Old 01-11-2013, 09:27 AM   #6841
Baja Dad
Baja Dad's Avatar
Oddometer: 1,981
I have a 08 side stand I am not going to use.
Lets trade!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 01-11-2013, 11:38 AM   #6842
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
Originally Posted by dad2bike View Post
I might do an adjustable style like I did on the 950.
Pic of your design?
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 01-11-2013, 12:04 PM   #6843
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,063
Originally Posted by Sutherngintelmen View Post
Pic of your design?
I pretty much copied this design.
From this thread. http://www.advrider.com/forums/showthread.php?t=560956
I personally used smaller bolt/nuts and a big round washer for a big foot. I also ground off the bolt head at an angle.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 01-12-2013, 01:44 AM   #6844
Oldbear
Don't want a pickle
Oddometer: 225
Could somebody with a 2009 or 2010 R please give me a length in mm on the sidestand? The PO apparently cut or replaced this one when he lowered the bike. I'll be raising it back up to full height. 2008 & 2012 shows 295 mm. I expect 09 & 10 would be longer some. The microfiche don't show for the 09.
It should be 306 mm on the R model. Regular Enduro (and 2012 Enduro R) has a 295 mm one and SMC R 275 mm.
Oldbear is offline   Reply With Quote
Old 01-12-2013, 04:32 AM   #6845
Sutherngintelmen
around the bend
Oddometer: 1,205
Thanks .
E stand with SM wheels is straight up and down.
Old 01-12-2013, 03:54 PM   #6846
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,063
Thanks much.
Sent from outer space with my Thunderbolt with Tapatalk.
Tom
My2Wheels
690 WIKI
Old 01-13-2013, 10:28 AM   #6847
motoged
motoged's Avatar
Oddometer: 908
Tire Changing Tool
Riders,
It may not fit in your fanny tool kit.....but it sure is slick....watch this:
http://www.veebiinfo.ee/v1/page.php?page=2853&username=kaurit
Now, back to trying to find Dakar on the tube
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 01-13-2013, 11:23 AM   #6848
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,591
Originally Posted by motoged View Post
Riders,
Ahhh so they've added to it so you can break the beads and remove the tires as well. Really nice looking stuff, but damn it's expensive!
Old 01-14-2013, 06:03 AM   #6849
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,545
I have used a rig similar to the one above but with one bead breaker....very handy for changing mousse.
Seth S
Seth S is offline   Reply With Quote
Old 01-14-2013, 10:08 AM   #6850
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,063
Has anybody got experience will running smaller rear tires (knobbie) on the 690?
I don't want to get into a tire brand discussion, just a size question.
The tires I run on my 525 are 120/100-18. The next size is the 140/80-18. I was thinking if I dropped down to the 120 I might just be able to keep the lowering link installed and not hit the tank.
Thoughts?
Another thought- I haven't noticed any posts or threads about drilling the drain holes in the 690 swing arm. Isn't this an issue with them as with the rest of the KTM line?
Tom
My2Wheels
690 WIKI
Old 01-14-2013, 10:14 AM   #6851
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,680
Thoughts?
I have a 130/80-18 on the rear right now. I prefer the big ol' 140/80. You need to get that power to the ground!
I'm not familiar with the swing arm problem you talk about.. they fill with water?
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-14-2013, 10:15 AM   #6852
Seth S
Seth S's Avatar
Oddometer: 4,545
Thoughts?
I ran the Kenda trakmaster II on the rear in a 120/100-18 for a little over 1000 miles without any issue. The tire worked fine, no rim issues, no abnormal wear issues and I was on dirt and pavement. In the woods the narrower tired hooked up almost as well as a trials tire...it was very impressive. I also have run a trials tire on the rear with no issue.
Seth S
Old 01-14-2013, 10:40 AM   #6853
motoged
motoged's Avatar
Oddometer: 908
Tars...
130/80 vs 130/100.....the first number is the width of the tire and the second is the height relative to the width is what I think these numbers represent....if this is true....the "100" would be a taller sidewall.....
n'est pas?
And , yes, the EXC swingarms can take in water and it is a good idea to drill a 1/8 hole in the bottom of each swing arm a few inches from the back end....and check the holes occasionally as they can get plugged.
Ged Schwartz
Kamloops , BC
Old 01-14-2013, 10:46 AM   #6854
Seth S
Seth S's Avatar
Oddometer: 4,545
I currently have 3 rear wheels and really only need 2. I have a wide and a narrow. The wide is an adapted 640 wheel as my stock rear rim got trashed through normal riding. The stock rear hub was superlaced with an excel rim. I also have a new Rad rear wheel..both the rad and the stock/excel are unused and i would like to sell one. I will put an ad up in the flea market in the next day or two but figured i would post a heads up here. Both of the Excel wheels are 1.85 wide iirc...good for offroad tires...not so good for fitting rally mousse
I am trying to scratch some cash together to aid in a house down payment
Seth S
Seth S screwed with this post 01-14-2013 at 10:52 AM
Old 01-14-2013, 10:46 AM   #6855
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Tars...
n'est pas?
R U sure? I have a 100/100 rear and the sidewall is really short.
The 100/80 has a taller sidewall.
Just say'IN
crankshaft is offline   Reply With Quote
Times are GMT -7.   It's 09:13 AM.
