Old 01-10-2013, 08:30 PM   #1
Jdeks OP
Oddometer: 297
Idle drop after revving.
Hi again all,
I'm putting my bike back together, after having done a lot of service work (valves, new oil regulator, cam chain tensioners) and also I've switched to a 2 to 1 exhaust, and installed Pyndons prefilter. I'm using a jetting config that he recommended for it (nothing special really, actually pretty close to stock).
It starts fine, idles fine, revvs fine. No smoke from the exhaust. But when I rev it hard and then let it off, the idle drops low (about 1000rpm) for a few seconds then slowly recovers. Sometimes, if its a really fast on/off throttle snap, it dies on the way back to idle. It pops a little on its way back down the revs, but thats normal I believe.
Any ideas?
Jdeks is offline   Reply With Quote
Old 01-11-2013, 05:42 PM   #2
Jdeks OP
Oddometer: 297
Anyone?
I've checked carb sync, calibrated the TPS, checked the carbs are seated properly.
Old 01-12-2013, 04:27 AM   #3
Jdeks OP
Oddometer: 297
Okay, I think I fixed it. Swapped out my new fuel filter for my larger old one - seems it was restricting fuel flow.
Got a new problem now though...
Old 01-12-2013, 04:35 AM   #4
GSAragazzi
GSAragazzi's Avatar
Oddometer: 441
Not a Hijack
But I'm also waiting for someones suggestions bc my bike starts, runs well but after 5 min it starts to sputter and then dies. Push and push the magic button and nothing. If i wait 5 min it starts but sputters, give gas and dies. The only thing I've found helpful is to let the bike fall on its side (clearing whatever the problem is) and then it starts and back to square 1.
I'll ck my fuel filter, so thanks.
Anyone out there with any suggestion?
"The Only Easy Day Was Yesterday"
GSAragazzi is offline   Reply With Quote
Old 01-12-2013, 04:45 AM   #5
Jdeks OP
Oddometer: 297
My fuel filter was a custom one I installed myself.
I would check your fuel pump - have you opened it up and looked at the contact points?
Old 01-12-2013, 05:13 AM   #6
Deepc
Oddometer: 267
It sounds like your fuel pump might be on its way out. There are a bunch of upgrade options out there. I used the dr. beans kit. Its cheap, simple to install, and was delivered in about 1 week.
Deepc is offline   Reply With Quote
Times are GMT -7.   It's 08:18 AM.
