Old 01-14-2013, 05:11 AM   #1
mwalker OP
mike
Oddometer: 75
wiring your GPS
Whats the best way to hardwire your GPS to the switched side of the electrical system, so it turns on when you turn the bike on? Garmin 276C...on a Yamaha XT250
mwalker is offline   Reply With Quote
Old 01-14-2013, 06:06 AM   #2
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,689
Tap into switched power via a headlight or running light circuit.
Old 01-14-2013, 06:32 AM   #3
Jeff Munn
Just along for the ride..
Jeff Munn's Avatar
Oddometer: 2,155
Don't forget
and if you add a quick disconnet with two prongs, make sure the exposed prong on the supply side is the ground and NOT the power. Don't ask.
Ride to challenge yourself and to expand your horizons. But be warned, once you've ridden beyond the U.S. border, you might begin to realize that the world doesn't revolve around us......
2004 ADVRider Mileage Champion 48,350 miles
Riding Central America Feb 2006
England to China Apr-Aug 2007
Central America Ride Planning and Road Wisdom
Jeff Munn is offline   Reply With Quote
Old 01-14-2013, 07:59 AM   #4
250senuf
250senuf's Avatar
Oddometer: 2,424
I'd add a relay which is triggered by the lighting circuit. That way if there is a "malfuntion" you don't lose your lights.
Not all who wonder are confused
250senuf is online now   Reply With Quote
Old 01-14-2013, 08:01 AM   #5
wbbnm
wbbnm's Avatar
Oddometer: 2,272
This is specifically how I do it. It is a little ugly and it might not be the best way, but has worked on bikes used for some really rough riding.
FInd a wire that is accessable and has switched power like one of those described above.
Find a convenient place and use an exacto knife to peel away about 3/4" of insulation. Strip back the insulation on the wire you are going to splice it. Wrap the bare wires together. Solder them. Wrap electrical tape around the splice.
I use a lot of those two-pronged SAE connectors. I create them by buying 12" two-conductor SAE extension cables at AutoZone and cutting the wire and getting two plugs to use. As the guy said it is really important that the positive wire be on the female side of the connector.
wbbnm is offline   Reply With Quote
Old 01-14-2013, 09:28 AM   #6
mwalker OP
mike
Oddometer: 75
Got it...great help
Old 01-14-2013, 09:33 AM   #7
mwalker OP
mike
Oddometer: 75
with a relay do I still need a inline fuse?
Old 01-14-2013, 09:44 AM   #8
250senuf
250senuf's Avatar
Oddometer: 2,424
Fuses are always good to have. When using the relay the fuse should be in the load wire (controlled circuit) near the battery.
Old 01-14-2013, 08:10 PM   #9
worwig
Oddometer: 1,277
PosiTap connectors are handy for this type stuff.
Hog mountain Weather
worwig is offline   Reply With Quote
Times are GMT -7.   It's 06:27 PM.
