Old 01-13-2013, 11:43 AM   #3766
WitchCityBallabio
Guzzi weirdo
WitchCityBallabio's Avatar
Oddometer: 382
Send a message via Yahoo to WitchCityBallabio
Originally Posted by stevie88 View Post
Your motor must run much hotter than mine. I've got the same setup and it's good gear but 32 degrees with just the liners? No way, not in this world.
I should have been more specific. I actually only ride with the liner in the jacket. Never in the pants unless it's raining.
2011 Moto Guzzi Griso SE, 2009 Moto Guzzi Stelvio
2004 Moto Guzzi V11 Sport Ballabio, 1979 Moto Guzzi V1000 Roadster Cafe
1970 Moto Guzzi Ambassador
1966 Moto Guzzi Stornello
IBA # 35648
WitchCityBallabio is offline   Reply With Quote
Old 01-13-2013, 11:46 AM   #3767
Renman1117
Oddometer: 34
[QUOTE=Chuck in Indiana;20470692][QUOTE=Renman1117;20468258]
At the present time I think it's related to how I have picked up speed for input to the Servo.
The Servo needs a strong, steady input signal. That signal is then used as the control point that the unit works against. I used an engine signal (#1 spark plug) on my '08 C-14 and basically controlled to engine speed rather than bike speed. On my '09 Wee-Strom, I used bike speed (from the front wheel speed signal) and controlled that way.
On the NTX, the bike speed is from a signal from the ABS pickup/ring going back to the ECU, from both ends of the bike. Those signals also factor into the Traction Control for the bike. I was reluctant to cut into the ABS wires for fear of messing it up and, instead, went with the Pick-up Coil and Magnet Accessory that Rostra sells. It uses a Coil (that I have mounted on the front wheel assembly) and magnets (I am using four that are attached to the inner parts of the brake disc). I think my problem/inconsistency may be in this pick-up arrangement, somehow.
Unfortunately, our weather is closing in again, so any work I do for awhile will have to be in my garage. Sorry.[/QUOTE
So not having ABS or traction control should simplify the install on my 09 model. I think I will order one in and attempt an install while winter is upon us and my bike is put up in the barn.Good luck with sorting out the pickup arrangement.
Cliff
Renman1117 is offline   Reply With Quote
Old 01-13-2013, 12:21 PM   #3768
kirb
should be out riding
kirb's Avatar
Oddometer: 1,319
Originally Posted by Sock Monkey View Post
Well, I checked out the Klim gear and nearly pulled the trigger, but I think I'll wait until someone has a sale. Plus, I need an education on their line since they've got so many different models. Adventure, Badlands, Latitude, Traverse....sheesh! I tried on the Latitude and Traverse and the Traverse seem much better as an overpant, where the Lattitude (and the rest of their top of the line gear) all seem to be focused towards wearing them over a "base layer" like high-tech long underwear (which they also sell). I need something that can go over jeans comfortably.
-SM
The traverse, for me, could go over or worn alone. All Klim is supposed to be layered. The product line goes down in the order you describe ditching features along the way.
It's top end gear and priced to be so. Good luck finding a sale. They are priced the same everywhere and never seem to have price reductions. I have seen discounts on the dakar pant, but they are cheap anyway (not waterproof). There are so many Klim items on backorder that I highly doubt you will see reductions any time soon.
'13 Moto Guzzi Stelvio NTX, '07 Moto Guzzi Griso, '08 KTM adventure, '00 EH Super X, '48 Indian Chief (in resto)
kirb is offline   Reply With Quote
Old 01-13-2013, 02:27 PM   #3769
pyoungbl
Colonel Blood
Oddometer: 220
Send a message via Skype™ to pyoungbl
Damn I love this bike! We had an unseasonable break in winter today and a lack of rain so I took the big girl out for a 100 mile stroll. Here on the coast we don't have much in the way of curves but it was still sweet to crank her up and burn some hydrocarbons. Nothing fancy, just riding through the country reminding myself of why I like this bike so much. She sprang to life after about one revolution of the crankshaft, fell into a smooth idle, and did not even give me that 'first clutch engagement groan' routine. I had forgotten how smooth the shifting is at 6,000 rpm, just a seamless transition with a slight change in engine sound. Now I guess I'll have to hunker down until the next warm snap....
Peter Y.
Growing old ain't for sissies!
pyoungbl is offline   Reply With Quote
Old 01-13-2013, 06:08 PM   #3770
Toadride
NTXer
Toadride's Avatar
Oddometer: 705
Nippy ride for me today, Peter, down here in Rio Rico. Lowest temp yet. 16F. and I left her outside all night just to put the new battery to the test. Fired right up, no problemos. Heated grips workin great!
