Old 01-12-2013, 03:54 PM   #6826
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,128
Originally Posted by Oldbear View Post
It should be 306 mm on the R model. Regular Enduro (and 2012 Enduro R) has a 295 mm one and SMC R 275 mm.
Thanks much.
Sent from outer space with my Thunderbolt with Tapatalk.
Tom-2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC
My2Wheels
dad2bike is offline   Reply With Quote
Old 01-13-2013, 10:28 AM   #6827
motoged
motoged's Avatar
Oddometer: 908
Tire Changing Tool
Riders,
It may not fit in your fanny tool kit.....but it sure is slick....watch this:
http://www.veebiinfo.ee/v1/page.php?page=2853&username=kaurit
Now, back to trying to find Dakar on the tube
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 01-13-2013, 11:23 AM   #6828
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,806
Originally Posted by motoged View Post
Riders,
Ahhh so they've added to it so you can break the beads and remove the tires as well. Really nice looking stuff, but damn it's expensive!
Old 01-14-2013, 06:03 AM   #6829
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,708
I have used a rig similar to the one above but with one bead breaker....very handy for changing mousse.
Seth S
Seth S is offline   Reply With Quote
Old 01-14-2013, 10:08 AM   #6830
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,128
Has anybody got experience will running smaller rear tires (knobbie) on the 690?
I don't want to get into a tire brand discussion, just a size question.
The tires I run on my 525 are 120/100-18. The next size is the 140/80-18. I was thinking if I dropped down to the 120 I might just be able to keep the lowering link installed and not hit the tank.
Thoughts?
Another thought- I haven't noticed any posts or threads about drilling the drain holes in the 690 swing arm. Isn't this an issue with them as with the rest of the KTM line?
My2Wheels
Old 01-14-2013, 10:14 AM   #6831
RoninMoto
Wanderer
RoninMoto's Avatar
Oddometer: 1,692
Thoughts?
I have a 130/80-18 on the rear right now. I prefer the big ol' 140/80. You need to get that power to the ground!
I'm not familiar with the swing arm problem you talk about.. they fill with water?
Noah 08 KTM 690 ADV. 125,000 km. 42 countries. 5 continents and counting.
Old 01-14-2013, 10:15 AM   #6832
Seth S
Seth S's Avatar
Oddometer: 4,708
Thoughts?
I ran the Kenda trakmaster II on the rear in a 120/100-18 for a little over 1000 miles without any issue. The tire worked fine, no rim issues, no abnormal wear issues and I was on dirt and pavement. In the woods the narrower tired hooked up almost as well as a trials tire...it was very impressive. I also have run a trials tire on the rear with no issue.
Seth S
Old 01-14-2013, 10:40 AM   #6833
motoged
motoged's Avatar
Oddometer: 908
Tars...
130/80 vs 130/100.....the first number is the width of the tire and the second is the height relative to the width is what I think these numbers represent....if this is true....the "100" would be a taller sidewall.....
n'est pas?
And , yes, the EXC swingarms can take in water and it is a good idea to drill a 1/8 hole in the bottom of each swing arm a few inches from the back end....and check the holes occasionally as they can get plugged.
Ged Schwartz
Kamloops , BC
Old 01-14-2013, 10:46 AM   #6834
Seth S
Seth S's Avatar
Oddometer: 4,708
I currently have 3 rear wheels and really only need 2. I have a wide and a narrow. The wide is an adapted 640 wheel as my stock rear rim got trashed through normal riding. The stock rear hub was superlaced with an excel rim. I also have a new Rad rear wheel..both the rad and the stock/excel are unused and i would like to sell one. I will put an ad up in the flea market in the next day or two but figured i would post a heads up here. Both of the Excel wheels are 1.85 wide iirc...good for offroad tires...not so good for fitting rally mousse
I am trying to scratch some cash together to aid in a house down payment
Seth S
Seth S screwed with this post 01-14-2013 at 10:52 AM
Old 01-14-2013, 10:46 AM   #6835
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Tars...
n'est pas?
R U sure? I have a 100/100 rear and the sidewall is really short.
The 100/80 has a taller sidewall.
Just say'IN
crankshaft is offline   Reply With Quote
Old 01-14-2013, 10:51 AM   #6836
Seth S
Seth S's Avatar
Oddometer: 4,708
same brand of tires? I have seen differences in heights between brands. should be width/(height as percenty of width) - diameter.
Seth S
Seth S screwed with this post 01-14-2013 at 10:57 AM
Old 01-14-2013, 10:55 AM   #6837
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,806
Originally Posted by Seth S View Post
same brand of tires? I have since differences in heights between brands. should be width/(height as percenty of width) - diameter.
It's amazing the discrepancy in sizes between brands.
Old 01-14-2013, 10:59 AM   #6838
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,128
I found this. http://www.ehow.com/how_4841621_dete...tire-size.html
It seems a 120/100 would be 120mm tall and a 140/80 would be 112mm tall.
I guess the 140/80 would shorter.
I guess I could go for 100/100. That would surely give clearance.
My2Wheels
Old 01-14-2013, 11:01 AM   #6839
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,128
What about the 690 swingarm?
I know we drill 950/990 swingarms too.
My2Wheels
Old 01-14-2013, 11:06 AM   #6840
Seth S
Seth S's Avatar
Oddometer: 4,708
The 690 arm has some opennings in it as I recall...which makes me remember that I might have some stuff hidden in mine...hmmm better go have a look. I do recommend pulling out the adjuster bolts and coating them with copper anti-seize
Seth S
Times are GMT -7.   It's 09:05 AM.
