01-15-2013, 07:39 AM
#4186 |
Swabee
Oddometer: 5,514
WANT!
06 KTM 950 Adventure S 08 Dodge 2500, QC Shortbed, Cummins 6-speed auto, Big Horn |
01-15-2013, 07:49 AM
#4187 | |
X-MAX Adventurer
Oddometer: 36
Road to road, bed to bed, lover to lover, black to red There's no salvation for me now! Some full daytrippin' reports (in spanish) |
01-15-2013, 09:23 AM
#4188 |
Oddometer: 3,076
I see he's using the tailwheel touchdown to signal when to cut power, so if you can touch the tailwheel down exactly where you want to, you're in like flynn.
---->>Thanks for the rotor, guys!<<---- |
01-15-2013, 09:38 AM
#4189 |
Rectum Non Bustibus
Oddometer: 3,525
It's interesting that the leading edge slats are manually controllable. If there's a decent wind blowing that could be landed with almost no roll after touchdown.
10 Ducati 1098 Streetfighter S - "Sleipnir" 09 Kaw Versys "The problem with Socialism is that you eventually run out of other people's money" _____ Margaret Thatcher |
01-15-2013, 09:58 AM
#4190 | |
Swabee
Oddometer: 5,514
From their site: " Press Release – Just Aircraft New “Superstol”Just Aircraft has completed design and testing of a new “Slatted wing” and compatible “Shock Absorber Landing Gear”. The results exceeded expectations! “This newly completed “Superstol” with a high lift wing and long strut air shock landing gear is the ultimate future bushplane. Fowler flaps and automatic leading edge slats increase wing cord and provide exceptional STOL performance while maintaining the trailerable folding wing. • At least 10% faster cruise speed • At least 10% slower stall speed • Reduced landing distance by 50%"
01-15-2013, 01:54 PM
#4191 |
Oddometer: 3,076
I wonder if there is a linkage (either a lockout or a full mechanical link) that prevents a 'slats disagree', and if not, if it has an override or sufficient aileron authority to compensate.
01-15-2013, 02:05 PM
#4192 | |
Swabee
Oddometer: 5,514
Good question. I emailed them and asked I'll let you know what I find out.
01-15-2013, 02:10 PM
#4193 |
Rectum Non Bustibus
Oddometer: 3,525
The automatic slats are just spring loaded and depend on air pressure to push them closed. I don't think there's anything like a linkage involved. Maybe it's only required on the powered type used on large aircraft.
01-15-2013, 04:00 PM
#4194 |
Brace for collision!
Oddometer: 2,418
Just like a BF-109!
Pete |
01-15-2013, 04:12 PM
#4195 |
Oddometer: 3,076
Interesting task as well to try and build in some aerodynamics that will yield a bit of hysteresis (you want the deploy and retract speeds to be different), unless that comes for free.
You wouldn't want the dang things popping in and out when you were near the deploy or retract transition.
01-15-2013, 04:52 PM
#4196 |
Rectum Non Bustibus
Oddometer: 3,525
01-15-2013, 09:33 PM
#4197 | |
Oddometer: 1,353
As is pretty obvious from my posts, I am a warbird guy through and through. But bush pilot landings with big wheels and almost 0 knot stall speeds really make my inner child smile.
1974 BMW R90/6 Bettie #1 Quote:
01-16-2013, 06:13 AM
#4198 |
Obviously a major malf...
Oddometer: 187
Nice A/C but you are probably looking at $100.000 by the time you get done with all STOL options, not to mention the 600to 700 hrs build…
Could you do this or close with a PA 20 or PA 11for half of the price? Looking at the accident reports over the years seems that a lot of pilots with highly capable bush aircraft tend to damage them more often…and take more chances. A Swiss pilot operating in Alaska comes to mind…some of you will know the man in question, A pilot at Winchester Airpark, Jim V used to land across the East West runway with his modified Supercub when the wind was from the North…not recommended in my book.
You've never been lost until you've been lost at Mach 2. |
01-16-2013, 06:37 AM
#4199 |
geezer
01-16-2013, 08:01 AM
#4200 |
Oddometer: 187
Judging by the oddometers on this thread...do you guys do anything else...
Oops...INCOMING...
| Thread Tools | |
