Old 01-12-2013, 10:30 PM   #121
MarGyver
Ruteros De Chiapas
Oddometer: 38
Extra gas bottle holders
I just installed a double bottle holder for extra gas and an other for water from Touratech in my Jesses, one cheap top case (just 40 dlls) too, decorated with some touratech and Max BMW stickers.
Gerardo M. Mar
MarGyver is offline   Reply With Quote
Old 01-13-2013, 12:48 PM   #122
henrymartin
Mr. Tourguide
henrymartin's Avatar
Oddometer: 3,688
So, I decided to get off my ass and start working on the WR250R. There are a few things that should be arriving next week: rad guard, skidplate, new turn signals and taillight, and a tank bag. These are things that I cannot make or the cost of making them would make it more expensive than purchasing them. But, since I like to make stuff, I decided to make my own tail rack.
I started with a clean tail and a piece of scrap, 1/4" aluminum.
First order of business was to remove the tail and secure wiring away, then drill four 5/8" holes through the fender. Yamaha conveniently mark the hole locations on the plastic fender.
With the holes done, I made a cardboard template, roughly the size of the final product. I then cut the aluminum to shape, and started working on the final design.
Next, I decided to make some holes for loops to use when securing cargo to the rack. I marked the holes, drilled them, and cut the rest with a saw. Cleaning these up was a real pain (with a file and sandpaper), but I needed to make sure there was a nice, smooth bevel so the straps wouldn't get cut.
The four holes in the plate are not the mounting points. They will be used to either attach something to the rack (like a Rotopax) or just enlarged to get rid of some weight. I had to drill four additional holes in the rear that are used for mounting. Now I'm just waiting for some tapered stainless steel bolts to attach it. For the time being, the plate was attached with plain hex head bolt to ensure proper fit.
The rack rests on 5/8" aluminum spacers that raise it above the fender by about a 3/4 of an inch.
henrymartin is offline   Reply With Quote
Old 01-13-2013, 06:30 PM   #123
biensur22
biensur22's Avatar
Oddometer: 179
I've been restoring an old snapon tool box.
Before
Work in progress:
Just painted the last 2 drawers today, should have it back together tomorrow.
Current Rides:1998 KTM 620 Adventure
Past Rides: 1994 KTM 400 EXC WP/D LC4 - Plated; 2001 BMW F650GS Thumper; 1970 CB175; 2003 KLR250
biensur22 is offline   Reply With Quote
Old 01-13-2013, 06:32 PM   #124
CaptTeach
Oddometer: 209
I got on top of the office and chased down the leaks that are keeping me from being able to finish out the sheetrock and therefore my office - Now just need to wait on the weather to break so I can fix them!!
CaptTeach
96 Heritage Softail Classic
89 XT 600
71 CB 200 Cafe Racer
70 CL 100
63 Sporty XLCH
CaptTeach is offline   Reply With Quote
Old 01-13-2013, 06:47 PM   #125
JimVonBaden OP
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,776
Fess up, you drilled the first four holes in the wrong place!
Looks good!
Jim
Old 01-13-2013, 07:19 PM   #126
cotrailrdr
Oddometer: 84
Walked into the garage. Looked at the thermometer which read -2 degrees. Went back in house.
2013 KTM 300 XC-W
2007 Yamaha WR450F, plated
2005 KTM 950 Adv
2004 Beta 270 Rev3
2013 Polaris RZR 800
cotrailrdr is offline   Reply With Quote
Old 01-13-2013, 07:20 PM   #127
WhiteShark
Oddometer: 19
Where did u get that top case? Been looking around and don't really like what I'm seeing,looks good with the jesse's. wich is what I have.
WhiteShark is offline   Reply With Quote
Old 01-13-2013, 07:53 PM   #128
ride2little
MoveAlongNothingHere
ride2little's Avatar
Oddometer: 1,966
Yesterday...
Washed the bike OUTSIDE the garage, then rolled it in...
Pulled the bodywork off my F800GS.
And that's where it began.
Flushed brake system
changed oil/filter
R&R's spark plugs
New air filter.
Flushed radiator/new coolant.
Cleaned all of the air box, intake, usually hidden plastics. LOTS of dust in there.
Buttoned everything back up, installed bodywork and admired my job.
What i didn't do, was put the new fork springs and go with the heavier fork oil. Was going to do that TODAY, but it's where if finished off the coolant swap.
Forks can wait for another day. But one very soon.
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
ride2little is offline   Reply With Quote
Old 01-13-2013, 08:23 PM   #129
henrymartin
Mr. Tourguide
Oddometer: 3,688
Looks good!
Jim
Actually, you are somewhat right. I first drilled the four holes. Then I thought long and hard about how to design this thing. Then I decided to make a template out of cardboard, which I did. Once I put the template over the ONLY piece of 1/4" aluminum I had, I needed to either put the mounting holes elsewhere or shorten the rack. I decided to keep the rack the size I designed it, so the holes became obsolete.
Hey, if I don't count my time, it was a free rack. Really, it was just an excuse to get away from the family for a bit and have some alone time.
Old 01-14-2013, 05:11 PM   #130
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,228
It appears to be an Emgo. Google around and you'll find it.
No idea where/how he got it for $40, but maybe he got it used or someone had a screaming sale.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 01-14-2013, 05:12 PM   #131
D.T.
Difficult but useful
D.T.'s Avatar
Oddometer: 11,631
Thumbs down
Nothing.
Originally posted by burgerking So?
Holland is about the most expensive country in Europe when it comes to bikes and fuel..Stop whining and go riding It's just money and you only live once...
D.T. is online now   Reply With Quote
Old 01-14-2013, 05:37 PM   #132
MarGyver
Ruteros De Chiapas
Oddometer: 38
I know, I found it in a Mexican web sales page, http://articulo.mercadolibre.com.mx/...-universal-_JM
less than 40 US Dlls and I really like it, is Alessia brand and it does have the same shape on top and base than Jesse's. and fits one helmet in it.
Gerardo M. Mar
MarGyver screwed with this post 01-14-2013 at 05:55 PM
Old 01-18-2013, 12:44 PM   #133
Vankaye
n00b on the move
Oddometer: 225
i have added two more bikes to the stable. My wife's (new to her) XT225 has been up on the lift getting an oil change,
filter clean and new chain and sprockets. As well as a througough torque check on all the important parts.
My (new to me) DR350 is next. I need have a look at the clutch to see the condition of the plates, basket and throw0ut washer. Also want to clean the carb (who knows when it was done last - if ever) and I have a set of rear and front wheel bearings on the way along with a new Tusk Bearing Puller Kit! (I really needed that. I've been bringing parts to my local shop and paying them to pull bearings for me. Finally pulled the trigger of a kit for myself!)
Vankaye is offline   Reply With Quote
Old 01-18-2013, 02:44 PM   #134
2fast4u
Oddometer: 747
changed oil/filter
R&R's spark plugs
New air filter.
Looks like someone is getting ready for another big ride.
2fast4u is offline   Reply With Quote
Old 01-18-2013, 07:57 PM   #135
JimVonBaden OP
"Cool" Aid!
Oddometer: 53,776
Installed the wiring for my two sets of lights:
Jim
Times are GMT -7.   It's 03:44 AM.
