09-24-2008, 10:57 AM
#16 | |
Life is a trip
Oddometer: 3,132
I think your description points towards the clutch.
There is always a reason!! |
11-28-2008, 02:14 PM
#17 | |
All idiot, no savant
Oddometer: 8,223
Well..... I didn't do anything until today. Hadn't been riding much, and bought a XR250R on Sunday so I was playing with that. Today I thought I ought to exercise the beast. Got sick of the vibes after 30 minutes around town and came home. On a whim I took the seat off and was looking down at the cylinder head and all around. I noticed a pair of fasteners that didn't match. The bolt that holds the right side subframe to the frame was backing out. I pulled the fasteners for the right side plastic off and tightened it up. I thought, well it can't get any worse... there's no way this is going to fix it, but I'll try it anyway. So I took it out for a test. ![]() SIGNIFICANTLY better. Not perfect, but even at lower RPMs it's noticeably better. After I burn off the gas I filled up with today, I'm going to tear it down and re-torque everything. It's probably time for a good once over. I bet I have a few loose screws.... . |
11-28-2008, 02:23 PM
#18 |
Oddometer: 158
When I first picked my 08 up from the dealer in July my hands went numb from the vibes on the freeway.
That was the one and only time though. I have 7000 on it now and done a 1000 mile day once even, and never have never had problems with it since that first day. So either I got used to it or it went away. |
11-28-2008, 02:27 PM
#19 | |
Is this round trip?
Oddometer: 232
11-28-2008, 03:08 PM
#20 | |
Oddometer: 8,223
Na... It's an '04 w/ 20K miles. From what I understand, it's seen some pretty heavy riding. . |
11-28-2008, 03:26 PM
#21 | |
Is this round trip?
Oddometer: 232
11-30-2008, 12:24 PM
#22 |
Life is the adventure!
Oddometer: 695
Guys,
Check your chain tension. I used to run mine way too tight. When I started to experiment , I noticed a big improvement when I "loosened" it a lot. Also it's better for the suspension and the bearings. Also check the tank bolts to see if they are too tight. hope this helps someone. Killer Whale KTM
Friend:"That ain't no dirt bike,it's a damn whale!" Me: " It may be a whale, but if it is, it's a KILLER WHALE !! " |
11-30-2008, 11:46 PM
#23 |
Oddometer: 439
He stated that the vibration is there when stopped and just reving the motor. Vibration goes away when clutch is pulled in at speed.
I agree with previous post... check main nut on clutch basket and related parts. MAKE THE DEALER CHECK IT OUT!!!!!!!!! It's a new bike and the 990's natoriously smooth.
11 Gas Gas 300ec (plated) 09 Kawasaki Concours ABS 2011 44th Baja 1000 (Finisher) 2X 2010 43rd Baja 1000 (Finisher) 305X 2009 42nd Baja 1000 (Finisher) 313X |
12-01-2008, 07:36 AM
#24 |
Life is an Adventure
Oddometer: 566
(2) 990's in the stable
Both bikes had the 600 mile service. I had a slight vibration from front tire on my bike. Dealer replaced the front tire (no cost) with a brand new Scorp/and found the front rim slightly out of round. New tire and a trued rim, all is well and smooth.
Both bikes have been running great. no issues.
Big Dave "Life is no dress rehearsal" 2011 GS Adventure 2012 650 Wee Strom |
12-01-2008, 04:37 PM
#25 |
I don't give a shit
Oddometer: 12,506
KTM 990 ADV 07 Member #68,893 Fishkens: Holy shit! Look at that little lizard. It's the Jesus Christ lizard...... Honey Badger don't give a shit. Ashamed member: I've been around oceans most of my life, and I honestly have never seen a Black man fishing. |
01-15-2013, 08:54 PM
#26 |
Oddometer: 19
990 vibrates too
Old thread for sure, but I just got back from my first ride on the 2012 990R and searched this topic. I too am experiencing bad vibes between 4/5k rpms. My 950 did not do this. I'm trying to really work the allowable rev range and do a proper break in. The manual says up to 6k ok. Maybe 6,500 rpm but I only took it to 5 or so where it smoothed out nicely. Below 4k very smooth too. It may be just a break in thing. I read somewhere about a yamaha super tenere vibrating badly until it had some decent miles on it. I'd love to find another 990 to ride now.
Not sure if I should just put the first 600 miles on or take it in now. Seems a little hasty, only 75 miles on it! Any 990 input? |
01-15-2013, 09:25 PM
#27 |
Zoob
Oddometer: 988
This bike needs at least 3-5000 miles on it to start working right. They are really sweet after the first 'proper' valve adjust.
These bikes are very sensitive to chain tension. The lowered (STD) models can get the chain tighter and will be smoother. The longer travel will just have to live with some vibes. When it gets even slightly loose, you'll get a vibe at 4200-5000 on the highway, more with a load, none without a load. It's only about a 1/3 turn on the adjusters to go from vibes to no vibes. Never over tighten. Have two friends sit on it and check the tension. It should not be bow string tight.
"Dad, can I get a motorcycle when I grow up?" "Son, you can't do both" |
01-15-2013, 09:34 PM
#28 |
Oddometer: 19
Chain tension
Thanks for the tip!
I'll give it some more break in time, weather permitting. I'll check the load vs no load at the 4200 to 5k vibration zone, hadn't thought of that...pulling in the clutch or trying it downhill. I'll also check the chain tension. I remember one time getting my then new 888 back from the shop and having a horrible vibration at certain rpms. Eventually i stopped and checked over the bike to hear the ticking sound of a chain about ready to explode from heat. It was so freaking tight and so freaking hot i wouldn't dare ride it, so I walked to a house to borrow tools to loosen it. Apparently the tech at the shop didn't tighten either the axle bolt or the tensioner bolts and it tightened as I rode it. I check stuff out a little better now. |
