Go Back   ADVrider > Riding > Regional forums > Central From Da Nort Woods to the Plane States
Old 01-14-2013, 11:53 AM   #55906
ruppster
ruppster's Avatar
Oddometer: 864
Originally Posted by Gonzo_Matt View Post
.002 and .004? That is tight, i don't care what the book says. Try running them at .006 and .008 and see how it starts.
Gen 1 KLR650 is 0.1- 0.2mm (.004-.008") Intake and 0.15 - .25mm (.006-.010") Exhaust. I set it up on the loose end of the spec, it runs great & starts easy. Your values seem very tight, must be a more performance oriented engine. What isn't?
You stated that compression felt weak when kicking it, sure it was TDC? Also is there an auto decompressor adjustment after the valves are adjusted? At least it's a Honda so you don't have those damn shims!
Here is a write-up I found on ADV http://www.advrider.com/forums/showthread.php?t=570015
15 KTM 690E, 05 KTM 450EXC
ruppster is offline   Reply With Quote
Old 01-14-2013, 05:01 PM   #55907
Moparmanpete
Support all riders
Moparmanpete's Avatar
Oddometer: 294
Thanks buddy
It didn't have a manual decompressor when I bought it and the kicker/auto decompressor cable broke and I never replaced it due to unpopular reports so TDC is pretty hard to miss. You really have to lean on it and wait for it to pass TDC on it's own. When cold that is.
I almost have that write up memerized
I plan to bring it home later this week, If right I should be able to readjust the carb where it was and it will start and run fine. I'll ride it home and check the valves hot and see what I get (besides burnt) and if it is tight as I think it will be I'll open it up once cold to .004 and .008 and test run it again 30miles and see what happens.
I still wonder about switching the jets around so I'll check the plug real close and go from there.
I really apprectiate your guys help and hope to get this bike tip top so I can show off my crashing skills this year
"The reward is in the doing of it" "If you don't go when you to want to go, when you do go you'll find you've gone" BM
08 Wildfire 150 Scoot "The Virus"
The Virus's RR http://advrider.com/forums/showthread.php?t=826703
87 XL600R "The Cracken" deceased till further notice
Moparmanpete is offline   Reply With Quote
Old 01-14-2013, 05:09 PM   #55908
ruppster
ruppster's Avatar
Oddometer: 864
Originally Posted by Moparmanpete View Post
Thanks buddy
I was just thinking out loud, I know sometimes it doesn't take much for me to have an AHA moment. Good luck with the carbs.
Old 01-14-2013, 08:33 PM   #55909
indypup
indypup's Avatar
Oddometer: 3,741
Anyone know the best way clear Honeysuckle? From what I can tell you need to try to pull it out of the ground hopefully getting most of the roots.
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 01-14-2013, 09:02 PM   #55910
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,204
I belive my main problem is the adjustment of the pilot mixture screw, it's an 87 with the california twin carbs so no air screw...
Most thumpers do not have an air screw, just a fuel screw between the slide and the manifold to the head, the 2 strokes I owned had air screws between the slide and airbox boot. Some of these had aluminum caps over them so you couldn't adjust them. We'd just drill a small hole in them and run a screw into it so it could be pulled out. Most of my Hondas had a brass or copper BB in a hole and it was peened in to block fuel and air passages. Don't drill those!
If the secondary carb is not shutting all the way, too much air may be getting by the slide causing a lean spot.
If the idle is set too high, and the fuel/air screw is out of adjustment, the bike will run differently between hot and cold.
Get the motor hot and set the mixture screw at 1.5 turn out from seated gently. Try to get the idle screw out as far as you can and get the idle up using the mixture screw. Your slide may be too high and you may be adding too much fuel for a warm engine and flooding it. Great when cold but not so when warm. Your carb has all kinds of passages in it for air and fuel to bypass the slide when closed.
A simple test to try with a hot engine. If you blip the throttle and the engine slowly revs down or takes a while to rev down, then you may be lean. If the engine slows down rapidly and start to die, it may be rich.
Hope you get it figured out
btw, all I did was change the valve cover gasket on mine and the intake valve went tight and wouldn't start at all.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 01-14-2013, 09:04 PM   #55911
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,722
I'm no yard care expert, but this worked for me. Cut it short in the spring, and paint the stumps with Ortho brush killer straight from the bottle. I'm not sure if you can still buy the stuff though. I've had the same bottle for a long time.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 01-14-2013, 09:11 PM   #55912
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,204
I belive my main problem is the adjustment of the pilot mixture screw, it's an 87 with the california twin carbs so no air screw,
One setting she starts great cold with a real good idle and rev but then sometimes not all the time doesn't want to start hot.
Once adjusted to start hot it will have a a cough/backfire through the carbs every couple of seconds for about 10mins that can kill it and have a stuck high idle.
Going back and looking at this, the hot start setting sounds too lean for idle.
My 950 backfired through the carbs when I got it too lean with the needle.
Michael
Old 01-14-2013, 09:13 PM   #55913
buildit
Guns, bikes and Bows
buildit's Avatar
Oddometer: 14,248
Gallon or so of Bleach will destroy any vegetation. Breaks down the cell walls.
http://www.youtube.com/user/advfilmer
2013 Super-10
2007 KTM950SEr
2006 KLR650
2001 YZ426 (street Legal)
buildit is offline   Reply With Quote
Old 01-14-2013, 09:29 PM   #55914
indypup
indypup's Avatar
Oddometer: 3,741
Ouch...I flinched several times.
Old 01-15-2013, 04:25 AM   #55915
r-3350
r-3350's Avatar
Oddometer: 177
A product called Tordon RTU is a good stump killer. It comes in a quart squeeze bottlle so you just squirt the cutoff stump. Rual King carries it. Carl
r-3350 is online now   Reply With Quote
Old 01-15-2013, 05:31 AM   #55916
BigOhio
BigOhio's Avatar
Oddometer: 479
A few goats would keep it in check.
Just leave me alone...
BigOhio is offline   Reply With Quote
Old 01-15-2013, 05:54 AM   #55917
Danjal
Insert wit here.
Danjal's Avatar
Oddometer: 2,737
How clear are we talking here? Some lawn sterilizing agent would keep the area vegetation free for years. Some gas or diesel would help keep it in check too unless it's really robust. Fire can work too unless it's an area you can't burn in. Or just get goats.
Danjal is offline   Reply With Quote
Old 01-15-2013, 05:56 AM   #55918
buildit
buildit's Avatar
Oddometer: 14,248
Being he lives in Troy, I doubt he wants to salt the earth but probably has a patch he just wants gone along a fence or the side of the house where getting a lawn to grow is difficult.
2013 Super-10
2007 KTM950SEr
2006 KLR650
Old 01-15-2013, 07:34 AM   #55919
indypup
indypup's Avatar
Oddometer: 3,741
No, I was talking about my Dad's farm over in Indiana. The fence rows are encroaching in on the farm fields with this stuff and it's everywhere it seems. :(
I was thinking a tractor with a frontend loader might be able to bull doze it right out of the ground but some of it is 4~5" diameter. :(
Old 01-15-2013, 08:39 AM   #55920
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,360
Autum/Russian Olive out of control at my place. It basically takes over any open areas that are not mowed. Lots of fruit in the fall so the birds spread (shit) the seeds like crazy.
This is SPARTA!
SCQTT is offline   Reply With Quote
Times are GMT -7.   It's 09:03 AM.
