Old 12-28-2012, 10:09 AM   #796
JTT
JTT's Avatar
Oddometer: 1,376
Send a message via Skype™ to JTT
Saw a neat trick the other day by a plumber. I had a leak in a 4" ABS drain pipe inside a wall (as a result of a "misdirected" recip ). Instead of cutting out the pipe, he took another piece of ABS and started sawing small strips off and collecting the shavings. Mixed the shavings with ABS glue on a board making a slurry (as the glue dissolves the ABS), then applied it like putty. Made me think of other applications using this technique.
JTT is offline   Reply With Quote
Old 12-31-2012, 01:03 PM   #797
small_e_900
Amanda carried it
small_e_900's Avatar
Oddometer: 1,296
Most motorcycle plastic is ABS.
You can repair cracks in a similar manner, but if you take the shavings and put them in a jar of acetone over night, you'll have a paste that will have a longer working time than if you use ABS glue.
____________________
The highest function of love is that it makes the loved one a unique and irreplaceable being.
Tom Robbins
small_e_900 is offline   Reply With Quote
Old 01-01-2013, 06:01 PM   #798
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,285
Related to that, Christy's, Oatey, and Weld-On each make a black-colored, ABS-filled, medium-body, ABS cement. It sounds a lot like what you're talking about.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List
Poolside is offline   Reply With Quote
Old 01-02-2013, 05:12 AM   #799
mikesova
mikesova's Avatar
Oddometer: 1,370
I recently acquired a Honda quad that was missing it's starter button. There was a square plastic pin still sticking out, though. I work with kids in an afterschool program and we were taking old keyboards apart a few weeks ago, to use the parts for upcycling into other items. I noticed the keyboard keys might work ok for the job. I hollowed out the inside portion of the key and it slid over the square pin just about perfectly. So, I used some Goop to glue the new button on. I waited 24 hours and boom, it works perfectly. :)
2009 Kawasaki KLX250S
2001 Yamaha TTR125 (Wife's bike)
2005 Yamaha FZ6
mikesova is online now   Reply With Quote
Old 01-03-2013, 09:18 AM   #800
indr
Oddometer: 840
Brake cleaner fumes clear up my sinuses.
indr is offline   Reply With Quote
Old 01-05-2013, 05:39 PM   #801
duck
PsyKotic Waterfowl
duck's Avatar
Oddometer: 9,966
I wire up an Audiovox CCS-100 cruise control to the K1100LT/R1100RT windscreen switch on my K bikes. Waterproof OEM switchgear w/o the need for an add-on control pad.
93 K1100LT, 94 K1100RS, 86-97 K75F (K75/100/1100 Frankenbrick), 91 K1, 05 KTM 450 SMR
IBA #17739 (SS1K, BBG, 50CC)
http://home.comcast.net/~smithduck/BMW_Tours.htm
duck is offline   Reply With Quote
Old 01-15-2013, 04:45 AM   #802
arcanum
Oddometer: 235
Bobcat 853 fuel line repair
The cracked fuel [suction]draw line/check valve on my Bobcat 853 was just impossibly located to remove and re-install with a replacement. The replacement part fits into a 7/16 diameter hole and when installed,expands the rubber parts to fill the non-threaded hole in the tank.
I tried for hours to figure out how to get the old part off and the new part on.The little beastie was located somewhere under the main hydro drive pump in a[ stand-on your head to get at things and no room for your hands or tools ] cluster fock engineering nightmare.
The fuel tank is made from heavy poly like an ag spray tank. Suddenly it hit me... Drilled a new hole in the tank in an accessible location ,ran new fuel line/check valve to the engine, and plugged the old fuel line coming from the original location.
Half hour job once the "right way to do it" was abandoned.
arcanum is offline   Reply With Quote
Old 01-15-2013, 11:50 AM   #803
taosgsr
taosgsr's Avatar
Oddometer: 336
Redneck Spring compressor
From web
See ya at the Pub!!
"don't I have a real dirtbike to do this on?????"
taosgsr is offline   Reply With Quote
Old 01-15-2013, 08:44 PM   #804
grizzzly
The Pre-Banned Version
grizzzly's Avatar
Oddometer: 2,729
Originally Posted by taosgsr View Post
how do you have that camper set up?
any mor pics?
you actually expect people to take responsibility for their actions in today's society?!
grizzzly is online now   Reply With Quote
Old 01-16-2013, 03:57 PM   #805
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 1,721
any mor pics?
Yeah, I really like the idea of a bulldozer with attached camper.
Go anywhere, make your own damn campsite.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR650 - Turd II, The ReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 01-16-2013, 04:44 PM   #806
grizzzly
grizzzly's Avatar
Oddometer: 2,729
I am just thinking that he mounted a camper to his tractor to protect himself from the weather
Old 01-16-2013, 06:33 PM   #807
Geek
oot & aboot
Geek's Avatar
Oddometer: 25,748
the weather... or flying springs
www.motogeek.com
Old 01-17-2013, 06:23 AM   #808
Trixie
No, not that Trixie
Trixie's Avatar
Oddometer: 3,358
Send a message via ICQ to Trixie Send a message via AIM to Trixie Send a message via Skype™ to Trixie
Coming home from the airport many years ago in the GF's VW jetta. Headlights just go out, fuses fine, can't find any obvious wiring issues (in the dark) .
Bought a common 110v extension cord at the convenience store, stripped the wires at one end and clamped them to the battery posts. Simply plugged the other end into the backside of one of the headlight connectors. Drove it home 1.5 hrs that way.
One of the penalties for refusing to participate in politics is
that you end up being governed by your inferiors. - Plato
The important thing is this: To be able at any moment to sacrifice what we are for who we could become!
Charles Dubois
Trixie is offline   Reply With Quote
Old 01-23-2013, 09:28 PM   #809
smilin jack
Grandpa Adventurer
smilin jack's Avatar
Oddometer: 1,175
Wiper arm fell off
The driver side wiper arm fell off my 68 VW camper van while driving to Alaska thru the Yukon... at night in a rain storm. Turned around and drove slowly looking for it. Found it lying in the road unharmed but the set screw was corroded in place (steel vs aluminum).
Sat and thought a while, got a beer can from the garbage and cut a 1/2" wide strip, formed a ring to fit over the wiper stud just below the windshield and hammered the wiper arm back in place. It lasted for the life of the vehicle. Sold it several years later with the wipers still working.
My friend had his wiper motor burn out on a trip, so rigged soda straws in the wing windows and strung braided fishing line thru the straws, tied them to the wiper arms and had a loop to operate the wipers. His high school kid worked the wipers as needed.
Fixed my chainsaw wire with a soda straw.
The insulation had worn/burned off the ignition wire and the saw wouldn't run. Ran the wire thru a short chunk of soda straw to use as insulation. It's still on the 031 Stihl saw many years later. The ignition module is outboard on the side of the saw.
Dave
smilin jack screwed with this post 01-23-2013 at 09:35 PM
smilin jack is offline   Reply With Quote
Old 01-24-2013, 06:11 AM   #810
tgeliot
Topher
Oddometer: 1,328
Beer can shims. Pirsig would be proud.
Topher
1989 Transalp. Sort of.
I don't have a bucket list, I have a post-bucket list. So far it includes
1) Coroner's report is to read "Death by misadventure."
2) Dixieland jazz band at my funeral.
tgeliot is offline   Reply With Quote
Times are GMT -7.   It's 08:15 AM.
