01-13-2013, 06:23 AM
#1 |
Oddometer: 367
Warn Winch Wiring
For those of you who already have the Warn XT 17 Winch...
Where did you run the main relay/power plug wiring on your bike? Thanks. |
01-13-2013, 07:16 AM
#2 |
Oddometer: 298
The relay fits nicely bolted to the outside of the underseat storage box just in front or inside of the rear
shock preload adjuster where the box gets more narrow. You can access the plug from just under the body panel, I have mine zip tied to the subframe where I can still get to it. Matthew
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo- 2006 KTM 950 ADV S http://www.mdfeditions.com/ http://www.cjdesignsllc.com/ |
01-13-2013, 07:56 AM
#3 |
Dans le doute...gaz!
Oddometer: 1,721
Mine is inside the abs box. All tucked away.
The race is long and, in the end, it's only with yourself...
01-13-2013, 12:36 PM
#4 |
Oddometer: 220
Mine too along with the remote receiver. The connector for the winch I have routed to where the shock adjuster is and secured with a velcro strap. That puts it at the middle of the bike and the winch can be used both at the front or back, left or right. (Left or right you ask? Yup, I use it to help lift the bike when I fall over.
2013 KTM 690 (Thanks FLHRCI Buyer! ) 2011 990 Adventure Dakar (Thank you Honey!) 2010 Aprilia RSV4 Factory 2010 Ducati 1198S |
01-13-2013, 01:12 PM
#5 | |
Oddometer: 1,721
01-13-2013, 07:28 PM
#6 |
Oddometer: 367
Thanks for the suggestions.
Any pics handy? It seems kind of tight mounting outside the storage box near the pre-load adjuster. The other side has more room but I am worried about the heat coming up off the H pipe even though I just had the exhaust pipes ceramic coated. I am going to try and fit it inside the storage box above the alarm system. That is when I can get enough time between chasing the 11 month old around. |
01-13-2013, 07:38 PM
#7 |
Oddometer: 1,862
you guys put a winch on your motorcycle?
DD
04 CRF230F 06 CRF250x 08 KTM990 ADV/ABS Black 09 KTM 530 EXC |
01-13-2013, 07:56 PM
#8 |
Oddometer: 49
Help out the people from the countries we love to ride through: http://www.kiva.org/invitedto/advent...er/by/alex9291 |
01-14-2013, 01:47 AM
#9 |
Oddometer: 220
You bet! I ride by myself and with this little baby I don't worry about what's around the next bend, I just ride.
http://www.warn.com/blog/2011/06/08/...le_winch.shtml
01-14-2013, 01:31 PM
#10 |
AWD please!!
Oddometer: 3,866
My 2006 950S thread. 2006 950s updateNew product updates here! Wordpress BLOG click www.cjdesignsllc.com for the full line of products. www.outriderjournal.com FREE STUFF!! |
01-14-2013, 03:44 PM
#11 |
Oddometer: 49
Wow, didn't even know you could get these!
01-14-2013, 07:43 PM
#12 |
Oddometer: 1,862
last summer I was playing around at big bear in SOCAL. There was one section that we absolutely could not get up. A winch would have been perfect. We had to cluster up and each push/help each other up the section.
It was steep with loose sand, gravel and enough turns that you could not keep any speed. Good to know. DD
01-15-2013, 06:12 AM
#13 |
Oddometer: 709
I absolutely will not ride the big bikes off-road without one ever again. I ride by myself a lot and recovering a 500-6600 bike solo is typically not an option. We had one of the riders in our group go off the side of a cliff last year. Straight down with absolutely no traction. MAYBE we could have recovered it with 8 guys and a long rope (which most of us don't carry either) but we all would have been beat. Anything short of that would have involved a tow truck, 40 miles from the pavement and probably a $500 bill.
The winch turned this into a minor inconvenience. 30 minutes later we were back on the trail and none of us were physically wiped out so we could enjoy the rest of the day. Just brilliant. From this: ![]() Using this: ![]() Back on the trail in 30 minutes. Can't beat it.
Kurt - Black Dog Cycle Works Check out our new website: BLACK DOG CYCLE WORKS WE TEST WHAT WE SELL!! If we offer a product, you can be sure we feel it is one of the best in the industry! |
04-01-2013, 03:35 PM
#14 |
Just Do It!
Oddometer: 2
When operating the xt17, do you typically have the bike that is supplying the battery power running? Any issues with loading on the alternator on the BMW R1200GSA?
04-01-2013, 04:14 PM
#15 | |
AWD please!!
Oddometer: 3,866
If you used too long and too much it would be like trying to start your bike over and over again in the cold. Eventually, you'll have a dead battery if your bike won't run. Battery should hold long enough for a few heavy duty pulls, but that depends on your batter condition to start with. I see no reason why the GSA would give you any problems.
