01-06-2013, 12:14 PM
#301 |
Oddometer: 290
Project Update!
The Carbon Fiber Handguard Deflector project has been updated. Click here to go directly to the project post. I'm making some good progress in this one... Teaser Pic ![]() By the way, please feel free to rate this thread. You can find the Rating feature in the upper right hand corner of the page, just above the thread page numbers. Thanks for taggin' along!
My Virgin ADV Trip Rocks Flyin', Me Cryin', and God Looking On - A WABDR Adventure Fun With Carbon Fiber therivermonster screwed with this post 01-06-2013 at 03:09 PM |
01-06-2013, 12:24 PM
#302 |
Oddometer: 9,781
Ever think of working in plaster instead of foam? Those surforms do a great job shaping plaster.
Little air belt sanders work pretty good. |
01-06-2013, 01:11 PM
#303 |
Oddometer: 7,715
Subscribed!
Cool thread!
I've been doing FG, CF, Kevlar(patches, gel coats), and plastic repairs(patches and welding) on Kayaks and canoes for over twenty years. I'll have to go back thru and see what you've been doing. I'm not sure if you are aware but another great product for sanding foam is Dragon Skin... I got it from a different source, which I can't remember the name of right off hand but I found that pic here...One piece will last a life time if just used on foam. You can also make it from a piece of tin, a sharp nail, a hammer, a lot of time...and a lot of beer!
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST |
01-06-2013, 03:00 PM
#304 | ||
Oddometer: 290
How did you get into the canoe/kayak repari business? I do a lot of kayaking with family and friends.I think that it would be a hoot to build a composite kayak someday. Maybe a fancy tandom open water boat made out of carbon, Kevlar, and some nice wood trim. That would be one fancy kayak. |
01-06-2013, 06:03 PM
#305 | |
Oddometer: 7,715
PS composites EDIT: BTW, here is another Glass distributor in the Bethesda MD area. I don't know if their prices are in line with who you buy from but there it is... Sweet Composites They are good folks.
2004 XR650L 1992 Specialized Stump Jumper FS NWVA TAG NWVA TAG MAP RTE THREAD & IN LIST bwalsh screwed with this post 01-06-2013 at 07:50 PM |
01-07-2013, 07:51 PM
#306 |
Oddometer: 290
Project Update!
The Carbon Fiber Handguard Deflector project has been updated. Click here to go directly to the project post. The foam shaping has almost come to an end. Thank goodness!
My Virgin ADV Trip Rocks Flyin', Me Cryin', and God Looking On - A WABDR Adventure Fun With Carbon Fiber therivermonster screwed with this post 01-07-2013 at 08:07 PM |
01-12-2013, 03:46 PM
#307 | |
Oddometer: 2,799
Erling |
01-13-2013, 03:52 PM
#308 |
Oddometer: 290
Project Update!
The Carbon Fiber Handguard Deflector project has been updated. Click here to go directly to the project post. Finally we get down to some resin and glass work and a bit of trimming with the use of a very cool tool. Teaser pic!
My Virgin ADV Trip Rocks Flyin', Me Cryin', and God Looking On - A WABDR Adventure Fun With Carbon Fiber therivermonster screwed with this post 01-13-2013 at 03:57 PM |
01-13-2013, 03:56 PM
#309 | |
Oddometer: 290
01-13-2013, 09:13 PM
#310 |
Oddometer: 2,799
Good to hear. I did the same once, only to ring that the gases permitted through small pinholes, and deformed the foam..... It was polyester not bondo. As long as you are aware of the incompatability...... Which it sounds like you are..... :)
Erling |
01-13-2013, 10:25 PM
#311 |
fishing with dynamite
Oddometer: 2,031
Looking good. Have you done much work with bondo? Pays dividends to apply as smoothly as possible, and not to add much more than you need. Was making a lot of unnecessary work for myself until I got the hang of that. Also, another thing I started doing was to do some preliminary sanding/shaping before the bondo hardens. There's about a 10 minute window when it's really great to work with. Not so wet that it will smear and ball-up when you sand it, but still soft enough that you can knock down the high spots with ease. Saves a ton of time/effort.
01-14-2013, 07:39 AM
#312 | |
Oddometer: 290
01-14-2013, 09:51 AM
#313 |
Oddometer: 2,031
Hard to say, but you'll get a feel for it. Try slicing the high ridges off with a razor blade, and see if it cuts through cleanly, without sticking to the blade. Forgot to mention that shaving down those ridges with a razor blade also works really well. Forget the name of it, but there's a long thin cheese-grater-looking tool that makes quick work of shaping soft bondo (not shown). Then I usually switch to course files to even out those compound curves. Concave surfaces are a little more difficult, so shaping and sanding while soft makes all the difference.
01-14-2013, 09:57 AM
#314 | |
Oddometer: 9,781
Stanley Surform - But he's already got the small version (pictured above with the pink foam) For foam it is also hard to beat an electric carving knife. |
01-16-2013, 12:58 PM
#315 |
Oddometer: 290
Project Update!
The Carbon Fiber Handguard Deflector project has been updated. Click here to go directly to the project post. Let the sanding begin... Teaser pic
