Old 01-13-2013, 05:27 PM   #1
Davidjohnson OP
Oddometer: 78
No Toil Pre-Oiled Filter - XR250
Are these filters okay? An OEM or a UNI are about 2X the price.
Do they use the OEM screen/frame?
Thanks,
DJ
David Johnson
Davidjohnson is offline   Reply With Quote
Old 01-13-2013, 06:01 PM   #2
aicram22
Oddometer: 52
Try a K&N filter, blow it off with an air hose to clean it
aicram22 is offline   Reply With Quote
Old 01-13-2013, 06:33 PM   #3
biensur22
biensur22's Avatar
Oddometer: 179
I use twin air, you get what you pay for. I wouldn't use a k&n if you plan to ride off-road. You'll get more than your share of dirt in the motor and that WILL wear the valves prematurely.
Current Rides:1998 KTM 620 Adventure
Past Rides: 1994 KTM 400 EXC WP/D LC4 - Plated; 2001 BMW F650GS Thumper; 1970 CB175; 2003 KLR250
biensur22 is offline   Reply With Quote
Old 01-13-2013, 08:44 PM   #4
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 10,876
I love No-toil. Great for Euro bikes like KTMs, Husky, etc that are very finicky about getting dirt or sand in the intake.
Total overkill for an XR250.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is online now   Reply With Quote
Old 01-13-2013, 09:57 PM   #5
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
And don't forget to blow out the downstream side of the intake where all the dust that's transited to K&N filter has accumulated... YMMV
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 01-13-2013, 10:21 PM   #6
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,510
Thanks,
DJ
They are cheap filters. They won't last as long as the more expensive filters, but they're ok for a while. On the late model XRs they use the stock screen. I don't know about the older models.
Beaten paths are for beaten men.
lamotovita screwed with this post 01-13-2013 at 10:29 PM
lamotovita is offline   Reply With Quote
Old 01-14-2013, 06:38 AM   #7
Davidjohnson OP
Oddometer: 78
Thanks everyone for your comments. I think I will try the No Toil. It is half the price of everything else out there and the two fifty doesn't get used that much in extreme conditions.
David Johnson
Old 01-14-2013, 06:49 AM   #8
elsalvadorklr
southern xr rider
Oddometer: 4,154
Im confused...
how the heck is it overkill if it is half the price of a comparable UNI or OEM filter...?
and how is one bike more finicky about sand or dirt in the intake than another..or was the point that an xr valvetrain is a bit more robust or old school than a newer model valvetrain? and can thereofre take a bit more dirty air? if so I would agree on that
cheers
elsalvadorklr is offline   Reply With Quote
Old 01-15-2013, 08:51 PM   #9
jules083
jules083's Avatar
Oddometer: 3,790
My xr650 has a no-toil on it, and I've always used either uni or twin air on everything else.
Except for the difference in cleaning they seem to perform the same. I bought the one for the xr as a tester, I haven't decided one way or the other which one I like better. Also I haven't had it long enough to comment about longevity.
The no toil is easier to clean. Either way its messy, but using water and a kitchen sink beats the parts washer and diesel fuel.
All typos and misspellings blamed on my phone.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is offline   Reply With Quote
Old 01-15-2013, 09:24 PM   #10
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Originally Posted by elsalvadorklr View Post
Im confused...
cheers
A key rule of Thumpers is to ignore anything Off the Grid says in regards to Japanese bikes.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 01-16-2013, 12:39 AM   #11
Off the grid
Chaotic Good
Oddometer: 10,876
No-toil filters might be cheaper, but it's a wash because you have to use their oil and cleaning solution/grease. It's usually sold as a kit.
I would venture that the tolerances in newer aluminum engines are much more precise and have less allowances for dirt and grit. Normal maintenance and proper seating of the air filter is enough to avoid this.
Which is foolish, considering I've owned dozens.
Every post is an opportunity to learn something from someone. Only a fool thinks otherwise.
Old 01-16-2013, 05:30 AM   #12
wfopete
Suffer Fools; Gladly!
wfopete's Avatar
Oddometer: 480
I just ordered a UNI from Rocky Mountain ATV for my 2001 XR. I thought it was interesting that the UNI comes with a replacement filter cage.
The UNI spin sez:
The Uni Air Filter is two layers of foam that will trap small and large particles like dust and dirt helping prevent anything reaching to the cylinder. Uni Air Filter is manufactured of high performance foam and biodegradable. The Uni Air Filter has a seamless design that allows for a maximum amount of air flow to your machine. The Uni Air Filter is easy to clean with the Uni Air Filter Cleaning Kit and will help cut the grease and oils down so you are able to reuse indefinitely
MULTI-STAGE COMPETITION OFF-ROAD AIR FILTERS.
Traps dirt and dust in two layers of foam, the large pore pre-filter captures the bigger particles.
The small pore inner filter prevents any engine wrecking grit from reaching the cylinder.
Comes with a replacemnt filter cage.
Suffer Fools; Gladly!....
RIDING the TAT? CHECK IT OUT: TAT SHAK
ARA - Adventure Riders of Arkansas
wfopete is offline   Reply With Quote
Old 01-16-2013, 08:39 AM   #13
trailrider383
867-5309
trailrider383's Avatar
Oddometer: 3,254
+1 - Ignore list.
DO WHAT YOU LIKE - LIKE WHAT YOU DO
Explain to me again why enjoying life when I retire is more important than enjoying life now?
trailrider383 is offline   Reply With Quote
Old 01-16-2013, 08:53 AM   #14
elsalvadorklr
southern xr rider
Oddometer: 4,154
GOTTYA! we agree then...
I to agree that despite most of our opinions and likes, LEARNING beats subjective banter 100% of the time...
Times are GMT -7.   It's 10:41 AM.