Old 01-13-2013, 08:10 PM   #3771
Sock Monkey
Corporate slave
Sock Monkey's Avatar
Oddometer: 1,554
Originally Posted by WitchCityBallabio View Post
If you haven't already, don't forget to check out the Motoport stuff. Indestructable, incomparable construction, custom fit and big bang for the buck.
I have the Air Mesh Kevlar II and the Kevlar pants. With the liner in on the mesh I can ride comfortably down to 32 degrees and if I go colder I just toss in my Powerlet heated gear. In the summer, it's cooler than riding in a tee shirt.
Thanks for the reminder but unfortunately they aren't waterproof unless you also wear the optional liner. I have this setup now with my BMW Rallye 2 jacket (outer layer isn't waterproof but liner is), and while it keeps me nice and dry, everything in the pockets gets soaked. Ideally I'm looking for an overpant to wear over jeans or a thermal layer that is waterproof but still protective (so that eliminates pull-over rain pants). So far there are only a few brands that I've found that provide this and also get good reviews (ICON is one, KLIM is the other, both are $$$). Both Moose and MSR used to make some really nice gear, but over the years their quality has suffered. I really like the look of the First Gear Kathmandu pants, but I have an older version of their HT Overpants and they leak. I'm not sure the Kathmandu will be much better, but I like that they're about $100 less (on sale now) than the KLIM. I just hate the idea of spending $200 on pants that might leak.....
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R, 2010 Ducati Multistrada 1200 S Sport - FOR SALE - PM me since they keep deleting my Flea Market ad
Gone: Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 01-14-2013, 04:37 AM   #3772
kirb
kirb's Avatar
Oddometer: 1,319
-SM
Have you considered Aerostich Darien?
Old 01-14-2013, 06:21 AM   #3773
96ssportsp
Oddometer: 18
Peter Y.
Peter,
As I remember, you used to ride a 1st gen MTS, correct? I have been looking at Stelvio's and have not had the chance to ride one yet. A "BIG" concern for me is the weight. My 05 MTS s feels much lighter than it is @ 470 lbs. Can you give me any comparison between the two bikes I would still keep the MTS if I did get a Stelvio, too good of a bike to move.
TIA, Scott.
I am checking them out. Any 1st hand experience?
Thanks, Scott.
96ssportsp is offline   Reply With Quote
Old 01-14-2013, 09:33 AM   #3774
pyoungbl
Colonel Blood
Oddometer: 220
Originally Posted by 96ssportsp View Post
Peter,
TIA, Scott.
Scott...I'm the same guy. Although I really liked that Multi I was happy to switch over to my NTX. Here's the plus/minus from my point of view.
My Multi had Ohlins F&R set up for my weight. That was wonderful suspension and will be hard to equal anywhere. I had the transmission gears micro polished so the shifting was nothing short of amazing. With high compression pistons and boaring out to 1123cc I had 90 hp at the rear wheel. If I took the db killers out of the Arrow exhaust I'd gain another 10 but the noise was more than I liked. The bike did, indeed, feel much lighter than the real weight. The rest of the story: My tank was replaced by Ducati but it was just a matter of time before I would have the swelling problem again and a replacement tank would be $1K. The centerstand liked to drag on left hand turns until I cranked up the suspension link. It was a royal PITA to do any work on the bike because in most cases I had to take the tank off to get to anything. Taking the tank off was a big deal. If I ever dropped the bike I could see big bucks for any repair to the plastic so going off pavement was really not something I'd ever do. The 220 mile range was OK but almost left me walking a couple times. The dry clutch was a $500 expense every 12-15K (basket and plates), belts were $90 every 12K/2 years, checking/adjusting the valves took me a week every winter, and I seemed to be the only person who did not bitch about the stock seat...there really were no options so why complain..the tank design made it really difficult to do much to the seat without adding lots to the seat height.
The NTX really is a heavy bike....but about normal for bikes in the class. NTX is 616 lbs, BMW GS Adventure is 618 when equipped with equal stuff. The weight would only be an issue if you dropped the bike, otherwise I do not notice it because the bike does not feel that heavy. Moto Guzzi did a good job of hiding the actual capacity of the tank, 8.5 gal! The NTX, on the showroom floor, is almost totally farkled out...crash bars, bash plate, comfy seat, aux lights, really good headlight, LED tail light, hand guards, adjustable windscreen, Brembo radial brakes, decent suspension, and pre wired for GPS and heated grips. The grip kit is about $120 and easy to install. The fuel gauge actually works and you can rely on it...not so my Multi. The dash gives just about any information you can ask for except oil temp. Except for clutch replacement, every routine maintenance action is dead simple. I can check the valves in about 20 minutes and without taking anything off the bike except one rubber plug and the valve covers. Clutches seem to last darn near forever. No chain.
