Old 01-09-2013, 04:46 PM   #181
RedRaptor22
Oddometer: 155
It may or may not be possible depending on chain and sidestand locations but for bulletproofing those pegs I think making them a single unit like on the old way back bikes were they bolted them to the cases would probably be the strongest and most inconspicuous solution, plus that cross bar would give you something super sturdy to mount the rear of a skid plate to.
RedRaptor22 is offline   Reply With Quote
Old 01-11-2013, 05:56 PM   #182
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,691
There isn't anything below strong enough to mount the bar like you describe def don't want to risk the oil pan or lower case. I'm 230#
Spent some time with one of my favorite tools, the JD2 hydraulic tubing bender. Originally I tried to bend it all out of one piece, but that was not happening. So I had to make it out of two pieces and add another weld.
I finally hooked up my air compressor so I can run the cylinder off air, much faster (and noisier) than pump the jack by hand. The material is 3/4" 6063 pipe, which is 1.05" OD for the astute observer. My 1" tubing die grabs the pipe slightly and grooves it, but it's pretty minor. Certainly not enough to make me spend $175 on the correct die.
The final mockup after some fast and dirty welding
Originally I was going to make the racks from steel and weld them to the frame, but with the aluminum rotopax holder I made it just makes sense to weld the whole thing from aluminum and bolt it. Just the hoop I made weighs almost a pound less (0.845 lbs) using aluminum vs steel. And I'm on a diet with this bike.
I will probably remake these hoops once I get the Wolfman luggage in hand I was just anxious to bend some metal today.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 01-12-2013, 12:22 PM   #183
RedRaptor22
Oddometer: 155
Originally Posted by sailah View Post
There isn't anything below strong enough to mount the bar like you describe def don't want to risk the oil pan or lower case. I'm 230#.
I was'nt very clear lol, I did'nt mean actually mounting them to the cases like back in the day, mount them to the original rear set tabs on the frame like in the picture that Sanjoh posted, in addition run a brace or tube between them to make them a single peice with four bolts rather than two pieces with two bolts, should help spread any impact they may take in a crash or something.
That is if it's even possible without interfering with the chain routing or sidestand...well could modify the sidestand with a horseshoe to fit around the brace.
Old 01-12-2013, 08:14 PM   #184
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,691
Gotcha. Might just look into that. I hope the exhaust wouldn't get in the way and I think it will unfortunately. I def plan to make something similar to KTMKLX but will weld it to frame and brace it underneath with a triangle or tube. I think to go clear across would end up in the same real estate as the header.
Spent the entire day in the shop. You all know me well enough to know there should be pics. Well, there aren't
I'm embarrassed by my frugality to show the pics of the STUPID FRIGGEN fender mounts it took me all day to make and I gave up on. I hope I am worth minimum wage because that's about what I was making today. Lukas, I owe you a beer...
Then the only other thing exciting I did was cut the seatpan and glass it with epoxy. I'm sure you can deal without seeing glue dry right? The epoxy really seems to grip the plastic I was surprised.
Since I am now lengthening the seat, cutting the tank is unavoidable. I hope this one goes better than the last one...
Nessmuk
Old 01-12-2013, 08:29 PM   #185
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,184
...I'm sure you can deal without seeing glue dry right?
I'd probably skip the video.
Luke is online now   Reply With Quote
Old 01-13-2013, 05:14 AM   #186
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,691
But it's in HD??
Nessmuk
Old 01-13-2013, 02:33 PM   #187
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,184
But it's in HD??
Hmmm.
Will it have you and some friends in the background throwing temper tantrums?
Iron City Choppers would be awesome.
Old 01-23-2013, 07:26 PM   #188
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,138
Old 01-24-2013, 07:12 AM   #189
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,691
Lots of new parts rolling in, I got a rally fairing from lithuania, composite parts from rhode island. Been whacked with the flu and no energy
Nessmuk
Old 01-24-2013, 08:32 AM   #190
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,170
Slacker
JK, get well soon Pete, we're all just bored shitless (well those of us in New England are at least) since we can't go riding.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 01-24-2013, 09:50 AM   #191
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,691
Originally Posted by Mercury264 View Post
Slacker
Haha I was riding dirt last weekend
Nessmuk
Old 01-24-2013, 09:52 AM   #192
Mercury264
Mercury264's Avatar
Oddometer: 22,170
You. Suck.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 01-30-2013, 05:00 PM   #193
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,691
So some parts rolled in. I'm a little stalled out on this silly seat pan right now and it's sapping my motivation. I need to push through so I can get moving on the big parts remaining.
I did get the rally fairing from Lithuania and I really like it. Don't think it's going to require much to fit up to the bike.
Also got my new saddlebags from Wolfman. I dig these too. I do like aluminum bags but I think these fit the MO of the bike better.
I took tomorrow off so I plan to get cracking on the rest of glassing up the seat pan. Then I can start on the tank.
I'm also going to try and tackle laying out the rear sets and drawing the parts up in CAD to have them cut. I'll post up the results from tomorrow.
Nessmuk
Old 01-30-2013, 06:49 PM   #194
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,606
That fairing is *very* cool looking. What headlight is it designed to work with, or ar you on your own in that regard? Can you post a link to the seller?
Suck, Squeeze, Bang, Blow
Roadracer_Al is offline   Reply With Quote
Old 01-30-2013, 07:07 PM   #195
sailah OP
Lampin' it
sailah's Avatar
Oddometer: 5,691
Al,
It's designed for a BMW X Challenge. Same thing (I think) that Colebatch used on his Sibersky trip. Super nice guy selling them from Lithuania, I ordered it and had it within a week.
This seller ( I think he;s the original) isn't selling any framework so lights are your own design.
http://www.advrider.com/forums/showthread.php?t=622796
There is another seller that I believe bought the molds from the original guy who is the one who set up Colebatch.
http://www.advrider.com/forums/showthread.php?t=856311
His setup uses Infiniti FX-R HID lights which are true projector lights. I have a pair from a previous project. I also have some 90mm Hellas that are HID but I think I am going to try and run the Infinitis.
I thought about buying the nav tower etc but he said it won't work and I'd be spending probably north of $500 on something I would have to modify. I know I can design one out to fit my bike exactly and have it cut and then weld it myself for WAY less so i decided to just buy the glass.
I really like the look of it, I have been looking for examples of rally fairing to copy for awhile now and when I saw this one I said that's the one. Cost me $307 shipped to my door but there is no way I could make one that nice even if I had all the time in the world. Some things are better to just pay for.
Here's one a inmate did an excellent job on his XChallenge
Nessmuk
Times are GMT -7.   It's 10:07 AM.
