Old 01-09-2013, 05:44 AM   #106
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,965
Originally Posted by JimVonBaden View Post
It was Christmas!
Took it to the garage and played with some of it.
A bunch of farkles for the bike, and new brakes for the wife's car. I'll be busy this weekend!
Jim
I added a couple more farkles.
Helmet lock off E-bay. Not particularly cheap, but necessary.
I also added a couple yellow conspicuity lights.
Cheap CREE 15 watt yellow lights.
I added a switch for temporary. I plan a better one when I do the Fuzeblock.
I know, but they are ridiculously light, and I am trying it out. I have some spare turn signal stalks.
They really put out. I doubt all that much down the road, but I bet people will see me, even if they don't see my turn signals!
Alternate mounting locations are in the future when I add the driving lights.
I also mounted and wired up, temporarily, my USB plug. Very nice Pieces, and should work great!
Jim
Old 01-09-2013, 10:24 AM   #107
RoyQ
RoyQ's Avatar
Oddometer: 2,185
I have been building this track monster since Nov '12
Started out as a nice street bike
Few weeks later stripped of street creed
Suspension upgrades, 30 mil Thermosman tweaked Ohlins cartridges in front forks and a massive JRi rear shock added.
Vortex rearsets and Spiegler brake lines added
Vortex engine guards added
Race bodywork added, but I still need to add decals, stickers and numbers once paint cures.
It's a mean mutha, ecu tuned and it's not short on power. I still have to add the quick shifter with map up to ecu and CRG black shorty levers. 8 weeks is the inaugural run at Talladega GP in Al. Then Barber in April. Day in the life of a GSXR1000.
2012 YAMAHA Super Ténéré
'11 GSXR750
'11 GSXR1000 racebike
WERA Expert #826
RoyQ screwed with this post 01-09-2013 at 10:41 AM
RoyQ is offline   Reply With Quote
Old 01-10-2013, 05:10 AM   #108
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 7,002
Way cool project.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc is offline   Reply With Quote
Old 01-10-2013, 05:38 AM   #109
Sir. Waffles
Sir. Waffles's Avatar
Oddometer: 116
Jim
Where did you get the USB socket from??
Sir. Waffles is online now   Reply With Quote
Old 01-10-2013, 06:41 AM   #110
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,965
Ebay, these guys: http://www.ebay.com/itm/251122104452...84.m1439.l2649
Just keep in mind that it needs to be put on a circuit that has no power with the bike off. It is lit, and draws a small amount that could kill the battery over many days.
Covered.
Jim
PS I tested it yeaterday and it works great, even in the rain!
Old 01-10-2013, 06:44 AM   #111
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,965
Made this last night:
Jim
Old 01-10-2013, 08:30 AM   #112
kubiak
Oddometer: 4,829
nice headlight protector!
Old 01-10-2013, 04:52 PM   #113
Sir. Waffles
Oddometer: 116
Covered.
Jim
Thanks, I've seen them around but been trying to find a cheap place to get one. Still over priced for USB in my mind but better than 40 plus shipping at other places.
Old 01-10-2013, 06:11 PM   #114
kubiak
Oddometer: 4,829
on my bmw tw650 i put some bar risers, shortened the kickstand an inch since i put a lowering link on a few days ago and a helmet lock.
Old 01-10-2013, 06:24 PM   #115
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,965
Yeah, I looked everywhere for this kind of flush mount USB with two plugs. This was the best I could find. High quality to be sure.
Jim
Old 01-11-2013, 05:24 AM   #116
RoyQ
RoyQ's Avatar
Oddometer: 2,185
Sticker fairy arrived yesterday
The GSXR is just about complete!
'11 GSXR750
WERA Expert #826
Old 01-11-2013, 08:02 PM   #117
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,965
I wanted both conspicuity lights (see above), and driving lights. I also wanted to move the conspicuity lights lower so they didn't wash out my turn signals.
This was my cheap solution:
Using 1" by 1/8" flat bar I formed this:
Checking for clearance I zip tied it in place.
The center section is 11" long, with a 1.5" drop and 4" mounting surface for lights. It is quite stiff as is.
Being cheap, I made my own "J" bolts from long bolts I had in the bin.
I wanted to bed liner paint it, but had run out, so I used Plastidip. It was really too thick, but should be OK for now. I have plans for a slightly improved unit in the future.
Mounted to the beak frame with J-bolts. As far forward as possible. This gives the forks about an inch of clearance at full lock.
The conspicuity lights are mounted low, and the driving lights high. (Yes, I would have prefered black light housings for both, but they were cheap.) I used the same bolt, loctited, for both lights.
Front view. Looks like this should work great!
I will wire up the lights when I receive the fuse box next weekend.
Jim
Old 01-12-2013, 06:18 AM   #118
walkingbear
walkingbear's Avatar
Oddometer: 3,548
Friday
finished re organizing the tool box and purchased a rivet gun to
redo some of my seats,
Question to the audience : Can I use led driving or spot lights with a home 12v landscaping system.
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is online now   Reply With Quote
Old 01-12-2013, 09:15 AM   #119
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,965
Most of the LED lights are able to handle a variety of voltages. Mine are good from 9-80 volts. You can get them dirt cheap on E-bay too!
Jim
Old 01-12-2013, 02:20 PM   #120
JimVonBaden OP
"Cool" Aid!
Oddometer: 52,965
Brakes, pads and rotors, on the wife's Rogue.
The rotors were not much out of new spec, about .02", but there was a high speed vibration when braking from about 50+ lightly. Not bad wear for 38K miles, and a lot of in town driving by a heavy braking foot.
Polished out several door scratches, and cleaned the garage for the next project.
Jim
Times are GMT -7.   It's 01:27 PM.
