Old 01-14-2013, 11:51 AM   #6871
Seth S
Safari Scramble!!!!!
Seth S's Avatar
Oddometer: 4,474
Originally Posted by crankshaft View Post
R U sure? I have a 100/100 rear and the sidewall is really short.
The 100/80 has a taller sidewall.
same brand of tires? I have seen differences in heights between brands. should be width/(height as percenty of width) - diameter.
Seth S
Seth S screwed with this post 01-14-2013 at 11:57 AM
Seth S is offline   Reply With Quote
Old 01-14-2013, 11:55 AM   #6872
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,429
Originally Posted by Seth S View Post
same brand of tires? I have since differences in heights between brands. should be width/(height as percenty of width) - diameter.
It's amazing the discrepancy in sizes between brands.
Old 01-14-2013, 11:59 AM   #6873
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
I found this. http://www.ehow.com/how_4841621_dete...tire-size.html
It seems a 120/100 would be 120mm tall and a 140/80 would be 112mm tall.
I guess the 140/80 would shorter.
I guess I could go for 100/100. That would surely give clearance.
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 01-14-2013, 12:01 PM   #6874
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
Originally Posted by motoged View Post
And , yes, the EXC swingarms can take in water and it is a good idea to drill a 1/8 hole in the bottom of each swing arm a few inches from the back end....and check the holes occasionally as they can get plugged.
What about the 690 swingarm?
I know we drill 950/990 swingarms too.
Tom
My2Wheels
690 WIKI
Old 01-14-2013, 12:06 PM   #6875
Seth S
Seth S's Avatar
Oddometer: 4,474
The 690 arm has some opennings in it as I recall...which makes me remember that I might have some stuff hidden in mine...hmmm better go have a look. I do recommend pulling out the adjuster bolts and coating them with copper anti-seize
Seth S
Old 01-14-2013, 01:38 PM   #6876
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,012
Oh heck yeah. I do that to all my swingarms. I learned my lesson way back on a 1980 Husky swingswing arm.
Tom
My2Wheels
690 WIKI
Old 01-14-2013, 01:48 PM   #6877
DirtJack
DirtJack's Avatar
Oddometer: 1,531
I run Michelin T63's on my knobby wheels. The rear is 130/80. Works well and they are cheap.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 01-14-2013, 02:08 PM   #6878
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,137
Yes your are correst. The first number is the width and the second number is the height expressed as an aspect ratio of the width.
90/90/21 says the width is 90 and the height is 90% of the width.
At least that is what the tire section of motorcycle-superstore.com says.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 01-14-2013, 02:36 PM   #6879
DirtJack
DirtJack's Avatar
Oddometer: 1,531
The size 120/100 gives the width (120 mm) and height (120) as a percentage (100%) of the width. On a 140/80, the height would be 80% of 140 or 112. Changing tire aspect ratios can alter speed/distance measurements particularly if the change is on the wheel used for measurements.
2008 KTM 690 Enduro
DirtJack screwed with this post 01-14-2013 at 02:56 PM Reason: Correct mistakes
Old 01-14-2013, 05:08 PM   #6880
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
Have you fixed your 690 or it is still suffering leaks ???
Paul Jr 8
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 01-14-2013, 06:32 PM   #6881
Seth S
Seth S's Avatar
Oddometer: 4,474
Paul Jr 8
Have not touched it or ridden in 9 months....other than to drain the coolant out of it. Had 3 decent crashes last year and needed a reset. I have done 10 years of ride and not much else so a little breather. Bike will get torn down and reiterated this spring.
Seth S
Old 01-14-2013, 07:14 PM   #6882
motoged
motoged's Avatar
Oddometer: 908
R U sure?
Yep....and the technically adept guys even agree.....
But you can think whatever you want
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 01-14-2013, 07:59 PM   #6883
Gros Buck
Gros Buck's Avatar
Oddometer: 847
R U sure? I have a 100/100 rear and the sidewall is really short. The 100/80 has a taller sidewall.
Positve.
100/80 means 100 mm wide x 100*80/100 = 80 mm heigth As you can read in the link, it's the aspect ration, and it is exactly the same principle with car and truck tyres.
The lower the aspect ratio, the sportier it is. Typicaly, sport car tyres have aspect ratio in the area of 30 to 40.
That said, the end result is not always in sync with the reality. Dunlop D606 130/90-18 are as wide as Pirelli MT21 140/80-18, and as tall as well ... It's not an accurate science ...
Paul Jr 8
KTM690r 2011
Old 01-16-2013, 12:51 PM   #6884
Kirkster
Parts Murderer
Oddometer: 296
Anyone know if we can swap out the 2012 instrument cluster for an older digital one?
I already have white dust in my 2012 one as well as LCD issues with parts of it blanking out...
Cheers..
K
TAT 2013 the "I'm Just Sayin" tour
BMW 2007 R1200R
2012 KTM 690 R
07 WR 450F
Kirkster is offline   Reply With Quote
Old 01-16-2013, 06:01 PM   #6885
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
Just asking a question, I don't spend hours and hours researching tires and specs I can tell you though, that twisting the throttle makes them disappear quicker and sitting on the couch makes them last forever
Just say'IN
crankshaft is offline   Reply With Quote
Times are GMT -7.   It's 05:40 AM.
