/Park-n-Move.htm
they have a couple of videos on there that do a good job of showing you how it works.
I'm here to chew bubblegum and kick ass....and I'm all out of bubble gum
06 Suzi DL1K
99 Suzi DR350SE
AtlantaViking screwed with this post 01-11-2013 at 08:49 AM Reason: Pic got Nuked.
AtlantaViking is offline   Reply With Quote
Old 01-11-2013, 05:45 AM   #4
ct-ktm
Oddometer: 3,428
A dolly for a wheeld bike..
I must be one cheap son of a bitch I just couldn't buy something like that ..
If the space is that tight how do you go stare and work on the bike..?
ct-ktm is offline   Reply With Quote
Old 01-11-2013, 06:51 AM   #5
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 1,024
cheap and easy to make.
Yes I am quite serious.
Mike Ryder is offline   Reply With Quote
Old 01-11-2013, 07:49 AM   #6
duck
duck's Avatar
Oddometer: 10,403
http://www.redlinestands.com/catalog...le-dolly-c-115
(Not affiliated.)
Old 01-11-2013, 08:36 AM   #7
nbsdave OP
Oddometer: 335
don't know if you are "one cheap son of a bitch"-sounds like you might be.
When I work on the bikes, I pull a car out of the garage to make room.
When I "stare", I just look around the car, and their they are.
Old 01-11-2013, 09:27 AM   #8
dasrider
Oddometer: 266
If I needed to reorient the bike in a tight space I've always been able to just pivot the bike on the sidestand and swivel it around. Granted, this is with sub-500lb sportbikes. Not sure how well a cruiser or full on touring bike would work with this method.
dasrider is offline   Reply With Quote
Old 01-12-2013, 03:02 AM   #9
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,795
Tip: Have a spare sidestand and mount on hand if you do this with any frequency to a big duallie or cruiser.
Don't try this on the centerstand of a BMW - the stand mounts directly to the engine and cracked cases have been reported by folks doing this.
If you're all about the destination, take a fucking flight. - Frank Turner
Got brap, and twice as much fuel as you. - Akarob
Twilight Error is offline   Reply With Quote
Old 01-12-2013, 05:09 AM   #10
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,630
I use a piece of 16x26" 22 ga galvanized sheet metal under the center stand to spin the bike while on it's center stand. That works fine, but I would not try to slide the bike on galvanized sheet while on the center stand. The park-n-move looks very interesting.
Stan_R80/7 screwed with this post 01-12-2013 at 05:49 AM
Stan_R80/7 is offline   Reply With Quote
Old 01-12-2013, 06:55 AM   #11
RSRennsport
Navigator
RSRennsport's Avatar
Oddometer: 64
If you are a little handy, you can make one yourself. If not, harbour-freight and so many more have all kinds of different devices you can purchase. I made my own rolling lift-table. Its on a lift-table that I can push out of the way if I need to.
Strassen?
AHRMA # 59
RSRennsport is offline   Reply With Quote
Old 01-12-2013, 07:54 AM   #12
duck
duck's Avatar
Oddometer: 10,403
On K bikes that have the CS mounted on the trans you can push down on the rear of the bike and pivot it on the CS. Done it MANY times.
Old 01-12-2013, 08:04 AM   #13
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,721
I've used the side stand to pivot the bike on.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 01-12-2013, 07:16 PM   #14
MiteyF
MiteyF's Avatar
Oddometer: 2,087
Great idea, great execution
People tell me I have a motorcycle problem. I tell them, I may have problems, but motorcycles are the solution.
MiteyF is offline   Reply With Quote
Old 01-12-2013, 07:31 PM   #15
pyrate
Walking the plank
pyrate's Avatar
Oddometer: 1,185
How thick is the bottom plate? And how much weight are you putting on it?
"but why is all the rum gone?"
pyrate is offline   Reply With Quote
Times are GMT -7.   It's 01:30 PM.
