Old 01-14-2013, 02:50 PM   #32506
japako
japako's Avatar
Oddometer: 592
The Bridgestone HD tube for the front is Bridgestone Heavy Duty Motorcycle Tube 80/100x21 and the rear is Bridgestone Heavy Duty Motorcycle Tube 110/100x18.
I hope that is what you asked for... I've had a few..
japako is offline   Reply With Quote
Old 01-14-2013, 03:22 PM   #32507
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,766
I've tried Maxxis, Michelin, Kenda, IRC, and Fly Racing tubes. I only use the normal heavy duty ones (because the super heavy duty tubes are a major pain to install)....
Of all the brands I've used over the past few years, I like the IRC the best. Very rugged yet still easy to install (I use only baby poweder)
http://www.motorcycle-superstore.com...T.ac=SLIsearch
110/100-18 will work fine in a Dunlop D606 @ 120/90-18
Kenda Tuff Tube is also very good, and would be my 2nd choice.
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is offline   Reply With Quote
Old 01-14-2013, 05:54 PM   #32508
riverman
Life is great !
Oddometer: 197
First High Five, now Crawdaddy, and BigDog still has the WR but has purchased another bike as well !! Hmmmmm!
Enjoy boys, its all good! Thanks for all your congtributions to this site and for answering many PM's from ADV'ers regarding the WR.
Rory aka "Riverman"
'11 WR250R
'13 Tiger 800XC
riverman is offline   Reply With Quote
Old 01-14-2013, 06:13 PM   #32509
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 589
Originally Posted by LooseWheel View Post
I am getting a Dunlop 606 front tire (90/90x21) and rear tire (120/90x18) to replace my aging stock WRR tires. Many inmates here like the Bridgestone Ultra Heavy Duty tubes. So I thought I might try them.
However, I have not found that tube in the size of either of the two tires. Both RockyMountainATVMC and Motorcycle-Superstore via chat said that the Bridgestone Ultra Heavy Duty tubes they sell would not fit.
I must be missing something pretty basic.
For what size of tubes should I be looking?
Like they said above http://www.rockymountainatvmc.com/p/...ultra+hd+tubes
select 80/100-21 front and 110/100-18 rear from pull down window
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 01-14-2013, 06:32 PM   #32510
alansz400
alansz400's Avatar
Oddometer: 1,014
For the price these are great tubes. http://www.rockymountainatvmc.com/p/...otorcycle-Tube
alansz400 is offline   Reply With Quote
Old 01-14-2013, 09:10 PM   #32511
LooseWheel
hearded cat
Oddometer: 5
BlueLightning,
skierd,
japaco,
thumpididump,
pfy50,
alansz400,
Thank you!!
Thanks all, for sharing your knowledge and experience.
I now feel much more confident in choosing some tubes to try withmy 606s.
Ride safely and have a helluva lotta fun doin it.
LooseWheel is offline   Reply With Quote
Old 01-15-2013, 04:23 AM   #32512
jimmy2020
limpiador de ventanas
jimmy2020's Avatar
Oddometer: 984
wr250 dirt tire question
will a 120/90 - 17 pirelli MT 21 work on the back wheel? I know a 130 works but I can only find a 120 width here in Costa Rica.
Also, will a 110 width work on the front?
Crap...In the title, I meant to tell you this is for a WR250X
jim
"the adrenaline and stress of an adventure are better than a thousand peaceful days"
jimmy2020 is offline   Reply With Quote
Old 01-15-2013, 06:26 AM   #32513
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 589
Yes, up to 110/70-17 front
140/70-17 rear so 120 can be used with resultant lower traction, but it looks like you want to go off road if your getting a MT-21.
Old 01-15-2013, 01:07 PM   #32514
Cowgirl
Cougar on the prowl
Cowgirl's Avatar
Oddometer: 4,236
I have a question for you. Last spring I cracked/broke/mangled the multi-function display on my WR. It still functioned except for the back light so I just left it and used it as is. I couldn't read it at night but that wasn't a big deal to me. Now in the dampness of winter it's finally quit displaying anything. All the leds still work but the display is kaputski. So my question(s). Should I replace it with a stock display or go with a Trail tech or Vapor tech display? What are the advantages/disadvantages of either? Will a new display show the correct mileage or will it start from 0? If 0 is there a way to program in the mileage? Is there a way to read this info from the broken display?
That's enough for now
Cougar tracks
The initial pawprints
The blind date
A Cougar goes racing
Lead me not into temptation ............ just follow me, I know a short-cut.
Cowgirl is offline   Reply With Quote
Old 01-15-2013, 01:17 PM   #32515
GSF1200S
Oddometer: 976
You can program the mileage in when you get a vapor. You will also end up with a more accurate mileage count (eventually) and a more accurate speedometer (it is set based on tire size and within .5 mph of gps on my bike). As an added bonus, sprocket changes will not affect the accuracy of your speedometer since the vapor tachs read speed off the front wheels rotation. The stock one as you know will end up off unless you use a speedohealer to calibrate when you do sprocket changes.
Thing is, I have heard things about the WR not starting if the stock cluster is removed. See: http://wr250rforum.forumotion.com/t5...ter-tachometer
Im not sure, but if you need to have the stock cluster, I wouldnt even waste time with a vapor unit.
GSF1200S is offline   Reply With Quote
Old 01-15-2013, 01:18 PM   #32516
KansasBob
KansasBob's Avatar
Oddometer: 515
It's part of your Fuel Injection computer, and the bike won't run without it. If you buy a used one it will read the mileage that was on the other bike when it was taken off. I don't know if your local Yammi dealer has the ability to go in and manipulate the mileage like car dealers can on newer cars..... they might, but I would guess not.
KansasBob is offline   Reply With Quote
Old 01-15-2013, 01:19 PM   #32517
GSF1200S
Oddometer: 976
And there is the voice of wisdom
Old 01-15-2013, 01:38 PM   #32518
Cowgirl
Cougar on the prowl
Cowgirl's Avatar
Oddometer: 4,236
Would having a power commander affect this?
Cougar tracks
The blind date
Old 01-15-2013, 01:55 PM   #32519
KansasBob
KansasBob's Avatar
Oddometer: 515
The power commander won't have any effect on your problem. It just reads the data the computer is already sending out and changes the values per your settings, then sends it back out to the bike.
Old 01-15-2013, 03:19 PM   #32520
sieg
sieg's Avatar
Oddometer: 2,924
I don't know if your local Yammi dealer has the ability to go in and manipulate the mileage like car dealers can on newer cars..... .
But can they? Just asking, 'cause I had a dealer replace the dash in my 'vette, the new dash read zero miles, I insisted it read the correct miles. They thought too that they could re-program it but found out they could not. They ended up getting another one from GM pre-programed with the right miles. Sorry for the high-jack.
"Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote" Ben Franklin
Current bikes F800GS-EXCF350-Versys-690R-RZ350
sieg is offline   Reply With Quote
Times are GMT -7.   It's 03:14 AM.
