Old 01-12-2013, 12:32 PM   #1
mixermsk OP
Oddometer: 42
Second Fan: BDCW vs AdvMachines
I want to install a second fan on my 990 Adv. On the internet I found the options from two manufacturers: BDCW and AdvMachines. Is there a any significant differences?
mixermsk is offline   Reply With Quote
Old 01-12-2013, 04:35 PM   #2
KTMADV
Hammer Down
KTMADV's Avatar
Oddometer: 174
Here is what else you could use. I just got a Spal 5.2 pull fan off ebay for $ 50 and installed it. The New Spal fan is the same size as the stock fan on the left side. Its a perfect fit. I like the fan better more air flow then the other two fans plus cheaper. Here is a link of my fan set up.
http://advrider.com/forums/showthread.php?t=837674
Ceasar Vasquez
KTMADV is offline   Reply With Quote
Old 01-13-2013, 01:23 AM   #3
Deepc
Oddometer: 299
I have the BDCW aux fan. Easy install. She works like a charm.
Deepc is offline   Reply With Quote
Old 01-13-2013, 05:00 AM   #4
Jaimoto
Spaniard in Chile
Jaimoto's Avatar
Oddometer: 1,256
I have the AdvMachines aux fan. Easy install. She works like a charm.
Too.
Jaime
Big, Loud and Orange KTM 990 Adv
Jaimoto is offline   Reply With Quote
Old 01-13-2013, 08:50 AM   #5
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Laugh Fan Switch
whichever route you go opt for the lower temperature-actuated fan switch (goes into right hand side of radiator)
this helps keep the temps down for sure- fan comes on sooner, but doesn't stay on long as it the engine/cooling system has accumulated less heat to shed. Without the sensor change both fans will run but run much longer, which (assuming you are riding slow/offroad which is where the additional cooling is REALLY needed) will be hard on your battery as the alternator isn't spinning fast enough to keep the voltage up.
I used Ken's AdvMachines kit as that's all there was at the time- and while saving a few bucks is always nice I'd rather give my $ to ADVRider-supporters (both BDCW & AdvMachines) and not somebody out of the loop.
If you do go fleabay then consider donating to ADVRider itself, Baldy is one hell of a guy to have created & hosted this site for us for years & years, all at his expense
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 01-13-2013, 09:38 AM   #6
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,811
[QUOTE=geometrician;20472088]whichever route you go opt for the lower temperature-actuated fan switch (goes into right hand side of radiator)
/QUOTE]
Linky?
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 01-13-2013, 01:45 PM   #7
mikeegee
Oddometer: 306
I found replacing the stock temp switch didn't allow the radiator and thermostat to do their jobs, and the fans actually ran longer than when I switch back to stock.
Love the 2 fans though.
meh
mikeegee is offline   Reply With Quote
Old 01-13-2013, 03:14 PM   #8
zeegman
zeegman's Avatar
Oddometer: 386
Lower tempThermo switch
[QUOTE=FakeName;20472389]
/QUOTE]
Linky?
http://www.ktmtwins.com/ktm-950-990-...rmostat-switch
MZ
zeegman is offline   Reply With Quote
Old 01-13-2013, 03:47 PM   #9
DuctTape
Oddometer: 351
They would run longer/sooner since the switch is set at a lower temperature then stock. This is a good thing.
2013 KTM 690 (Thanks FLHRCI Buyer! )
2011 990 Adventure Dakar (Thank you Honey!)
2010 Aprilia RSV4 Factory
2010 Ducati 1198S
DuctTape is offline   Reply With Quote
Old 01-13-2013, 08:15 PM   #10
up2nogood
Oddometer: 66
I went BDCW as it came with all wiring and bracketry.
If you're a bit more hands on, the SPAL and cable ties is also a winner.
Help out the people from the countries we love to ride through:
http://www.kiva.org/invitedto/advent...er/by/alex9291
up2nogood is offline   Reply With Quote
Old 01-14-2013, 03:11 AM   #11
mikeegee
Oddometer: 306
I'm not sure why running longer or sooner is a good thing.
If the radiator isn't being given a chance to do its job then I'm just using the fans to do the same work. When given the chance to do its job then the fans runs less frequently and shorter than they used to.
Where the single fan ran for ages sitting in traffic, even on very cool days, the double fans run for a fraction of the time. Since coming back from CJs tech weekend the bars haven't gone to more than 5, even once.
meh
Old 01-14-2013, 08:01 AM   #12
Failo
Is it spring yet???
Failo's Avatar
Oddometer: 176
Shroud?
Question for you guys that have installed a second fan: What did you do, if anything, about installing a shroud similar to the left side fan?
I just installed my ADVmachines fan and still have the tanks, etc off. I'm wondering if I need to install some sort of shroud to direct the hot air away from the right tank.
I'm very impressed with the bracket and electrical connectors that came with the ADV fan. The installation could not have been easier (with both tanks off).
Failo is offline   Reply With Quote
Old 01-14-2013, 08:09 AM   #13
Deepc
Oddometer: 299
heat shroud
I used some quarter inch thick adhesive backed heat shield material I purchased online. So far so good.
Old 01-14-2013, 08:13 AM   #14
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,050
pfdskipper is offline   Reply With Quote
Old 01-14-2013, 09:11 AM   #15
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,046
Laugh
I used the ADVMachines kit simply because I did not know BDCW had one at the time. I wouldn't hesitate to use either.
I did nearly 18,000 miles around the country this last summer and had a couple of overheating issues when running slow on trails. Never had a problem running down the freeway, even in 116* heat.
So to cure the slow running overheat issue, I rode faster...unfortunately that created other issues so I installed the second fan a and lower thermostat. Haven't had another over heating issue.
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Times are GMT -7.   It's 12:48 AM.
