01-13-2013, 04:27 PM
#1 |
Oddometer: 74
No Toil Pre-Oiled Filter - XR250
Are these filters okay? An OEM or a UNI are about 2X the price.
Do they use the OEM screen/frame? Thanks, DJ
David Johnson |
01-13-2013, 05:01 PM
#2 |
Oddometer: 52
Try a K&N filter, blow it off with an air hose to clean it
01-13-2013, 05:33 PM
#3 |
Oddometer: 181
I use twin air, you get what you pay for. I wouldn't use a k&n if you plan to ride off-road. You'll get more than your share of dirt in the motor and that WILL wear the valves prematurely.
Current Rides:1998 KTM 620 Adventure Past Rides: 1994 KTM 400 EXC WP/D LC4 - Plated; 2001 BMW F650GS Thumper; 1970 CB175; 2003 KLR250 |
01-13-2013, 07:44 PM
#4 |
Needs to STFU
Oddometer: 7,866
I love No-toil. Great for Euro bikes like KTMs, Husky, etc that are very finicky about getting dirt or sand in the intake.
Total overkill for an XR250.
Wedding = $25,000 Divorce = $500 2007 Triumph Tiger 1050 ABS = Priceless
01-13-2013, 08:57 PM
#5 |
Molon Labe
Oddometer: 6,287
And don't forget to blow out the downstream side of the intake where all the dust that's transited to K&N filter has accumulated... YMMV
Chris '03 KTM Adventure 640 '43 BSA M20WD |
01-13-2013, 09:21 PM
#6 |
Oddometer: 882
They are cheap filters. They won't last as long as the more expensive filters, but they're ok for a while. On the late model XRs they use the stock screen. I don't know about the older models.
It's not a big motorcycle, just a groovy little motor bike. lamotovita screwed with this post 01-13-2013 at 09:29 PM |
01-14-2013, 05:38 AM
#7 | |
Oddometer: 74
Thanks everyone for your comments. I think I will try the No Toil. It is half the price of everything else out there and the two fifty doesn't get used that much in extreme conditions.
David Johnson |
01-14-2013, 05:49 AM
#8 | |
Oddometer: 3,974
how the heck is it overkill if it is half the price of a comparable UNI or OEM filter...? and how is one bike more finicky about sand or dirt in the intake than another..or was the point that an xr valvetrain is a bit more robust or old school than a newer model valvetrain? and can thereofre take a bit more dirty air? if so I would agree on that cheers |
01-15-2013, 07:51 PM
#9 |
Oddometer: 1,138
My xr650 has a no-toil on it, and I've always used either uni or twin air on everything else.
Except for the difference in cleaning they seem to perform the same. I bought the one for the xr as a tester, I haven't decided one way or the other which one I like better. Also I haven't had it long enough to comment about longevity. The no toil is easier to clean. Either way its messy, but using water and a kitchen sink beats the parts washer and diesel fuel. All typos and misspellings blamed on my phone. |
01-15-2013, 08:24 PM
#10 | |
Awesometown
Oddometer: 400
'76 Xl250 '04 XR250R '09 DR650 '10 TR450 |
01-15-2013, 11:39 PM
#11 | |
Needs to STFU
Oddometer: 7,866
No-toil filters might be cheaper, but it's a wash because you have to use their oil and cleaning solution/grease. It's usually sold as a kit.
I would venture that the tolerances in newer aluminum engines are much more precise and have less allowances for dirt and grit. Normal maintenance and proper seating of the air filter is enough to avoid this. Quote:
Every post is an opportunity to learn something from someone. Only a fool thinks otherwise.
01-16-2013, 04:30 AM
#12 |
Suffer Fools; Gladly!
Oddometer: 318
I just ordered a UNI from Rocky Mountain ATV for my 2001 XR. I thought it was interesting that the UNI comes with a replacement filter cage.
The UNI spin sez: The Uni Air Filter is two layers of foam that will trap small and large particles like dust and dirt helping prevent anything reaching to the cylinder. Uni Air Filter is manufactured of high performance foam and biodegradable. The Uni Air Filter has a seamless design that allows for a maximum amount of air flow to your machine. The Uni Air Filter is easy to clean with the Uni Air Filter Cleaning Kit and will help cut the grease and oils down so you are able to reuse indefinitely MULTI-STAGE COMPETITION OFF-ROAD AIR FILTERS. Traps dirt and dust in two layers of foam, the large pore pre-filter captures the bigger particles. The small pore inner filter prevents any engine wrecking grit from reaching the cylinder. Comes with a replacemnt filter cage.
01-16-2013, 07:39 AM
#13 | |
867-5309
Oddometer: 2,570
+1 - Ignore list.
DO WHAT YOU LIKE - LIKE WHAT YOU DO Explain to me again why enjoying life when I retire is more important than enjoying life now? |
01-16-2013, 07:53 AM
#14 | |
Oddometer: 3,974
I to agree that despite most of our opinions and likes, LEARNING beats subjective banter 100% of the time... |
