Old 01-12-2013, 06:27 PM   #32476
shep546
shep546's Avatar
Oddometer: 215
Originally Posted by ArmyJoe View Post
I just noticed that justgastanks.com is a bit of a misnomer. In addition to the obvious, they also have Wolfman gear, Seat Concepts seats, and Rotopax gas cans. Another plus is they offer 5% off to Advriders.
I have a stock bike in desperate need of attention. Are there any other places with one-stop shopping for touring farkles?
wheelingcyclesupply
shep546 is offline   Reply With Quote
Old 01-12-2013, 07:02 PM   #32477
burtonrider3889
Oddometer: 846
Pic from today. Unfortunately I think I sprained my ankle pretty early in the day so I was taking it pretty easy. Tuckahoe is some DIFFICULT terrain.
2012 WR250R
2007 SV650 (SOLD)
1984 XL350R (SOLD)
2002 CR80R (SOLD)
burtonrider3889 is offline   Reply With Quote
Old 01-12-2013, 07:10 PM   #32478
krussell
krussell's Avatar
Oddometer: 562
Laugh
First farkle on the WR250R this weekend! Been going back and forth on racks, ended up with the IMMIX racing model.
http://www.immixracing.com/make/yama...argo-rack.html
Went on easy, very solid.
Why this one? Well, I like the look of the billet ones, but not the shape. And I plan on having it covered most of the time, either with camping gear, a Pelican, or a milk crate. I narrowed it down to this one and the TCI Borrego, but thought the TCI was a bit too big. The other thing I liked about the IMMIX was that unlike the Borrego, it's a natural extension of the seat, keeping the same line, where the Borrego is more level, but out of line with the seat. I like the larger mounting footprint of the Borrego and the IMMIX. Anyway, it's on and way too clean.
Here are some pics, the ones on the IMMIX site are much better. Did a test fit of a Pelican and a milk crate too. Oh, and the best part, on sale for $80.
Kevin
krussell is offline   Reply With Quote
Old 01-12-2013, 07:15 PM   #32479
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
Originally Posted by MeefZah View Post
Is the engine case, specifically the stator side, aluminum or magnesium?
I holed mine today, punched the shifter right through it. If aluminum, I can get a guy to weld it up... if not aluminum I guess I'll be buying a new one.
If I can weld it up, should I leave it on the bike to keep from warping it, or pull it off?
Not sure if this guy makes case savers for anything other than KTM's but you could drop him a PM and find out?
http://www.advrider.com/forums/showthread.php?t=839454
If not, I bet Sandman could gin these up for the WR?
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 01-12-2013, 07:17 PM   #32480
ba_
ba_'s Avatar
Oddometer: 2,733
Originally Posted by Scharcon View Post
I have the HDB setup and am running throttle cables upside down with no issues. Also agree with Chadx with the 1-1/2" max. No way could I have gone the 2" with stock cable even upside down.
'09 Triumph Bonneville 50th Anniversary, '14 KTM 690 Enduro R
ba_ is online now   Reply With Quote
Old 01-12-2013, 08:10 PM   #32481
japako
japako's Avatar
Oddometer: 592
Originally Posted by GAS GUY View Post
Don't actually spin the tire, just lightly move it to various spots every 45 degrees or so and see if it stays or keeps rolling to a certain area.
Yep, that works also.. By spinning the tire, I get to drink a beer before it stops. By the time it's balanced I'm done for the day...
japako is offline   Reply With Quote
Old 01-12-2013, 08:22 PM   #32482
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
Originally Posted by japako View Post
I get to drink a beer..... it's balanced
I don't screw with it anymore.....I automatically just throw four 1oz. weights directly across from the Rim Lock/Valve stem......pretty damn close to balanced.......and I use spoke weights....not those adhesive rim strips that fly off.....you can see'em on the front spokes in the below pic (I don't bother to balance the rear)
Crawdaddy screwed with this post 01-13-2013 at 08:50 PM
Old 01-12-2013, 09:08 PM   #32483
ADWrider
AKA Acorn27
ADWrider's Avatar
Oddometer: 86
Originally Posted by pfy50 View Post
It's almost ready for my trip(ref:#31820,31923), extra fuel capacity includes Safari tank, newer 1.75 rotopax and 8L. fuel bladder. BUT I am having an issue with the current tire. I just put on a new Kenda 270 on the front and I am getting a slight pogo/bouncing action in the front suspension at around 28-35mph more so when I am slowing down from a higher speed than when accelerating up through that range. I have eliminated some of it by uping the rebound setting, but have not eliminated it. Has anyone here have a similar problem?
Crikey, do you ever plan to stop for gas? What's your range with that setup?
Only God decides the LENGH of your life, but you decide its WIDTH.
ADWrider is offline   Reply With Quote
Old 01-13-2013, 06:33 AM   #32484
1Down-5Up
1Down-5Up's Avatar
Oddometer: 109
I think he will have to change tires before he has to refuel!!!
Safari tank= 15L +8L +7L Roto= 30L @ 27km/L = 810 km (506 miles) Best case scenario
As for the tire, I would take the wheel off , let the air out and break the bead. Check the tube for kinks and rotate the tire
and see if a new position helps.
1Down-5Up is offline   Reply With Quote
Old 01-13-2013, 08:03 AM   #32485
bradrh
Oddometer: 409
Did you make sure the bead is seated evenly ?
- DR650
- WR250R times 2
bradrh is offline   Reply With Quote
Old 01-13-2013, 08:05 AM   #32486
zimzooma
zimzooma's Avatar
Oddometer: 175
I just put a steel braided front brake line on my X/R to replace the damaged stock line. The oversized X rotor and the feel of the steel line add up to create a superb braking package. Should have done it sooner.
Don't check out my adventures.
zimzooma is offline   Reply With Quote
Old 01-13-2013, 09:23 AM   #32487
shep546
shep546's Avatar
Oddometer: 215
Originally Posted by Crawdaddy View Post
I don't screw with it anymore.....I automatically just throw four 1oz. weights directly across from the Rim Lock/Valve stem......pretty damn close to balanced.......and I use spoke weights....not those adhesive rim strips that fly off.....you can see'em on the front spokes in the below pick (I don't bother to balance the rear)
What rear is that?
Old 01-13-2013, 10:40 AM   #32488
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 560
Well not really. Currently I'm getting to about 105m before the fuel light comes on then usually about 60m. left to empty on the safari tank. I have yet to replace the fuel programmer so that will probably cut the range down a little, and I have yet to do any full up equipment test for range yet; which I hope to do as soon as the weather allows. In the end I am looking for a safe 260m range with reserve to do the Daltom Hwy. to Prudhoe bay. I will probably leave one system or the other behind. Rotopax is 1.75g with the convenience of always being mounted out of the way, BUT it is a little heavier and the empty weight is always with you. The fuel bladder will give me 2g, and the convenience of lighter weight when not used and can be stored out of the way, BUT when loaded it is mounted up higher on the rear rack which is less stable. So more fun yet in load/ride testing to come.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 01-13-2013, 05:19 PM   #32489
Just Bob
Been There Done That
Just Bob's Avatar
Oddometer: 257
Woot! Found a new option for on-the-bike luggage.
http://www.rideasia.net/motorcycle-f...ng-mai-14.html
________________________________
Confidence is the feeling you have before you understand the situation.
Just Bob is offline   Reply With Quote
Old 01-13-2013, 05:36 PM   #32490
shep546
shep546's Avatar
Oddometer: 215
Lightweight... I like that.
Times are GMT -7.   It's 09:45 AM.
