01-10-2013, 10:31 AM
#3796 |
XR650L_High_Runner
Oddometer: 352
So my bike does not have the manual cam chain adjuster and have not heard a loud noise from videos I've seen of people who needed to replace but when I'm giving my bike gas I notice a slight different noise but have heard others who made the same noise, normal?
Here's a video of my bike idling, I'll have to make another of riding it.
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles) 2006 CRF250r (traded) XR80r 2008 XCRW450 (260 hrs) |
01-10-2013, 11:07 AM
#3797 |
Oddometer: 342
Do you have a dirtricks Cam chain tensioner in it? Maybe check out one of those. Maybe someone else will chime in too.
President and Founder of Superhero Proving Grounds "Where dreams are made and egos are checked" |
01-10-2013, 12:19 PM
#3798 | |
RubberNecker
Oddometer: 1,695
I've posted these before, but here is a before and after the Dirt Tricks tensioner. This bike is far worse than the 530 that was the latest, and while it sounded pretty bad before replacing the part, it was no where near as bad as the Husaberg in the videos.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI |
01-10-2013, 02:52 PM
#3799 |
XR650L_High_Runner
Oddometer: 352
Appreciate the help, guess I'll be ordering the Dirt Tricks sooner than I expected. A friend who is a very good mechanic has experience with mainly the big four, he told me KTM's he always heard all had some weird noise but I figured this noise wasn't "normal" for KTM's. How do I know how many clicks for the Dirt Tricks?
01-10-2013, 03:11 PM
#3800 |
RubberNecker
Oddometer: 1,695
You install it collapsed, and it adjusts itself once the engine is fired up, never to be thought about again. It shouldn't take more than 5-10 minutes to install.
01-10-2013, 05:42 PM
#3801 | |
Oddometer: 316
01-11-2013, 07:44 AM
#3802 |
beat up ex flat tracker
Oddometer: 6,753
DRZ400? Truly a station wagon of the dirt,heavy yet slow and ponderous on trails.Money pit when you try and make em go better
530KTM? Fast smooth great handling dirtbike with a plate,needs nothing to go way faster then most people need. Husky510? Not as common or well supported by the aftermarket,KTM has been at this dualsport/dirtbike thing for quite a while now.
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
01-13-2013, 06:21 PM
#3803 |
Random Hooligan
Oddometer: 6,162
Today, in honor of the Dakar rest-day, I did some work on my 450. First, I've had oil blowing out the vent on the transmission side. After ruling everything else out, I came to suspect the kick start idler gear. Sure enough:
The old one: ![]() You can see that the inner bushing has shifited, blocking the oil passages. Here's the new one: ![]() Then, using Ned's write up in this very thread, I replaced the head gasket due a suspicion that was what was causing my coolant to spew out, even when the engine was not over-heating. Here's what the inside of the head looked like: ![]() ![]() And the valves: ![]() Some weird crystalization there, especially right near the spark plug hole. Not sure what to make of that.Thoughts?
-Scott- Semper Fi '04 BMW R1150GSA, '97 BMW R1100GS, '08 KTM 450EXC-R, '04 KTM 625 SXC "A pessimist thinks all women are bad. An optimist is one who hopes they are." Chauncey Depew
01-14-2013, 06:48 PM
#3804 |
Oddometer: 6,753
If compression was leaking past the head gasket and pressurizing the cooling system,then it would have carbon particles and compression by products in the water/anti-freeze? Just thinkin
A 300 I had did that once and there were black spots floating in the radiators.
01-14-2013, 07:58 PM
#3805 | |
Random Hooligan
Oddometer: 6,162
01-15-2013, 03:15 PM
#3806 |
Oddometer: 188
Hodaka Guy?
Are you back riding bikes again----Last I saw you had your bike up for sale---thought you were going to dune buggies or something? ANyway It's good to see you posting again----We appreciate your sharing your knowledge and experience.
01-15-2013, 03:47 PM
#3807 | |
Random Hooligan
Oddometer: 6,162
01-18-2013, 05:35 PM
#3808 |
XR650L_High_Runner
Oddometer: 352
So I just installed the Highflo Water Impeller tonight somewhat dark out, did it on my own (I usually get my dad to help me but I've decided to try and learn to work mechanically on my bikes on my own). First off it was all easy until I had to find a way to get the first gasket on, then the orange metal piece, then the final gasket along with the pump cover. So I got it all back on, installed correctly and as should (don't have a torque wrench so I applied enough torque I thought needed so nothing would loosen or overtighten) anyway so I started the bike and it sounded fine, no leaks, and no new noises other than the stupid cam chain that I need to replace. Should there be anything I need to watch out for? I was confused on the water impeller because as I tightened the nut it kept going back and back so I kept tightening and did not want to tighten it all the way to the back, was this a mistake? It's somewhat tight now and obviously there needed to be room but I was unsure if the washer behind the impeller was what caused it to somewhat get tighter so I stopped. I am doing the coolant recovery kit tomorrow and I was unable to hook the rad hose back up to the cover fully on but enough so no leak and etc. but tomorrow while the gas tank is off I'll have room to fully slide it on but while I have it all off tomorrow I wanted to check to see if I might've screwed up along the way of putting the impeller on and etc.
2008 Qlink XP200 (60k miles) 2006 CRF250r (traded) XR80r 2008 XCRW450 (260 hrs) antpatterson screwed with this post 01-20-2013 at 10:57 AM |
01-20-2013, 10:10 AM
#3809 | |
Oddometer: 6,753
Best be careful. Simple things can lead to disaster.
01-20-2013, 10:55 AM
#3810 |
XR650L_High_Runner
Oddometer: 352
Well I talked to my mechanic friend and he said the water impeller should tighten on it's on but I tightened it a good bit and ran it for awhile now, and went out flying on it today and no issues or leaks. My mechanic buddy has been working on dirtbikes for 35+ years and he doesn't always use a torque wrench either if you know what feels good then it should be tight enough, my next project is the DirtTricks came tensioner.
I have a separate question, I've had no oil issues at all BUT I don't know if any previous owners did the oil seal correction or if this bike even has that potential problem since it was the early 08's and some 09's, I read later 08's were corrected though. The question though, is combining the tranny and engine oil better? Any good picture threads on how this is done? Does it require machining? Cost?
