Old 08-11-2012, 05:10 AM   #76
mcma111
mcma111's Avatar
Oddometer: 12,563
Steering Stops
The steering stops didn't work for me so I welded one on. Right below the wiring harness loop. This is on my XR600 but the same as the XRL with CRF triples
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 08-11-2012, 05:42 AM   #77
elsalvadorklr OP
southern xr rider
Oddometer: 4,154
Originally Posted by Cumbacheech View Post
Hi Christian,
Was just wondering if the steering stops work for you.
hey man
worked perfect for me, but do notice I have a smaller clarke tank now and not the big ims4
had to do nothing and turning radius is maybe a teeny smidge less than before...
hows yours coming along?
elsalvadorklr is offline   Reply With Quote
Old 08-22-2012, 09:08 AM   #78
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Originally Posted by elsalvadorklr View Post
hey man
Mine is coming along... Just have not had a chance to even look at the bike, been super busy with work. I am aiming to have it all together this weekend so that I can start riding it!
Cheers,
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 08-22-2012, 09:20 AM   #79
elsalvadorklr OP
southern xr rider
Oddometer: 4,154
hey I posted on your thread
you just need to hammer the lock washer flat, enlarge the hole and align it so the tab sits back like stock
then when the top clamp is on you can lift up the tab
basically stock the lock washer is not big enough to be able to flip up so it rests uneven on the actual lock nut.
so just do that and you be golden
good luck!
Old 01-02-2013, 08:49 AM   #80
edgeman6000
Oddometer: 7
just wonderin... any of you use the xr wheel after you did the swap? i got a brand new rubber on my 3 month old excel supermoto wheels. anything can be done with the correct spacers/bushings etc. just wondering if any of you have done this. thanks in advance, dan
edgeman6000 is offline   Reply With Quote
Old 01-12-2013, 05:07 PM   #81
heart_of_darkness
Location: lifting an XR600 from the NJ Pine Barrens sand
Oddometer: 99
I made spacer bushings for both sides of the XR axle. I also had to space the brake caliper over with a few washers between the caliper mount and the fork. It did work, but was a hassle to assemble. I bought a proper CRF wheel soon after.
heart_of_darkness is offline   Reply With Quote
Old 01-12-2013, 05:08 PM   #82
heart_of_darkness
Oddometer: 99
What is everyone doing about the too-long CRF forks? They're nearly an inch longer than the XR forks.
Old 01-12-2013, 05:18 PM   #83
thebigman
bout a dollar 3.98
thebigman's Avatar
Oddometer: 3,523
I let em stick thru a bit , works fine .
Marko
08 xr650l ,99 xr650l, 10 HDXR1200X ,84atc200s 85atc200s, 80ct110 ,99xr70, 04xr650l ,
Dumb ass people do dumb ass things
thebigman is online now   Reply With Quote
Old 01-12-2013, 06:03 PM   #84
elsalvadorklr OP
southern xr rider
Oddometer: 4,154
^^^^^yuppers
play with them...go up and down and see what works best in dirt...
for example put the forks 2 inches from top...you will notice it turns like a beast carves almost too well!
but at speed you will wobble like crazy
the push them up all the way flush and it will be choppered out and smooth on the highway but it will suck even more than the stock forks when it comes to turning
this is commonly caused "pushing"
if you cant find a happy medium then you need to look at correct springs for your wieght and usds forks...
cheers
Old 01-13-2013, 05:19 AM   #85
taco250
wannabe adventurer
taco250's Avatar
Oddometer: 1,329
You can also shorten them internaly but I don't remeber how it's done. Bprt4 did it to his.
Prov 3:5 & 6
www.benddualsport.com
300+ mile Paisley OR day ride
taco250 is offline   Reply With Quote
Old 01-13-2013, 09:38 AM   #86
elsalvadorklr OP
southern xr rider
Oddometer: 4,154
true too...a bit expensive however...
Old 01-19-2013, 04:49 AM   #87
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
Originally Posted by mcma111 View Post
Same old, same old. Gave the XR600 a bath today. Boy oh boy it sure is purdy. Maybe I should take it's picture some day.
Take it's picture? Maybe you should ride it!
XR650R Plated Supermoto
XR628R Plated and highly modified
CR500R Still rips after all these beers
RZ350L Kenny Roberts Special
BMW R1200GS Adv Kind of a space ship
XRider is offline   Reply With Quote
Old 01-19-2013, 04:52 AM   #88
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
Two words, sah-weet!!
Old 01-19-2013, 07:23 AM   #89
mcma111
mcma111's Avatar
Oddometer: 12,563
Kinda slow on the pick up here eh? My post was from May of 2012!!!
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 01-19-2013, 10:57 AM   #90
XRider
Almost Lifelike
XRider's Avatar
Oddometer: 1,283
Give me a break, I've been away fighting cancer. I should add that I've beaten it. However, this doesn't take away from the fact that you should be ridding your Big 6 not shooting pictures of it!
Times are GMT -7.   It's 07:25 AM.
