Old 01-13-2013, 08:23 AM   #32491
shep546
shep546's Avatar
Oddometer: 193
Originally Posted by Crawdaddy View Post
I don't screw with it anymore.....I automatically just throw four 1oz. weights directly across from the Rim Lock/Valve stem......pretty damn close to balanced.......and I use spoke weights....not those adhesive rim strips that fly off.....you can see'em on the front spokes in the below pick (I don't bother to balance the rear)
What rear is that?
shep546 is offline   Reply With Quote
Old 01-13-2013, 09:40 AM   #32492
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 350
Originally Posted by 1Down-5Up View Post
I think he will have to change tires before he has to refuel!!!
Safari tank= 15L +8L +7L Roto= 30L @ 27km/L = 810 km (506 miles) Best case scenario
As for the tire, I would take the wheel off , let the air out and break the bead. Check the tube for kinks and rotate the tire
and see if a new position helps.
Well not really. Currently I'm getting to about 105m before the fuel light comes on then usually about 60m. left to empty on the safari tank. I have yet to replace the fuel programmer so that will probably cut the range down a little, and I have yet to do any full up equipment test for range yet; which I hope to do as soon as the weather allows. In the end I am looking for a safe 260m range with reserve to do the Daltom Hwy. to Prudhoe bay. I will probably leave one system or the other behind. Rotopax is 1.75g with the convenience of always being mounted out of the way, BUT it is a little heavier and the empty weight is always with you. The fuel bladder will give me 2g, and the convenience of lighter weight when not used and can be stored out of the way, BUT when loaded it is mounted up higher on the rear rack which is less stable. So more fun yet in load/ride testing to come.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2011 WR250R,2008 KTM 990 ADV,2004 KAWA Concours
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 01-13-2013, 04:19 PM   #32493
Just Bob
Just Bob's Avatar
Oddometer: 248
Woot! Found a new option for on-the-bike luggage.
http://www.rideasia.net/motorcycle-f...ng-mai-14.html
________________________________
Confidence is the feeling you have before you understand the situation.
Just Bob is offline   Reply With Quote
Old 01-13-2013, 04:36 PM   #32494
shep546
shep546's Avatar
Oddometer: 193
Lightweight... I like that.
Old 01-13-2013, 04:52 PM   #32495
Just Bob
Just Bob's Avatar
Oddometer: 248
Owner of that bike had just ridden it 2500 kilometers from Singapore to Chiang Mai Thailand. Double woot!
Old 01-13-2013, 05:19 PM   #32496
shep546
shep546's Avatar
Oddometer: 193
Nice, my uncle is looking to ride from texas to brazil on a honda ruckus next year.
Old 01-13-2013, 05:22 PM   #32497
Wingnut037
Two Sheds
Wingnut037's Avatar
Oddometer: 150
What rear is that?
Pirelli MT43 Trials
Wingnut037 is online now   Reply With Quote
Old 01-13-2013, 06:26 PM   #32498
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,106
Originally Posted by UtahFox View Post
How about a teaser pic of the bike before you get started?
I feel fortunate to live so close to Pamo Valley......Lusardi Truck Trail, Black Mtn Truck Trail, and Santa Isabel Truck Trail are all ~15 minutes from my driveway along with a few side trails.......fun area to ride anytime......so I headed over there with my friend Ron around noonish to break-in the 350XCF-W and get a general feel for the bike/suspension modifications.....and just generally enjoy the day......
Wow, that bike is rolling DOPE and I'm addicted already......very light, peppy and smooth fuel injection.......pretty apparent that it'll have plenty enough juice on the trails "for me".......(I haven't railed on the throttle yet.....was told to behave on the first ride)....just took it for a nice/short ~40 mile loop today and had a blast........time to dump the oil/filter and hit it a bit harder on the next ride.....
I didn't notice any of the "popping" on decel that I've read about......maybe that's unique to the EXC version.....
