Old 09-18-2012, 09:20 AM   #16
mtiberio
mtiberio's Avatar
Oddometer: 88
you most certainly can hone a nikasil cylinder. I used to do it every year back when I raced. The trick is to use a "used" dingleberry hone, Get a bucket filled with soapy water, put the cylinder in it, and put the hone in a drill. You only want to make one or two passes, just enough to clean up the cylinder, and put crude cross hatching back on the surface.
You can also use chrome top rings on nikasil, but cast iron is the recommended material.
Wiseco makes some 94mm stroker volkswagon pistons that I have used in an SP once. I believe they gave 1083cc. They have the right compression height (distance from wrist pin to deck), wirstpin diameter (22mm), and are flat topped. they are about $100 each:
http://www.nolimitmotorsport.com/prod/K001ESV
mtiberio is offline   Reply With Quote
Old 09-18-2012, 09:33 AM   #17
mtiberio
mtiberio's Avatar
Oddometer: 88
you can get wiseco pistons as sing;e replacements. You could get two for about $220:
http://www.wiseco.com/PDFs/Wiseco-VWType1FlatTop.pdf
http://www.summitracing.com/parts/WIS-6633M94/
Old 01-16-2013, 02:22 PM   #18
woodly1069
woodly1069's Avatar
Location: Louisville, KY...really too far from the hills!
Oddometer: 1,854
Hey JonnyCash, you still have those old iron sleeved jugs lying about? I just found out my chrome is flaking...I'll try a PM too!
If you can't fix it with a hammer, you've got an electrical problem!
woodly1069 is offline   Reply With Quote
Times are GMT -7.   It's 09:55 PM.
