01-11-2013, 03:07 PM
#4291 |
Verbose Adventurer
Oddometer: 239
01-11-2013, 04:26 PM
#4292 | |
Oddometer: 421
'10 Multistrada 1200 Std ('11 - current) '07 Super Enduro 950 ('12- current) '02 Superhawk (37k miles, '02-'11) '96 KLX250R - kind of street legal - ('97 - current) '90 KLR 650 Tengei ('95-'97) |
01-12-2013, 01:59 PM
#4293 | |
Oddometer: 17
Hadi canim yandan yandan. Biz korkmayiz ondan bundan... |
01-12-2013, 04:00 PM
#4294 |
Oddometer: 123
He said he can't move the multistrada. He still had 2012s. He said I am in a GS area (they sell bmw&ducatis) the dealer is
http://www.championhondabmw.com/ They are in charleston South Carolina. I called & talked to the manager & asked him if he would sell me 1 @ invoice & he said yes. I then looked around for the invoice=17k.
2007 Honda Shadow Aero 750, 1999 Ducati 900 Super Sport,1992 Harley Davidson FLHS,2005 Honda Ruckus (scooter trash),2010 A2B Electric Bike, Being a inmate has perks=Dealer pricing on alien blood oh I mean Amsoil ![]() http://www.amsoil.com/a/synthetic-motorcycle-oil The link shows retail pricing so you can check vs my dealer price quotes.. PM me |
01-12-2013, 04:08 PM
#4295 | |
Malta,NY(Saratoga Spring)
2013 Multistrada 1200ST 2008 Yamaha WR290R "ANYWHERE" 2001 Kawasaki W650 2011 Husaberg FE 390 '07 Mutant Ninja II (sold)click for build report |
01-12-2013, 04:21 PM
#4296 | |
Oddometer: 123
Not when I was there in October & November. He had two 2012s...Unless they were in the back & I asked him if this was all they had & he said yes. I think their website needs a update but It would still be worth a call
01-12-2013, 06:23 PM
#4297 |
Oddometer: 17
Awesome. I will contact them on Monday. Hope they will ship it to where I am right now, denver, co.
01-12-2013, 06:25 PM
#4298 |
Oddometer: 123
Ummm good luck with shipping cross county. What are your local dealers offering you?
01-12-2013, 06:31 PM
#4299 | |
Oddometer: 17
I just sent an email with my phone number. Hope it works out! |
01-12-2013, 06:44 PM
#4300 | |
Oddometer: 17
So, even though I pay for the shipping, I am quite sure it will be cheaper than buying here. |
01-12-2013, 06:52 PM
#4301 | |
Oddometer: 123
01-14-2013, 06:02 AM
#4302 | |
Oddometer: 286
Since I haven't updated the spring rates, I've increased the preload and adjusted the compression damping. The changes have resulted in less pitching (squat and dive) but then made the fork much more harsh over small but sharp bumps that seem so prevalent in Houston. The sharp bumps are due to the road heaving up, really are transmitted up to the rider with my current set up. The good part is that the excessive fork dive problem when braking has been fixed. I'll take short jarring bumps every once in awhile over diving at every brake application. I've also increased the fork oil weight, to I think to 10wt instead of 7wt to help resist the forks blowing through the entire stroke when coming down from wheelies. The change in oil weight helped, it doesn't blow through as often now. With some effort, I could correct these problems at the next service by installing the correct fork springs for my weight and increasing the amount of oil, by about 10mm. I'm on the fence about the oil weight 10 or 7. I just need more oil so it firms up for the last half of travel. At least this what I seem to remember what adding oil does to front suspensions. I would say a cartridge kit is more of a luxury. I've given it serious though, but when it comes time to but my money where my mind is I always back out. Please keep in mind most of my usual miles are commuting. For touring, the changes I've made are more than sufficient. For washboard gravel roads, they are too harsh. But then again that's less than 1% of my riding. I've been very happy with the BASE shock, a sachs unit? I only need to update the spring rate as well. I've increased the preload and rebound damping. |
01-14-2013, 06:07 AM
#4303 | |
Oddometer: 286
Thanks for the response and write up. I was only mildly interested in a cruise control, which I would use only for my true long distance rides, for getting out of Texas and going some place fun. Since I have the full race termi's the reflashing the ECU might cause a problem for me. Perhaps, the map Waynes supplies is better? I'd have to contact them about this. Anyways, how do you actually activate and control the CC? Do you use the stock handle bars controls? Does anything show up on the dash? Thanks again! |
01-14-2013, 08:55 AM
#4304 | |
Tryin' to get home..
Oddometer: 911
Tuneboy cruise control
I was gonna write up an article documenting my Tuneboy cruise control install, but the fact that I had to wait a week to get the correct files kind of bummed me out, so I didn't. Now I'm getting enough questions about it that maybe I should write it up...
You activate the CC using the "start" button. Yep, the same one that controls the heated grips. And yes, the CC and heated grips "interact" in a sense, but everything works OK. No display of any kind. --Doc Quote:
2010 Ducati Multistrada 1200S (RIP...but REBORN) 2006 Buell XB12X Ulysses 2000 Kawasaki KLX300R 1992 Ducati 900SS |
01-15-2013, 05:38 PM
#4305 | |
Oddometer: 1,112
Hi NMEXPAT, thanks for your comments on the stock fork. Sounds like it works quite well.
I am leaning more and more towards picking up a 2013 base model. If the suspension is okay or better then I could ride it around quite happily while waiting for the Ohlins semi-active kit to come out. Then could decide whether to go for that package, or fit a manual Ohlins shock and a fork kit, or just the manual shock, or simply leave it alone (at least until the stock shock wears out). The full Ohlins package obviously will be very good (even if not Skyhook), and of course could be removed and sold separately at new bike time, or likely removed and fitted to another Multi if/when Ducati releases a fresh upgrade. BTW: from Ducati's promotional material on the web, it appears the 2013 base model will come with the same 85-125N/mm progressive rear spring that they are fitting to the Skyhook bikes. If they make that available as a spare part, it could be a good upgrade for prior-year base models. On your fork dive thing, if it were me, I think I'd be going up a size on the front springs and sticking with the standard weight oil. And I'd be simply riding around what brake dive remained. It is built into the design. Sure, you can control it by adding so much spring that the fork behaves like a short-travel sport bike fork, but then you've got the height of the long-travel Multi without the plushness that the long travel provides. Or you can firm up the low-speed damping by adding viscosity, as you have, with a similar effect: less brake dive but harsh high-speed damping that jars you on sharpish hits. As you have likely worked out, that is one conflict that Skyhook helps resolve. Quote:
Sorting out the S4Rs Ohlins shock: click here. |