So far I have about 6800 miles on the big girl and no complaints. I have added a Russell Day Long seat and will be swapping out the aux lights for some LED ones. In the first month of ownership I rode to Wyoming and back in a week. Loved it. The bike likes to cruise at the same speeds as the Multi. 6th gear is nice but I find myself in 5th lots of the time.
I'd recommend taking a ride on the NTX if you can find one to demo. You may as well keep the Multi because they seem to depreciate pretty fast and you probably won't get what the bike is really worth. Unfortunately, I believe the Multi will be your garage queen if you have both.
Oh, re Darien pants...I have two pair and use them for lots of my long trips when I want more flexibility of what to wear. Mine do not leak. They are not stylish but, as you know, I'm not one for high fashion.
Hope some of this helps...good to hear from you again!
Old 01-14-2013, 11:02 AM   #3775
Sock Monkey
Corporate slave
Oddometer: 1,554
I own a "new gen" Multi (MTS12 S Sport) and second everything Peter says, both re. the Multi and re. the NTX. Different horses entirely.
-SM
aka NoVector
Old 01-14-2013, 12:22 PM   #3776
Sock Monkey
Corporate slave
Oddometer: 1,554
Thanks for the reminder Kirb re. the Aerostich gear. I checked them out, but they're the same price as the KLIM Traverse. The Traverse actually uses much tougher nylon (840) vs. the Darien (420), so they seem like the more durable pant for the same price. I'm just being cheap and don't want to pay $300 for a pair of waterproof riding pants. *sigh* I may just go with the First Gear Kathmandu overpant since they're getting good reviews and right now they're on sale. Decisions decisions......if would just stop raining I wouldn't have to worry about it.
I did pick up a pair of KLIM Powerxross gloves this weekend. Pittards treated leather palm, GoreTex lining....these guys certainly use high-end materials in their products. I used them this morning in 35 deg temps and I don't think they'll be great for cold weather. My hands were freezing. Thank doG for my new heated grips, but the backs of my hands were still . They should keep my hands dry though. My Alpinestar DryStars finally wore out (had as much plastic tape on them holding them together as there was original material!) so I guess I'm still looking for something suitable for cold wet weather.
-SM
aka NoVector
Old 01-14-2013, 01:56 PM   #3777
oalvarez
Resident Raggamuffin
oalvarez's Avatar
Oddometer: 1,699
comparing the old gen multi to the current Stelvio is a bit of a stretch, no?
the new gen Multi and current Stelvio are far enough different than one another as it is!
2012 Ducati 1199 Panigale
2012 Ducati MTS1200St Ti
2003 Aprilia Tuono Racing
2012 Vespa 300 Super
past: Ducatis, Aprilias, Moto Guzzis, a Husky, and some BMWs as well.
oalvarez is offline   Reply With Quote
Old 01-14-2013, 03:12 PM   #3778
pyoungbl
Colonel Blood
Oddometer: 220
The original post asked for a comparison of the old gen Multi and the current gen Stelvio. That's what was provided. Granted the new gen Multi is a big step up. That is not what was requested.
Peter Y.
Old 01-14-2013, 03:22 PM   #3779
oalvarez
oalvarez's Avatar
Oddometer: 1,699
That's all understood.
Old 01-14-2013, 03:42 PM   #3780
Renman1117
Oddometer: 34
4.25 x17 rim
Originally Posted by Forseti View Post
Those are mounted on 09 Stelvio.
They are not twitchy at all. hold line very well. I have dragged pegs with these on. Never had a but pucker with them. In fact I trust them to hold better than the tourance or anakee I have run previously. You must have the 4.25 rim on the rear as they only come up to a 150 size.
Got me thinking about getting serious regarding the rear wheel situation. I called Woody Wheel Works this afternoon and was quoted $700.00 plus shipping for redoing my 5.50 x 17 rear wheel. Basically donating my hub and they supply everything else. I would like to keep my 5.50 x 17 intact for road work so I googled 09 Stelvio rear hub and ended up talking to Curtis Harper at Harpers Moto Guzzi in K.C. He said that he had just went through this same inquiry last week and ended up being able to order an entire rear wheel 4.25 x 17 from the warehouse for around $370.00 He is going to call me back tomorrow when the Guzzi parts site comes back up, to check availability. Thats a pretty good deal. Last time I looked I think the price on Guzzitech was over $1000.00 for a new rear wheel.
Cliff
Times are GMT -7.   It's 02:00 AM.