Definitely a much greater overlap between the 300XCW and the 350XCF-W as opposed to the 300XCW the WR250R.......the 300 and 350 both are very light and very fun whereas the WR was fun but also a bit porky......that said, the porkyness/beefy subframe/350 watt alternator made it a great ADV "traveler".........the 300 will likely be relegated to technical missions on mtn goat trails and/or heavy sand (dune) rides........slap in the right gearing and that bike kicks ass in either scenario........the 350 is replacing the WR as my new "anywhere" bike......the 350 is clearly more of a trail performer/true dirt bike than the WR and I wouldn't want to use it to go to Alaska or some other multi-week trip as I would on the WR ......but I'm confident it'll be a nice platform for short multiday exploration once I add on bigger tank or Rotopax mount.....probably not as comfortable as the WR for the inevitable/boring slab sections but it'll truly go "anywhere" once you're off the boring sections.....
A few pics
Up top on Black Mtn TT:
(you can see the trail winding up down below.....just left of the bike in the pic below)
Cruising through the trees on Santa Isabel TT before the traverse over to Black Canyon
Santa Isabel TT in the background...... fun traverse in either direction
Also parted ways with the WR today......sold it as a parts bike to nearby couple with two WR250X bikes.....so all my WR250R farkles and stock stuff is gone......it was fun while it lasted......
See ya on the trail(s)!
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy screwed with this post 01-13-2013 at 07:53 PM
Crawdaddy is offline   Reply With Quote
Old 01-13-2013, 06:45 PM   #32499
Pantah
Red Sox Nation
Pantah's Avatar
Oddometer: 8,896
Crawdaddy - You are most likely going to LOVE your new KTM. My son bought one last February to race the Mexican 1000 last April. He'd never ridden the desert before, but he had a lot of road racing experience. The bike finished 4th overall motorcycle and won it's class. It made a top speed of 96mph on the playa and it was ridden flat out for much of the timed sections (about 950 miles). He's entered it again this year, but he might trade up to a 500 to try and compete for the overall.
Only problem was the Giant Loop kit disrupted the air flow so the exhaust melted off the rear signal.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
Pantah is offline   Reply With Quote
Old 01-13-2013, 08:16 PM   #32500
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 96
Anyone have the triple clamp torque specs? Thx in advance. Upper and lower values if different plz
EEKAMOUSE is offline   Reply With Quote
Old 01-13-2013, 09:38 PM   #32501
Gany
Oddometer: 191
20Nm (14ft lb) lower
23Nm (17ft lb) upper
3mm fork top face above upper triple
Gany is offline   Reply With Quote
Old 01-13-2013, 09:49 PM   #32502
Just Bob
Just Bob's Avatar
Oddometer: 248
Adios Crawdaddy. Happy trails. Thanks for all the great pics. I'll remember you most for this one;
Old 01-14-2013, 12:09 PM   #32503
TwilightZone
Oddometer: 1,950
6'-3" or so? Makes the KTM look pretty short !
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga!
TwilightZone is online now   Reply With Quote
Old 01-14-2013, 01:07 PM   #32504
shep546
shep546's Avatar
Oddometer: 193
Okay guys that's enough KTM's for now
Old 01-14-2013, 01:21 PM   #32505
LooseWheel
hearded cat
Oddometer: 5
Missing Something?
I am getting a Dunlop 606 front tire (90/90x21) and rear tire (120/90x18) to replace my aging stock WRR tires. Many inmates here like the Bridgestone Ultra Heavy Duty tubes. So I thought I might try them.
However, I have not found that tube in the size of either of the two tires. Both RockyMountainATVMC and Motorcycle-Superstore via chat said that the Bridgestone Ultra Heavy Duty tubes they sell would not fit.
I must be missing something pretty basic.
For what size of tubes should I be looking?
LooseWheel is offline   Reply With Quote
Times are GMT -7.   It's 09:00 PM.
