Old 01-14-2013, 10:46 AM   #6871
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 13,783
Originally Posted by motoged View Post
Tars...
130/80 vs 130/100.....the first number is the width of the tire and the second is the height relative to the width is what I think these numbers represent....if this is true....the "100" would be a taller sidewall.....
n'est pas?
And , yes, the EXC swingarms can take in water and it is a good idea to drill a 1/8 hole in the bottom of each swing arm a few inches from the back end....and check the holes occasionally as they can get plugged.
R U sure? I have a 100/100 rear and the sidewall is really short.
The 100/80 has a taller sidewall.
Just say'IN
crankshaft is offline   Reply With Quote
Old 01-14-2013, 10:51 AM   #6872
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 3,197
same brand of tires? I have seen differences in heights between brands. should be width/(height as percenty of width) - diameter.
Seth S
Husaberg tank for sale: HERE
Seth S screwed with this post 01-14-2013 at 10:57 AM
Seth S is offline   Reply With Quote
Old 01-14-2013, 10:55 AM   #6873
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 4,830
Originally Posted by Seth S View Post
same brand of tires? I have since differences in heights between brands. should be width/(height as percenty of width) - diameter.
It's amazing the discrepancy in sizes between brands.
Guess what doofus, nobody reads your lame blog.
Old 01-14-2013, 10:59 AM   #6874
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,325
I found this. http://www.ehow.com/how_4841621_dete...tire-size.html
It seems a 120/100 would be 120mm tall and a 140/80 would be 112mm tall.
I guess the 140/80 would shorter.
I guess I could go for 100/100. That would surely give clearance.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger", 2003 525 EXC, 2001 400 EXC
To Think is to Create!http://my2wheels.com/forum/cmps_index.php
dad2bike is offline   Reply With Quote
Old 01-14-2013, 11:01 AM   #6875
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,325
What about the 690 swingarm?
I know we drill 950/990 swingarms too.
Tom
Old 01-14-2013, 11:06 AM   #6876
Seth S
Seth S's Avatar
Oddometer: 3,197
The 690 arm has some opennings in it as I recall...which makes me remember that I might have some stuff hidden in mine...hmmm better go have a look. I do recommend pulling out the adjuster bolts and coating them with copper anti-seize
Seth S
Old 01-14-2013, 12:38 PM   #6877
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 2,325
Oh heck yeah. I do that to all my swingarms. I learned my lesson way back on a 1980 Husky swingswing arm.
Tom
Old 01-14-2013, 12:48 PM   #6878
DirtJack
DirtJack's Avatar
Oddometer: 331
I run Michelin T63's on my knobby wheels. The rear is 130/80. Works well and they are cheap.
Proud to be supporting Pyndon in the 2013 Dakar !
2007 KTM 990 Adventure
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
1998 KTM 400 RXC (sold)
DirtJack is offline   Reply With Quote
Old 01-14-2013, 01:08 PM   #6879
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 8,900
Yes your are correst. The first number is the width and the second number is the height expressed as an aspect ratio of the width.
90/90/21 says the width is 90 and the height is 90% of the width.
At least that is what the tire section of motorcycle-superstore.com says.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
Pantah is offline   Reply With Quote
Old 01-14-2013, 01:36 PM   #6880
DirtJack
DirtJack's Avatar
Oddometer: 331
The size 120/100 gives the width (120 mm) and height (120) as a percentage (100%) of the width. On a 140/80, the height would be 80% of 140 or 112. Changing tire aspect ratios can alter speed/distance measurements particularly if the change is on the wheel used for measurements.
2008 KTM 690 Enduro
DirtJack screwed with this post 01-14-2013 at 01:56 PM Reason: Correct mistakes
Old 01-14-2013, 04:08 PM   #6881
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 823
Send a message via MSN to Gros Buck
Have you fixed your 690 or it is still suffering leaks ???
Paul Jr 8
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 01-14-2013, 05:32 PM   #6882
Seth S
Seth S's Avatar
Oddometer: 3,197
Paul Jr 8
Have not touched it or ridden in 9 months....other than to drain the coolant out of it. Had 3 decent crashes last year and needed a reset. I have done 10 years of ride and not much else so a little breather. Bike will get torn down and reiterated this spring.
Seth S
Old 01-14-2013, 06:14 PM   #6883
motoged
motoged's Avatar
Oddometer: 529
R U sure?
Yep....and the technically adept guys even agree.....
But you can think whatever you want
Ged Schwartz
Kamloops , BC
'96 GS 1100
'04 450 EXC
'09 690 EXC
Baja '05
Baja 06/07
Baja 08/09
BC Alpine Single Track
motoged is offline   Reply With Quote
Old 01-14-2013, 06:59 PM   #6884
Gros Buck
Gros Buck's Avatar
Oddometer: 823
R U sure? I have a 100/100 rear and the sidewall is really short. The 100/80 has a taller sidewall.
Positve.
100/80 means 100 mm wide x 100*80/100 = 80 mm heigth As you can read in the link, it's the aspect ration, and it is exactly the same principle with car and truck tyres.
The lower the aspect ratio, the sportier it is. Typicaly, sport car tyres have aspect ratio in the area of 30 to 40.
That said, the end result is not always in sync with the reality. Dunlop D606 130/90-18 are as wide as Pirelli MT21 140/80-18, and as tall as well ... It's not an accurate science ...
Paul Jr 8
KTM690r 2011
Old 01-16-2013, 11:51 AM   #6885
Kirkster
Parts Murderer
Oddometer: 162
Anyone know if we can swap out the 2012 instrument cluster for an older digital one?
I already have white dust in my 2012 one as well as LCD issues with parts of it blanking out...
Cheers..
K
I don't crash. I burn in and make a crater....
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
1972 Honda CL125 - Retired but ready to ride in AZ
Kirkster is offline   Reply With Quote
Times are GMT -7.   It's 08:47 PM.
